Sponsored by: Innova
MB Analog Motorola Phone
Old Aug 29, 2002 | 04:31 PM
rgleason's Avatar
C240 2002
RE: A Mercedes-Benz portable phone and install kit for a 2000 CLK coupe. The phone is analog. Do any of you know whether the booster, P.S.E., mounting bracket, hardware packet, and wiring from this phone kit will work in my C240 2002 car if I add a Timeport or a V60 handset and cradle? I think I might be able to get a good deal on all of that hardware. Please let me know.
**** Gleason
Old Aug 29, 2002 | 06:25 PM
awiner's Avatar
2003 CL55 AMG
I know that the 2000 model year CLK will not support the V60. I think Mercedes had a upgrade path to the Timeport for 2000 models however. Let me take a look and I'll get back to you.
Old Aug 29, 2002 | 07:59 PM
rgleason's Avatar
C240 2002
Thanks, I appreciate it.
Old Sep 1, 2002 | 07:10 AM
Ted Baldwin's Avatar
300ce
.........This is incorrect. I have a v60 phone installed in my 200CLK.
Here is the link
Old Sep 1, 2002 | 03:08 PM
awiner's Avatar
2003 CL55 AMG
Originally posted by Ted Baldwin
[B.........This is incorrect. I have a v60 phone installed in my 200CLK. [/B]
According to Mercedes:
Q: Can the V60 be retrofitted back to older vehicles? Which ones?
A: Yes, at this point, the V60 can be retrofitted back to MY'01 and certain MY'00 vehicles. Also MY'02 vehicles which were equipped with the Timeport kit can be upgraded as well. Depending on the vehicle and the model year, specific components of the integrated phone system will need to be verified and installed.
So, in effect, certain (But not all) 2000 models can be upgraded. I was not aware the CLK was one of them. I know certain models of the 2000 S-Class were upgradeable.
Old Sep 1, 2002 | 05:25 PM
Richard's Avatar
2004 SL55, 2015 A250d, 2016 GLC250d
The "phone" software/hardware interface is D2B, so if the head-unit supports D2B phones, then the control unit should work.
- For instance, Ted has a European COMAND (from memory) but is using the US phone controller - which we dont get in Europe - in fact we dont even get Motorola phones anymore, just Nokia - and when we got Motorola it was just the "fixed mobile" not the portable.
I imagine there are some early MY2000 cars with duff software in the headunits that doesnt quite work ... I would also imagine that a s/w upgrade on them would fix the problem, but maybee they wont s/w upgrade - ive come across some early COMANDs that you cant do the s/w upgrade on - it just doesnt work - so MB are just saving themselves an expensive warranty bill.
R
Old Sep 2, 2002 | 06:41 AM
rgleason's Avatar
C240 2002
Relatively simple question!
R
Richard, can you simplify something for me? If someone gets a Motorola Timeport phone installed in a 2002 C240 Mercedes, can he or she upgrade to a V60 by simply changing the phone cradle and the phone or do the phone controllers also need to be changed? Thanks!
Old Sep 2, 2002 | 08:58 AM
Richard's Avatar
Im not familiar enough with US phones to answer this - Im in the UK.
In the UK we always need a new control unit for the new phones (and occasionally a new cradle) - MB have said a couple of times that the controller will work with the next N generations of phones, but they never do and you need a new controller ...
- I imagine same is true in the USA
R
Old Sep 2, 2002 | 10:18 AM
300ce
.........Richard is right. So long as the Command unit or MB head unit supports D2B, you can install a V60 phone. The BIGGEST problem is that, contrary to what you might think, in the USA the last person to go to for info about your mB is the dealer. They will simply say........IMPOSIBLE!!! Anyway, I have A Euro command that and in Europe, MB uses Nokia phones not even motorolla and I was able to get a V60 installed in my car. What you need is everything distal to the D2b interface needs to be changed to support the V60 phone. The software is not difficult. Mb dealers already have software available for "approved" V60 retrofits. You need to install the software. Problem is that you need a friendly dealer and a knowledgeable technician together. This combination is almost impossible in the USA.
Ted
Old Nov 19, 2002 | 01:51 AM
oktane's Avatar
Ted,
Is the v60 retrofit possible on a 1999 CLK430? My car has the old Motorola analog phone, and I would like to retrofit a digital phone.
COMMAND was not available until MY2000 here in the US, so I have the regular radio receiver instead.
How difficult is a COMMAND retrofit (with european tv version) to perform?
Thanks.
Old Nov 20, 2002 | 06:17 AM
300ce
.........yes, it is possible to install the V60 in a 199 car. If interested, e-mail me and I will let you know where to go.
...........The European Command retrofit is not very difficult in a car that already has command. I do not think the 1999 model cars have comand. Also, if your car already has command, it may no longer be neccessary to swap to Euro command in order to get video function.
Ted
Old Nov 20, 2002 | 12:26 PM
oktane's Avatar
Ted,
I sent you both an email and a PM, as my previous email to you didn't seem to go through.
My car is a 1999, and does not have COMMAND. How easy is this to retrofit? I am good with electronics, but don't have much experience with car audio type installations.
Thanks.
