battery life
Old Mar 3, 2004 | 04:42 PM
ningeve's Avatar
2000 c230 kompressor
battery life
Hello everyone,
I own a 2000 C230 Kompressor with 40,000 miles on it. This morning I couldn't start the car, the battery seemed to run out of power and it doesn't look good to me. How long will a Mercedes' battery last? What possibly consumed it? Why is its life shorter than a non-luxury car? (I've never changed the battery of my 6-year old Mitsubishi). It just broke my dream about Mercedes Benz. Do I need to change the battery? Thank you all in advance.
Old Mar 3, 2004 | 06:38 PM
redcoupe's Avatar
11 ML350
For some reason these batterys always need replaceing.
Just get a new one and call it a day.
Brian
Old Mar 3, 2004 | 08:04 PM
JimPurdy's Avatar
11 ML350W2 / 17 GLC300
Make sure you replace the battery with an OEM model. Since the battery is in the trunk (boot), there is a tube that exhausts the gas from the battery under the car. If this tube isn't connected, there is a risk of hydrogen buildup in the trunk and explosion. There was a service bulletin on this several years ago.
Old Mar 4, 2004 | 12:59 AM
henry47's Avatar
asdf
i wish i read this yesterday before i bought a new battery. haha. i noticed that little tube. where does the gas in the tube lead to? i just saw that the tube led to nowhere.
Old Mar 4, 2004 | 02:36 AM
DougandhisC280's Avatar
2008 SLK-280
I still have my original battery. It's a 1994 C280.
Old Mar 4, 2004 | 07:16 AM
GDawgC220's Avatar
'05 A4 1.8TQM6
damn Doug...that's a long time. I've had my battery replaced about 4-5 times now from Road Side.
Old Mar 10, 2004 | 12:57 PM
narci's Avatar
I just replaced my battery of 7 years. Only died cause the alternator died. Car's running like a champ.
The theory about the tube. I think it's for the OEM batteries..no way in hell would a aftermarket battery pass inspection or production if it did that. I ended up with an Interstate battery
Old Mar 11, 2004 | 03:12 PM
JimPurdy's Avatar
I would be very careful about using a battery without a vent to connect to the tube. Even batteries that are supposed to be "sealed" generate hydrogen while being charged. The hydrogen can collect in the trunk (boot) and be ignited by a spark from one of the relays that are close to the battery. There was a service bulletin and an article in the Star Magazine about several cars that exploded from this. Most batteries are designed and manufactured to be used in an open airflow area, not enclosed. I wouldn't try to save a little on the cost of a battery and risk losing the entire car - let alone the risk of life if someone were in the car.
Old Mar 11, 2004 | 05:12 PM
meanie's Avatar
Re: battery life
Originally posted by ningeve
Hello everyone,
The life of a battery is directly related to the following:
1. How many power accessories you have.
2. How the previous owner abused the battery.
3. How well YOU take care of the battery.
Your Mitsubishi probably did not have too many power accessories ( toys ).
Old Mar 12, 2004 | 11:41 AM
narci's Avatar
My C36 battery lasted 7 years.
Old Mar 12, 2004 | 11:55 AM
michakaveli's Avatar
E300
My Interstate has the vent tube as long as many others :-)
Old Mar 12, 2004 | 12:45 PM
meanie's Avatar
Yes, I average about 7 years battery life on any vehicle I've ever owned.
Amazing what abuse ( boosting, running-down, not checking water, not keeping connections clean, etc. ) will do to a battery.
Old Mar 12, 2004 | 01:22 PM
narci's Avatar
I never did anything to the batter, never boosted it nothing..not even check the water or connections clean and it lasted 7 years.
It died because my alternator crapped out on me.
Old Mar 6, 2008 | 08:35 PM
Whatstheprtnmbr's Avatar
1998 C 230
Originally Posted by ningeve
Hello everyone,
Usually about 7 years, check with voltmeter what voltage you have with it not under load, if not at least 12.5 volts might be due for a new one. Check autozone, about 89 bucks with the exchange. W
