1991 190e 2.3 dying
thoughts?
Is this a manual or auto transmission? This is even a bigger problem in manual transmissions as the auto's most of the time hide the underlying problem.
190Fan - I think it is a fuel issue vs electrics. and the car will always crank
Before replacing all the parts listed, the car was stalling much worse. the mechanic finally after all the work above said it ws a bad coil????????
The fuel tank was replaced by the former owner
One of my biggest problems is finding a LOCAL mechanic to work on it without having to drive long distance to Mercedes/Bosch specialist.
Im thinking maybe replace the cap and rotor with the electric module type, like I used to do back in the 70s. Not sure they still do that.
Thanks for the response though.
I'm 95% sure that this is an idle control issue. When I got tired of my manual transmission dying on me in between shifts I had to diagnose the problem mostly by myself with some on line help. That was 5 years ago and my car has not stalled on me ever since after the fix. You can imagine manual transmission amplifies the problem because your rpm is dropping like rock between shifts.
So the idle control has a few mechanisms to avoid stalls when the car/engine is slowing down. In your case one or more of these systems are failing you.
Here are the mechanisms.
(1) Throttle switch + microswitch: properly senses the plate and pedal positions to activate idle control loop
(2) Idle control in the ECU/MAS (depends on MY) could be intermittently cutting out due to electrical problems like OVP, could also be that the ECU/MAS is failing altogether for this case only.
(3) Hall effect sensor loop - Senses if the tires are moving at all, when the idle transitioning is happening. If the engine rpm is dropping from >1800 rpm and you let off the gas pedal it maintains idle >1000rpm for a while and at that point eases the rpms slowly to the normal 750rpm.
(4) Fuel cut off - The ECU senses when the fuel should be completely cut off when appropriate and by means of the EHA valve turns off the fuel flow until the engine rpm's drop to about 1200 rpm.
(5) Have I missed any other??
Happy motoring
thanks again
I do not expect a mechanic to know details of #2, #3, #4 or how to diagnose them.
This is why all of us need to know these items when diagnosing this type of problem even if it is merely for communicating with a mechanic's shop.
Basically you need to know more than the mechanic.
One more item is that there is one gauge that is desperately needed in a 30+ year old KE-Jetronic system in any W201 dashboard.
It is easy to install and with it you would not even need forums to answer items 2,3,4 in the above list.
You would also know how your Emissions system is functioning, if your EHA is aligned, if your AFM plate is adjusted correctly, etc, etc., at all times.
I know I have advocated for this in the past, just repeating the same here in your post.
BTW, does your car stall if you are coming to a stop and before you stop you throw the gear into neutral? Just curious.
It kept stalling but as soon as I swap the O2 sensor i was able to start daily driving the car with no further issues. It still ran the same as before as far as idle rpm but engine no longer quit
So basically if any sensor, actuator etc. is acting up, the EHA current meter will inform you there is a problem, as long as you understand the system.
This is why I say it is essential for a 30+ year old continuous injection car.
BTW, does your car stall iyou are coming to a stop and before you stop you throw the gear into neutral? Just curious.
I dont want to bug you guys to death, I will research it more and let you know what I find.
However, when it starts the stall, is your foot on the gas pedal or off the gas pedal. Or can it start the stall in either case? This is key.
The gauge I described does not exist commercially. It sits in your center console right next to a voltmeter in my car. I had these custom made for our 190's by a reputable company.
I constantly monitor the EHA current which is the final output for emissions control. Therefore you are seeing all of the sensor's effect on that current. I can even tell if my AC compressor is running because even that effects some the EHA in an obscure way. Things like OVP cut off is ridiculously easy to see as well.
For these intermittent stalls, it is invaluable in diagnosing because you are seeing the ECU's final output as the stall is appearing. And it is important to have an old analog gauge as opposed to a digital one that will always jump around and hard to see.
You do not appear to be a DIY person, but it is rather simple to install if you were. I'll re-post a picture if anyone is interested.
The alternative is to not permanently wire this in but to pull wires in to the car and attach a current meter to it temporarily and drive around with it and monitor your EHA current.
There are breakout harnesses sold for EHA current reading. They are available online. And for this a digital current meter could be used.
Back to dolucsi comments. I Initially focused too much on engine just cutting out when turning, It never happens if I let the car just set and idle. Have tried it for 45 minutes and is OK.
It does happen when driving. Could be cruising down highway and it cuts off. or when I slow down to turn off interstate or stopping at light. It never seems to happen on short drives ( ie less than 10 minutes) usually 30 minutes or more.
Thanks, again, its not your guys responsibility to fix it for me but I do appreciate your responses.
I would first rule out item "1" in the list of post 5. That is the low hanging fruit. And it can be easily checked by a knowledgeable mechanic
Once that is checked out as 190Efan mentioned above, it sounds like either your EHA is not working properly or is slow to react to fuel cut off.
That could also be that your ECU is slow to "undo" the fuel cut off. In other words slow to react. That is item "4" on that same list.
If you did not know this, the fuel cut off does not engage until the engine reaches full operating temp. This takes 5-10 minutes after you first start an engine. Sounds like you are also observing this during your stalls after a warm engine.
It is unusual to have EHA electro-mechanical failures before the EHA starts leaking which is about 100K miles with good fuel. But that does not mean it never happens.
If you want to make sure this is your problem you will have to observe the EHA current like I mentioned earlier while you are driving in the car and verify that the engine stalls only after the fuel is cutoff.
Another way to verify this is for you to take over of the ECU's responsibility. Meaning when you are slowing down as soon as the rpm's drop below 1800 rpm, down to between 1400-1800 rpm, pulse the gas pedal. I mean to momentarily tap it to disable the fuel cut off early. Does the car ever stall if you do this? By "ever" I mean try it at least 10 times maybe more to make sure you are not observing a false positive.
There are other ways to verify this. But it starts to get involved. There is one other condition that disables fuel cut off. You guessed it..... Your AC compressor being on disables fuel cut off.
I suspect that the likely hood of stalls would be much less likely if the AC is on and the compressor is running. You can even fake the ECU to think the compressor is running all the time but that could get involved.
I would confirm fuel pressures and volume
Get % reading at X 11- this is a biggie
Clean all electrical terminals, relay's, sensors, grounds, replace fuses.
Trace all electrical connections at 25 pin ECU connector.
Even though the car runs mostly ok doesn't mean the mixture is set correctly. The mixture could be set such as it is out of the range that the ECU-EHA can't make the right correct fueling, and therefore a stall or dip in idle.
Monitor running battery voltage looking for any spikes or drops when the stalling happens.
It isn't easy these intermittent issues.
replacing the fuel pump, filter and accumulator.. Any thoughts.
Now the Fuel Pump Relay cutting off can cause stalls, that is for sure but would not effect the air pressure in the tank. That is more of a mechanical "thing" not electrical.
I would not recommend replacing parts blindly not knowing how old they are especially if you are not replacing them with OE parts. Because quite often replacing a perfectly functioning factory part that is superior to a new aftermarket part. So replace them as the start to fail, or if they are at the end of their natura life. For example a fuel pump life is 100Kmiles to 120K miles, so replacing them before they fail at that mileage is fine with another Bosch unit. My accumulator was still functioning at 200K miles, when I replaced it. Life expentence also depends on other factors like climate, fuel quality used, etc. etc.
If everything else seems to check out then I recommend checking the fuel strainer too and Inspecting your fuel system back to front in general. In case of the blocked strainer the fuel pumps will be able to pull fuel but struggle as you drive and the tank sloshes around debris that occasionally blocks the outlet/strainer resulting in an inconsistent stall and the increased pressure
