Sponsored by: Innova
Mercedes Bluetooth (AWS) Phone Compatibility List
Old Nov 23, 2008 | 05:32 PM
  #401
Vik888's Avatar
2008 E550, 2012 GL450, 2014 GLK350, 2015 S550, 2020 GLC350e
Blackberry Storm anyone w/ the BT Puck?
Old Apr 20, 2009 | 05:22 PM
  #402
MBZ_lover's Avatar
06 E320 CDI
Skylar, you seem to be quite the BT guru in the forum, thanks for the hard work and info that you have supplied.
Question for you, I have a 2006 E320 CDI (02/06 build date), the phone is not wired for the phone system and I being in CA have to add a BT system to the vehicle and also want to add iPod integration.
I have looked at some info on the OEM BT puck and wiring along with the ability to add VCS to it but the cost is a bit alarming to me. I do like the OEM stuff over aftermarket in general.
The aftermarket unit I am looking at is a MoBridge with BT & iPod integration.
So questions are:
1. Would OEM VCS work with the MoBridge unit
2. Is the OEM BT better than the MoBridge unit for reception, clarity and use
of steering wheel control. I have an iPhone with 1800+ contacts in the
phone book
3. Assuming the OEM makes use of the Tel-Aid phone mic, etc.
4. Saw Kevin's PDF and think I could handle the install myself if I knew all
the parts for my car.
Thanks for any feedback and info.
Old Apr 20, 2009 | 08:39 PM
  #403
dan30252's Avatar
C63 AMG
Blackberry Curve 8900 (new Curve) works great with OE bluetooth (on my 09' C63)
Old May 22, 2009 | 12:38 PM
  #404
fostershields's Avatar
Mercedes Benz E350
Bluetooth
I had a tookie (after market) bluetooth installed in an MB E350 and it did something strange to the fiber optic network and took out all my nav, radio, all electronics. It also - when it did work - had a horrible echo on the other end, as well as dropping calls. It was interesting. Then, when I considered a MB bluetooth, we could not pair my phone (AT&T Tilt) which supports windows. What am I doing wrong, has anyone faced this? Bluetooth is not an option for me....I must have it.
Old May 24, 2009 | 09:41 AM
  #405
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
Check the firmware on the Tilt. Some earlier Windows Mobile firmware had a problem with many Bluetooth systems, but an update fixed most of these. I don't have the update bookmarked, but a search may find it for you.
Be advised though that if the Tilt is not compatible with MB, you still won't get things like phone book downloads. You should be able to place and receive calls, at minimum.
You will find it easier to buy a phone that is compatible with your car than to find equipment compatible with your phone.
Old Aug 9, 2009 | 01:55 PM
  #406
mikesa's Avatar
Originally Posted by JohnAMG
Update for my LG Dare phone. It integrates flawlessly with the GL450 but no phonebook download with my 2006 E55. I believed this is due to the older bluetooth module(first generation) I installed in the E55. The GL450 has a newer version of bluetooth.
John
A little late in this response but my experience with the LG Dare is that the address bok works fine with the first BT adapter for my 2006 E350.
Mike
Old Sep 13, 2009 | 11:21 PM
  #407
SkyCrusher's Avatar
G500, 300SE, SL560
Ne1 have success pairing and dL'g contacts with the new Blackberry Tour 9630 and v60 puck?
TIA.
Old Sep 22, 2009 | 08:12 AM
  #408
ram_rtg's Avatar
C200K Jul 2004
Anyone know the bluetooth pairing password for B6 787 5877? I've misplaced the booklet that comes with the unit. Other numbers on unit are:
08w18
HW: 1906
SW: 5106
Thank you in advance.
Old Sep 22, 2009 | 08:19 AM
  #409
ram_rtg's Avatar
C200K Jul 2004
Old Sep 22, 2009 | 09:05 AM
  #410
Diesel Benz's Avatar
08w18
HW: 1906
SW: 5106
I've never seen one but I believe the code is 62872. You should find it from the AWS site too.
Old Sep 22, 2009 | 09:23 AM
  #411
ram_rtg's Avatar
C200K Jul 2004
Thank you very much.
It works
Old Sep 22, 2009 | 11:22 AM
  #412
gvaughn's Avatar
2006 E500
08w18
HW: 1906
SW: 5106
I believe each unit has it's own code, but it's been a while, so I'm not 100% sure. There should be a little cover that comes off, and the code should be underneath. Check to see if you can find a code on the unit itself.
Edit: The above code: 62872 is correct. But as mentioned in my post, it is also listed on the puck. See this post for more info in case you forget the number in the future (see image 3 from the link below):
https://mbworld.org/forums/2625685-post13.html
Old Sep 22, 2009 | 05:21 PM
  #413
weinschela's Avatar
'14 E350 wagon; BMW G12 (2020) G01 (2019)
An easy way to remember the code is "MBUSA".
Old Sep 22, 2009 | 05:31 PM
  #414
bigben320e's Avatar
CLS63 Designo Edition, Hyundai Genesis 3.8 , Veloster Turbo, CLS500(Sold), E320 (SMOKED) R500 (Sold)
Adding to the list:
Samsung Jack: 4
By using the original key, it does not do 4. All others work with the BT puck.
KEY:
1. No PhoneBook Download
2. No Call List Download
3. No 3 way
4. No SMS Download
5. No DTMF Tones
6. No Signal Strength Indicator
7. No Speed Dial
Old Sep 22, 2009 | 11:11 PM
  #415
Skylaw's Avatar
In U.S. specification cars, SMS is not supported over Bluetooth in MB systems. It will work with plug-in phones only.
Old Sep 22, 2009 | 11:36 PM
  #416
bigben320e's Avatar
Good to know, so 4 is moot anyway in regards to the BT puck correct?
Old Sep 23, 2009 | 05:24 AM
  #417
ram_rtg's Avatar
C200K Jul 2004
Thank you guys yes the code does work
Cheers
Old Sep 23, 2009 | 10:44 AM
  #418
Skylaw's Avatar
Yes.
Old Sep 23, 2009 | 11:41 AM
  #419
JonMBZ's Avatar
06 C55, 09 E350
Foster I have a tilt and it pairs fine. Have you modified the ROM at all? Mine is completely custom and I noticed with some of 6.5 roms they use a bluetooth diagnostic tool that tries to auto pair the device. If so on the bottom right corner there is something that says "more" use that to search for devices instead. This will allow you to enter the needed password.
Old Oct 5, 2009 | 10:44 PM
  #420
maggiehammock's Avatar
c240
HELP!!!
I can't find one person in my life who can answer this question for me. I have a C240, 2005 when I bought my Mercedes the bluetooth chip did not come already installed I have a set for a phone but no chip, where do I get this installed besides the dealer???
Old Oct 6, 2009 | 10:05 AM
  #421
Skylaw's Avatar
Welcome to the forum.
You probably can't get an answer because your question is just a bit off the beam. There is no "chip" - it's an entire system, with several components. You don't identify the "set" for the phone that you're talking about - we don't know what you mean.
Your car uses an MHI phone system. The phone bulletin for your car, which identifies the system components, is at http://phdwebsite.powerpulse.cc/Phon...0C%20Sedan.pdf. You can read a bit about equipping cars with an MHI system at post (permalink) #5 at http://www.benzworld.org/forums/audi...des-plug.html; and post #1 contains additional information about version coding and also other sources of parts.
The phone bulletins for the C-Coupe and C-Wagon are at http://home.earthlink.net/~phdwebsit..._bulletins.htm
Please read those materials, and if you still need help, ask again - preferably in the "How To Guide" string.
Old Oct 20, 2009 | 02:49 AM
  #422
rockett0's Avatar
e320
Ipaq910
Adding to the list:
HP Ipaq 910 (4)
KEY:
3. No 3 way
4. No SMS Download
5. No DTMF Tones
7. No Speed Dial
Old Nov 23, 2009 | 07:07 PM
  #423
phil3path's Avatar
2003 e320
IDEN BOOST MOBILE PHONES??
Hi does anyone know if Boost mobile phones pair up with the puck and tail? I have the motorola i465. I believe nextel is on the iden network too. I will be trying to pair mine up in a few days when i get the first generation puck in the mail and ill let everyone know if i dont hear anything before that.
Old Dec 15, 2009 | 07:44 PM
  #424
kw2000's Avatar
08 CLS 550
Exclamation Samsung M 300
FYI. Just want to add Samsung M 300 to the list of cellular phones that work with Mercedes Benz Bluetooth Adapter B67875878. I just bought the adapter at EBAY for 08 CLS 550, it paired fine and downloaded phone book successfully. However, it often says "no service", but after turning the phone off and on again, it works ok. Is there something I am doing wrong to get the message "No service"?
Old Mar 7, 2010 | 11:28 AM
  #425
Mrsl500's Avatar
SL
bluetooth options link
http://mercedes-benzbluetooth.blogspot.com/
have a look at this link has been quite helpfull.
You have already rated this thread Rating: Thread Rating: 9 votes, 4.56 average.
