1999 C230 Kompressor W202 Vacuum Line PO410
Old May 19, 2023 | 01:37 AM
Capricornwon's Avatar
1999 Mercedes C230 Kompressor
Exclamation 1999 C230 Kompressor W202 Vacuum Line PO410
Hello, I was searching for the crankshaft sensor feeling around towards the lower back drivers side firewall and I noticed this line was disconnected and the rubber was fraile and falling apart. I'm hoping The Wizards of MBWorld can let me know where the location of this vacuum line plugs back into? I'm also getting a PO410 code on the Foxwell NT510 Elite OBD II Current Air system 'A' #1 Faulty Air pump #2 Faullty Air Bypass Valve #3 Open or short in the Air Bypass Solenoid Circuit. I have no clue where those parts are but I already replaced the damaged rubber hose line conectors. There are two 2" rubber hose at each end with a small blue air nozzle connector in the middle see attached pictures. The white vacuum line starts near the passenger side fuse box.
Passenger side fuse box where the line appears to begin.. Even with the diagram I'm not sure where it plugs back into lol
.plastic clilp over the line near the fuse box
Drivers side: White vacuum line going through top firewall railing. I placed it straight at the end just for the picture
Rubber hose connectors loose,fraile and falling apart. I know the whole engine needs cleaning.
I hope this is the cause of the code and not something more serious. Does anyone have a picture of where it connects?
Thanks in Advance
Old May 19, 2023 | 08:58 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W202 forum...
Old May 21, 2023 | 04:32 PM
RollTideW163's Avatar
2014 GL450, 2006 S500, 2003 ML350, 1996 C280 (Prev 1995 C220, 2002 CLK320, 1980 300SD Turbo)
I think that connects to the throttle body. I would have to take of my intake to see it (I have a different model than you) and I might do that in a couple weeks and try to let you know, but look around the throttle body/intake area.
Old May 22, 2023 | 01:49 AM
I felt around in back of the throttle underneath a plastic inverted cover. You can't see underneath it but you can feel there is one T-rubber connector and it feels like a insert nipple next to it. I'm not sure if it's it but I plugged it in. & reset the code. If you happen to take a look let me know Thanks for responding.
Old Nov 9, 2023 | 09:19 PM
2esky's Avatar
1999 c230 kompressor
did you end up finding where it connects to ? i’m having trouble finding where it goes as well
Old Nov 11, 2023 | 09:35 PM
Thumbs up 1999 C230 Kompressor W202 Vacuum Line PO410 location Solved
@2esky Check out the video at 1:22 it shows where it plugs in also I hope the pictures help. @RollTideW163 I found it You were right, it is in that location Thank You!
close to the back firewall on the drivers side.
Follow the white line to the blue hose connecter right under the drivers side firewall
It plugs into a round insert nipple thats under a plastic cover. You have to feel up under it with your fingers and push the hose in. Notice there's 2 hoses, insert yours into the empty plug.
File Type: avi
Old Nov 11, 2023 | 10:08 PM
1999 C230 Kompressor W202 Vacuum Line P0410
@2esky Check out the video attatched, at 1:22 it shows where it plugs into I hope this helps.
Drivers side infront of the firewall
blue plastic connector hose.
This is the Insert plug the hose goes into. You have to feel it with your fingers up under the plastic piece and push it in. Notice there are 2 hoses/plugs Insert the missing hose .
File Type: avi
Old Nov 16, 2023 | 10:15 PM
2esky's Avatar
thank you 👍
