was in for 60k service today...
it shifts super fast now.. hella responsive and sounds much better.
main things i got done was:
drain entire AT fluid and replace it with new fluid
7 quarts of new mobile 1 synthetic
replaced shifter bushings (with an older 300E shifter cuz its stiffer)
rotated tires
lubed up engine
replaced windshield wiper rubber insert
replaced spark plugs
stiffened up rear shocks
flushed brake fluid and replaced with new fluid
added new coolant etc
... and car came out AWESOME
-s-
yep they used the mb trans fluid... saw them put it in
i watched them work for 2 hrs right next to my car... didnt get to see how they tightened up the rear suspension but i asked them to check for stuff in the rear cuz of the clunking noises i'd get over bumps at 60-70.
heh
those r the prices for our local independant mechanic
he races 300e's and 190e's in his spare time
http://www.rc-imports.com/PhotoGalle...lotte2000.html
So, we ARE supposed to change the transmission fluid? What about the filter (if it has one)? I thought these transmissions weren't supposed to be opened. Are you sure?
-s-
if you keep reusing cooking oil over and over for years+, what does the oil look like? is it healthy as fresh oil?
its sealed only cuz theres a special tool to open it, you can buy the tool for like 15 bucks and do the whole thing your self if you know what yer doing. theres even a special dipstick that mercedes has to check the ATF fluid.
my mechanic showed me the old ATF Fluid when it was being drained (brown/black) and how the new one was suppose to look like (red)
This is a trick used by mechanics for years. Also showing the air filters and how DIRTY they are. Hahaha.
-s-
