Anyone know the part numbers for connectors on a COMMAND 2.0? (Richard)
2000 CLK 320
I went to the dealer and gave them the following part numbers:
C Connector (male) A016 545 36 28
C1 Connector block A034 545 7526
but they said those parts were non-existent or not in the computers. Anyone know the correct part numbers? Thanks.
P.S. These are the connectors that go on the back of a COMMAND 2.0.
2000 CLK 320
The second part:
should say
C1 Connector block A034 545 7528
As for the C connector (male), I can't find that part either and I'm going to cut the wires. G' luck
should say
Hello guys,
Go to this page, http://www.benzworld.org/gallery/sho...0&subname=John`s_E55&parentname=W210_E_Class , I took those pictures during my COMAND installation and part numbers are there too.
John
John
2000 CLK 320
Originally posted by Richard
Hi
The C "male" connector is A016 545 36 26
You found the correct C1 part number already - looks like I had my 26 and 28 mixed up ...
R
Hi
R
Funky102,
You are looking for the C1 plug where the CD-changer switch wires go into right? It has 10 contact holes in it. Then this is what you need http://www.benzworld.org/gallery/pic...J5025009PM.jpg Let me know if this is correct.
John
John
2000 CLK 320
Hi John,
I already have the C1 connector. I'm looking for the male C connector so that I don't have to cut the wires from the female C connector attached in the car. This female C connector plugs into the old stock radio.
I wish I had pictures but let me try with a diagram.
Car-----(wire)-----(C female connector) -----> (C male socket, part of stock radio)
What I want to do is...
Car----(wire)----(C female connector) ----> (C male connector)----(wire)-----(going to C1 and C2 connectors)(into COMAND)
The "----->" indicate "plugging in"
Hope this clears everything up.... I get confused myself sometimes when I explain it.
2004 SL55, 2015 A250d, 2016 GLC250d
Originally posted by funky102
I checked again and this part just does not exist here in the United States. . Can anyone else confirm this? Thanks...
Its never been ordered in the UK before, so they checked with Germany and the part does exist (but Germany are out of stock)
Sounds like you need to tell your dealer to order it , and then it will appear. I imagine your dealer has just not ordered a part that hasnt been ever shipped to the US before
R
