Crraking noise everywhere!!!
Old Apr 18, 2002 | 01:56 PM
Frissen's Avatar
Porsche, Mercedes & MINI
Unhappy Crraking noise everywhere!!!
I had a creaking noise that I thought came from the suspension or engine mounts, BTW I have a '95 C220 w/50k mi. The dealer said it was the door but check the suspension and engine mounts also. They did and the noises continued. Back to the dealer, same story. Third time to the dealer and now is worse.
Under normal driving is ok, it creaks when going over speedbumps or rough streets.
Anyone experienced something like this? If I could be guided on what to do to improve this...
Old May 4, 2002 | 12:30 AM
Frissen's Avatar
Well I finally found time to check my suspension, and yes it is the suspension making creaking noises. I believe the bushings in the front arms are causing my problem. I just wonder why the dumb@$$es at the dealer could not find anything. Well I will have it fixed and report on it.
Old May 22, 2002 | 04:54 PM
greenm's Avatar
2005 ML500 SE, 2005 X5
Just another example of poor quality control. These sites have good information on how sloppy MB is getting regarding this.
http://www.mercedesproblems.com
http://www.mercedes-lemon.com
Old May 30, 2002 | 05:01 AM
J__'s Avatar
J__
2012 C200 CGI
well i have the same noises ... mostly from the front engine compartment, but mine makes the noise only after driving for 30kms or so, then wen i brake to a stop i will make the noise, at first i thought it was the brakes, but then wen i release the brakes and brake again, it wont make it anymore, but i gas it and the noises reappear. Also wen im stopped and i turn the steering wheel it makes the same noise, its pissing me off. I thought MB was suppose to be reliable!
Old May 30, 2002 | 08:31 PM
Matt H's Avatar
'96 C220
I'd hardly call a 'noise' of THIS nature an issue of reliability. But, since all this talk came about, I did notice that I have a whistle/creek coming from the rear when I exit the car. Most likely a strut/shock problem unless it's a bushing or something of the type.
Old Jun 28, 2002 | 07:09 AM
My97C280Benz's Avatar
97 C280 Mercedes
Angry
ahh I am back after retirement, LOL.. I have not been on in so long. Anyway, I have had the same problem. When I start up in the morning, and turn the steering wheel I hear a power stearing whine, then some times while turning I can feel popping in the front.. its weird, and I also get some sounds from the front... "Sigh" But everything else seems to be running right.. I hope! =0)~
Damon
97 C280 96,000miles
Old Jun 28, 2002 | 09:56 AM
Matt H's Avatar
'96 C220
Popping in the front, I've noticed something sort of like that myself. I only notice it when turning very very sharply though. It's almost like the tire loose grip or something. The PS whine though, I don't know what to think. I've flushed the fluid, made sure there were no leaks, had the alignment done. I don't know what to do for it, really.
Old Jun 28, 2002 | 06:09 PM
97 C280 Mercedes
Yea
I dont know what the hell is going on to be honest, I mean - the damn thing pops like you said (the wheels losing grip) but the whole car shifts.. one of those Mercedes Quirks.... Im going to slowly start fixing things.. its just expensive! =0) thanks for replying!
Old Jun 29, 2002 | 05:25 PM
David C Klasse's Avatar
1995 C280 & 2002 CLK320 Cabrio
I had a popping noise in the front suspension, which usually occurred when turning sharply and/or on acceleration.
Over time it got worse, and the car tended to be very loose on the hwy, not tight; it took more concentration to drive in my lane.
Well it turned out to be the lower control arm bushings. $450 total @ the dealer fixed the problem right up.
BTW, this happened at 100k miles on my C280.
Good luck!
Old Jun 29, 2002 | 09:50 PM
Matt H's Avatar
'96 C220
David,
When you say that it was more difficult to drive on the highway. Are you talking about wind sheer moving you around, or just finding that the car is all over the place for some reason? I've sort of noticed the same thing. It's one of those problems that get's worse over time until you say..'there is no way I bought a car that was doing this from the get go.'
Maybe I'll replace them just for grins at 85k. Is there a visual inspection that can be done to aid in this decision?
Matt
Old Jul 1, 2002 | 11:25 PM
Hmm, not sure how to go about a visual inspection... sorry.
But yes, exactly what you describe; it's not like wind sheer, just more squirrely. It takes more attention to keep it in a lane... just doesn't feel as tight.
When I got my car back after the repair.. it was like night and day! What a difference!
Good luck... an independent mechanic would probably be a bit cheaper.
Old Jul 2, 2002 | 12:22 AM
Matt H's Avatar
'96 C220
I mean, it's no biggie, the part is like 10 bucks from the people I do business with and I agree an independant German Autowerks place would be cheaper than the dealer.
I guess I'll do it just because I'm noticing some of the same symptoms. Thanks for all your help on the forum lately. It's nice to see people posting!
