Argos D2b install help on w209
I did try to connect the tel-out tel-in to two of the different loops and it didn't work. In one case my changer stopped working. I have also checked all the fuses. They seem to be correct. I have command 2.0 unit. I am fairly mechanically inclined, but the instructions provided make me feel like an idiot.
Thanks ahead of time
The 25 pin cable is located on the right side of the trunk. You have to pull out the entire right shroud inside the trunk to access it. It ls located somewhat between the wheel well and the rear of the car. Mine was in a foam covering along with some other cables. I think there might of also have been a orange fiber cable riding along with it. Sorry I have no pictures as I have already replaced all the panels back into the car.
Sorry to hear about your troubles. I agree it is possible there could be an issue with your particular unit. I have heard some people complain about issues with the range of the unit. I would suggest trying to position the unit as close to the cabin (where your phone will be) as possible and make sure the arrow on the unit faces towards the phone (more or less).
Thanks again and good luck.
My SL on the other hand has a MB phone system and factory blue tooth, That sucker connects 100% of the time and will lock on and stay locked on 50ft from the car!
I wonder if you received a faulty unit. I would try contacting EIS directly. Their customer service is outstanding.
