Sponsored by: Innova
Mercedes Bluetooth (AWS) Phone Compatibility List
Old Nov 12, 2006 | 03:45 PM
  #126
TLC 320's Avatar
2001 SLK 320
Question PSE and Voice Recognition
I have the old 2001 Timeport. If I update to the V60 & V60 PSE, will the new PSE support my Voice Recognition system (the verbal control of radio, cd player and cell phone)????
I don't want to lose this feature. ARGOS says they will allow the continued use of VR system.
thanks
Old Nov 12, 2006 | 06:43 PM
  #127
JohnAMG's Avatar
3 Porsche rotation
thanks
Upgrading your PSE will not disable the VR feature in your car. I upgraded my p old Timeport in my 02'E55 and everything works like before.
John
Old Nov 13, 2006 | 09:04 AM
  #128
mbbodytech's Avatar
04 C320 Coupe MT
Anyone have a Treo 700p? Palm/Verizon released an update recently that had listed, among other things, improved support for bluetooth car kits/headsets. I'm wondering if as a result of that update it works better with the MB system.
I have the 700w, and am hoping that they will release a similar update for it.
Old Nov 14, 2006 | 12:37 PM
  #129
s54Legion's Avatar
2000 s500 Phone ????
Hey guys.. Does anyone know what phone or aws kit will work with my phone sytem on a 2000 s500?? I already have the cradle installed. Should I get the startek phone or the aws cradle? Can anyone help me out?
Thanks!
Legion
Miami, FL
Old Nov 14, 2006 | 12:38 PM
  #130
s54Legion's Avatar
I have treo 700wx with windows mobile 5.0. I havent tried it in the car yet because I dont know how to hook it up.. Any ideas? I have a 2000 s500..
Old Nov 14, 2006 | 12:46 PM
  #131
Jayhawk's Avatar
S500/W220/2000
Thanks!
Legion
Miami, FL
I take it your car does not have a phone? Mine has a Startac phone and cradle, but neither is functional any longer. I think it will be very expensive if you have to start from scratch to install a phone, etc. There are many extensive discussions of your question. If you would just do a search, I think you will learn a lot. I found 172 treads using "startac." You might want to narrow it to the W220 and/or Audio forums.
And welcome a-board!!
Old Nov 15, 2006 | 08:41 PM
  #132
coult's Avatar
'01 S55
Just Received My New AWS BT Puck
After some research before placing my order, I got what I expected...
My purpose is to find a way to download/upgrade/flash a BT phone & work with the puck & command system. It seems ANY BT phone will work as a $300 hands free device. Question is; how to get command to recognize & download contacts from phone.
If your phone is USB enabled, can sync w/ a pc, & accepts downloads - I'll bet you pink slips (my wife's car) there is a way to make it work.
The "approved" phones that aws list must have a common denomintor neccessary to work w/ the puck. Whether it's software, BT version, firmware or internal tweaking... There was a post that metioned "flashing" at howardforums - but couldn't find pertinent info...
'01 S55 - Motorola MPX 220
Old Nov 16, 2006 | 10:28 AM
  #133
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
All the AWS approved phones for my car are made by Motorola just like the OEM Mercedes phone which came with my 2002. Could the common denomintor for all or most features be Motorola phones?
Old Nov 16, 2006 | 11:36 AM
  #134
Jayhawk's Avatar
S500/W220/2000
I read somewhere that our NAV will see the phone data if it is on the SIM card not in memory...
Old Nov 16, 2006 | 09:33 PM
  #135
MBZ_lover's Avatar
06 E320 CDI
Originally Posted by squarepants
I looked for compatibility info for a Balckberry 8700g (Cingular) elsewhere and could not find it. So, I took the plunge and decided to be guinea pig.
Good news! The 8700g works almost perfectly with the MHI Bluetooth Interface Module.
My car: 2007 E350/P2/333(Sports)
Phonebook downloads
DTMF tones work
Signal strength meter shows
No Call List Download
Not sure about 3 way
No SMS
Not sure about Speed Dial
My one complaint is that the phone book seems to fill up and throw an error code. I am not sure how much it can store but it is more than 100 numbers. It is probably a KB limit.
Anyways, I hope this helps someone.
Is the 8700g the same as 8700c? I have a Blackberry 8700c and am interested in the MBZ Bluetooth MHI and puck, any words would be helpful. I am having a Comand installed by Steve in my 99 E300 turbodiesel next month.
Old Nov 17, 2006 | 10:38 AM
  #136
ECP's Avatar
ECP
Blackberry's and all Bluetooth phones are compatible with Argos. Some carriers block certain OBEX and Phonebook Transfer functions (mostly Verizon and some Sprint) - Also some phones do not support phonebook transfer over the AUDIO bluetooth connection (has nothing to do with a BT data connection) for the simple reason the AUDIO connection only has an 8kbs overhead allowance for data transfer, and if you had a typical smartphone with hundreds of contacts in it, it would take forever to download the book to the car - PLUS Mercedes Benz cars have a 99 entry limit.
Just use Voice Recognition instead. It works better and it is safer.
Old Nov 20, 2006 | 01:30 AM
  #137
mrw1ggl3z's Avatar
has any one experimented with tmobile's sidekick 3 yet? thanks!
Old Nov 23, 2006 | 08:22 AM
  #138
jdr1000's Avatar
I just tried with my 700P and there is pariring and you can make and receive calls with no problem.
The only thing I am trying to solve is that the phone rings with the car.
J
Old Nov 25, 2006 | 03:48 PM
  #139
charliemike's Avatar
I am with the other guy that doesn't want to pay the AWS price when all these other bluetooth phones are out there for free. I am going to start a new service and want a phone compatible with the v60 puck which I will buy. Does anyone know if the LG cu500 will work or the Nokia 6682? If not how do I make sure that a RAZR that I order has the right software for the MB?
Old Nov 25, 2006 | 05:28 PM
  #140
gvaughn's Avatar
2006 E500
I haven't heard anything about the Nokia 6682, but if you do find out more info, or decide to try it yourself, please post the results!!! I would like to find out it's compatibility.
Old Nov 25, 2006 | 05:41 PM
  #141
I'm a little nervous signing up for a 2 year service and finding out the phone, whether it's a Nokia 6682 or the LG CU500 and finding out they are 1.2.3.4.5.6. I don't need all these phones. From what I read here the AWS folks aren't going to help out.
Old Nov 27, 2006 | 02:52 PM
  #142
bzliteyear's Avatar
07 E63 06 CLK55 Cab 03 P-car C4S
more phone questions
sorry to be a bother, but i've read the entire thread and i'm still ver confused as to what i should buy, and what i get in return.
i have a 2001 E55 and it has a factory cradle inside the arm console w/ the wirings all hooked up. i also have T-mobile svc currently and a motorola V330 phone, and no problems getting a new phone...just wondering if i need to buy add'l parts, and from whom.
thx.
Old Nov 28, 2006 | 09:25 AM
  #143
MagicO309D's Avatar
thx.
Do you have a V60 or Timeport system installed in your '01? If it's a V60 system, you just need the V60 Bluetooth Adaptor from AWS or your local dealer and an approved Bluetooth phone.
It it's a Timeport system, other parts will need to be upgraded too. Just stop by your local dealer, they should be able to tell you right away what you need.
Old Nov 29, 2006 | 12:58 PM
  #144
mbnj's Avatar
'06 E 350 4matic wagon; '05 E 500 4matic sedan; '09 S550 4matic
Can you still buy V60's that work? My latest brain storm is (I have a 2001 with Timeport, command, voice recognition, built in antenna): First see if Cingular will turn back on the AMPS (analog Timeport phone) and add it to my family plan for 10 bucks, then forward my existing Razor to the Timeport when I'm in the car (free mobile to mobile I think), Anytime I'm in the car I can call out using the Timeport/built in antenna or get calls that have been forwarded (only works 'til AMPS discontinued in '08). If not, i need to decide if I went to get raked and upgrade PSE and cradle and phone to V60 and maybe even then add the puck- real waste of money but i do miss the convenience/safety of built-in phone. Or sell the car!
Old Nov 30, 2006 | 07:58 PM
  #145
mohdds's Avatar
Just installed the new bluetooth RAZR cradle into my '07 CLK550 Cab with COMAND and NAV. I have a RAZR V3 with Cingular (Quad mode GSM) with S/W version R374_G_OE.41.C3R_B which is NOT on the "approved" list of software versions. Phonebook downloaded (of course with no symbols for work, home, mobile etc.), no call waiting, no conferencing, but phone works great both docked and undocked. Have not tried bluetooth functions with this cradle with any other phone at this time. It is interesting how few phones are on the approved list, yet how many seem to work. Hope this information helps.
Old Dec 1, 2006 | 12:12 AM
  #146
ToonArmy's Avatar
2003 SL500
Nokia E70 - works (minimally)
JUst reporting my experience. I have a UHI system installed, previously used a Sony-Ericsson T-637 cradle, but that phone quit.
I purchased a Nokia E70 (new smartphone), and decided to try the BT cradle.
It works, but just barely. I can dial (voice or keypad) and receive calls, but no contacts download, no call lists (not even redial), no signal strength, no named caller id (and, it appears it will not allow me to manually enter numbers into the COMAND phonebook - just the voice dialing).
Also some monior glitches - turning off and removing the key does not disconnect the BT pairing even if there is no active call. I didn't realise this, answered my phone inside the house, and no audio (it was being routed to the H-F). On a couple occassions, the audio connection seems to disappear, no sound either way on a call. Once at least the pairing has dropped for no reason I could tell.
Will try my girlfriend's S-E K790a next - it pairs very well with the Toyota BT system, including phonebook upload.
Old Dec 1, 2006 | 11:36 AM
  #147
E55 KEV's Avatar
Veteran: Air Force
How do you check the software version for RAZR V3 and where is the list of approved software? Thanks.
Old Dec 2, 2006 | 10:17 AM
  #148
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
Your owner's manual for the phone will tell you how to check your software version (probably somewhere under the "phone info" menu) - AWS can probably tell you whether your software is on their "approved" list for the RAZR.
Old Dec 9, 2006 | 11:49 AM
  #149
Blue tooth updates
12/9/06. Anyone have any updates on phone compatibility with the bluetooth puck? I am looking at the LGVX8600 for Verizon. I saw on an earlier post that the LG's had a lot of 1.2.3.4's on them. Is that because it is CDMA as opposed to GSM on Cingular I wonder?
Old Dec 12, 2006 | 04:25 PM
  #150
amgme's Avatar
07 SL550; C32 (sold)
Motorola Z520a
Just tried the bluetooth MHI puck w/ the motorola Z520a and it works w/ incoming/outgoing calls and downloading recent calling list/caller-id. It will not download the address book or do any 3-way/conf calls.
You have already rated this thread Rating: Thread Rating: 9 votes, 4.56 average.
