Phone wiring diagram
I installed a V60 phone system in my car about 6 months ago and it never worked. I've been busy and never got around to troubleshoot. So the PSE works since i've been able to get the entire audio system working with no issues, it's just constantly saying phone not plugged in.
I tried all the fuses, and nothing. even managed to find a secondary connection behid the radio and that's plugged in as well.
Finally few weeks ago i was getting an oil change at the dealer and the mechaninc ran quick diagnostics and tells me that it's not the bluethooth puck, just a disconnect from the PSE to the cradle. Since he did it for free i did not ask him to go in any further.
So i want to take a look at the entire line going from front to the back and need to know where hte wires are running. does anyone have a diagram of the Cellphone system wiring? I'm assuming it goes in the back of the dash and then somehow makes it way to the trunk?
Any help would be appreciated.
Edit: Duh... 04 CLK 500 Coupe
Another source is phone retrofit guide but it works mostly on pre-installed cables and only shows where the connectors can be found.
I would have assumed the wiring would go directly to the rear from the centre compartment (is the cradle at the centre compartment in this car?) but there is a connector at the front so the harness must be routed from the front through the cable ducts at the side to the rear. Basically it is a direct harness between the cradle and the phone control unit.
http://www.auto-parts.spb.ru/cat/cat...97aabda7a4d9ef
I suppose fuses or relays would hinder the progress, but i don't see how since everything works and the wiring harness is not getting the signal through. i don't thing a fuse would affect that.
In this case I understand there is no physical connection from the phone cradle to the phone control unit. This should be fixed first, perhaps that would be all.
I have no idea where the problem could be. I checked the cable from front to back with a signal tester and it's dead. Nothing comes through.
There should be two connectors between the cradle and the control unit, one is at the armrest area, I believe you have installed the completer kit and the cradle wire to this connector and it should then be fine.
Another connector can be found as shown by the retrofit guide at the ashtray area. The retrofit guide suggests that this connector (along with the antenna cable connector at the same area) should be checked. I interpret it being likely that the connectors may be left open at the factory. Did you check this other connector (pair) already?
If it isn't this, then the cable must be cut somewhere. That sounds odd but your options are either to follow the cable or feed a completely new cable.
