Sponsored by: Innova
I've spent hours searcing for OEM Sirius part#
Old Dec 11, 2010 | 10:40 AM
JoeyPuck's Avatar
CL55, E500 Wagon, and an E320
Can someone please help me . . . I've been searching all the forums for the OEM Sirius part number for my '05 E500 wagon (w/command) and can't find it in any of the posts. I would like to pick up a used unit but have had no luck in obtaining the part number for this car; dealer's here in NY seem to share a secret oath of silence about disclosing this info!
Old Dec 11, 2010 | 12:02 PM
AreL11's Avatar
2006 E55 AMG
I have all the part numbers somewhere. I will send them to you if I can find them on my laptop. I warn you, though. If you're not pre-wired for it, it's gonna cost $$$$. I never did it on my 2006 e55. The total was around $1400.
Old Dec 11, 2010 | 12:53 PM
JoeyPuck's Avatar
That would be awesome, thanks! I wanted to make sure so I pulled the rhs panel located in the rear, removed the Harmon Kardon sub and there she was - pre-wired and ready to go. Thanks again, especially for answering so quickly... I'll keep a look out for your email with the data.
Old Dec 14, 2010 | 08:13 PM
AreL11's Avatar
2006 E55 AMG
B6 783 00 69 SDAR assembly kit 1
B6 783 00 89 SDAR wiring harness 1
B6 783 00 91 SDAR-MOST wiring harness 1
B6 783 00 60 SDAR receiver 1
B6 783 00 93 SDAR antenna line 1
B6 783 00 80 SDAR antenna, black 9040 As required
B6 783 00 81 SDAR antenna, cubanite silver 9723 As required
B6 783 00 82 SDAR antenna, iridium silver 9775 As required
B6 783 00 83 SDAR antenna, alabaster white 9960 As required
B6 783 00 84 SDAR antenna, primed As required
Old Dec 15, 2010 | 12:39 AM
DHMB's Avatar
Sirius Receiver
I have a receiver for sale if you are interested
Old Dec 15, 2010 | 03:15 AM
JonMBZ's Avatar
06 C55, 09 E350
Here
File Type: pdf
Old Dec 15, 2010 | 02:54 PM
JoeyPuck's Avatar
Thanks for all the help. I def appreciate it
Old Dec 15, 2010 | 03:01 PM
JoeyPuck's Avatar
DHMB - I'm interested in the receiver; send me an e-mail or a pm and let me know the info. thanks
Old Dec 23, 2010 | 04:00 AM
AMGPilot's Avatar
2004 E55
you need a B6 783 0085 which I have for sale. ($300) The expensive part is the factory antenna. You can use a generic Sirius antenna Like this one. The wiring is already there, same for the most fibers. after you install it you will need to have the Audio Gateway STAR Coded to "SDAR Present"
Old Dec 23, 2010 | 11:55 AM
t-bone's Avatar
2004 E55
Just find a good place to hide the antenna, but still get good reception. You don't want an ugly wart on your car.
Old Dec 28, 2010 | 02:32 PM
Daycruiser's Avatar
2007 W211 Bluetec
After you install the SDAR I would like to know if you experiance the 35 channel Sirius dropout problem that most other SDARs prior to '09 seem to be afflicted with. If you don't know which Sirius channels are affected let me know, they are posted on the other MB board. Geof
