ECU tuning advice
Was just wondering what kinda ecu upgrade you guys are running? I was looking into kleeman and renntech. Brabus I dont think had one for the c204. Im looking for quality and also obviously increase in toqrue/hp. I would appreciate any input. Thanks
The best bang for the buck is a Sprint Booster for $300. It just remaps the throttle response and gives you the feeling of being faster. Had one in my Boxster and it felt like entire different car.
Those companies listed above do have ecu tuning options for forced inducted engines and the gains are very good
With the 350 the major difference is the throttle response as compared to the factory. It makes a huge difference!
http://www.renntechmercedes.com/www/node/202
http://oetuning.com/products/mercede...3-amg-6-3.html
We have our 63 tune and handheld tuner on sale for $850 The handheld allows you to switch between stock and tuned whenever you want easily. (dealer visits etc)
Quoting from that file: "Fitting Details
Your car uses an ECU which has 'flash' memory. The flash EPROM
inside the ECU is a hybrid and cannot be modified in the
conventional chip tuning method. Powerchip can 'flash' program
the EPROM device by interfacing with the computer's wiring
connector plugs to reprogram the chip that contains the engine's
fuel delivery, ignition timing and throttle response settings. The
ECU will need to be removed from the vehicle and sent via
overnight courier to Powerchip. We have full photo ECU removal
instructions to assist you and we will contact you after the order is
made to organise the shipping information and other details.
