2002 c230 dead miss
I would suspect ignition or electronics first off if it's a problem that seems to reset itself after restart. Have you checked for codes? How are the plugs and wires? Start with some basic troubleshooting steps and you can narrow down where the problem might be.
If you are leaking exhaust out the check valves that may affect back pressure which will affect how the engine runs, but in my mind I cant make that connection. In any event you need to replace the check valve or you will always have the code. Hopefully the pump still works, that is an expensive little item. Intake manifold leaks are where you run into vacuum problems.
HTH, Bob.
