Spacers for ASA's?
Old Apr 27, 2005 | 11:54 AM
accbenz's Avatar
2005 C230WZ
Spacers for ASA's?
I recently got a set of ASA ST4 17 x 8's all around, I haven't put them on yet, but does anyone out there have them on their 2005 C230 Sedan or know for a fact if I'm going to need spacers to put them on? Thanks.
Old Apr 27, 2005 | 03:44 PM
Blake P's Avatar
'09 A4 S Line
I can't say for certain, but information I've seen so far has said that ASA's require spacers to clear the front brake kit on sport sedans and AMG's. I think there has been some confusion about ASA fitment since non-AMG C classes did not have the big brake kit until the 230's got them with the 04.5 model. I have a buddy who bought a set of ASA's for his CLK and was assured that they would clear his brakes without a problem, but low an behold...required a 5mm spacer. The spacer (H&R hubcentric) caused vibration that he could not stand, so he was forced to get rid of the ASA's. I sure hope you have better luck.
Old Apr 27, 2005 | 03:46 PM
E320Star's Avatar
2000 E320 Sedan
what is an ASA?
Old Apr 27, 2005 | 04:01 PM
Blake P's Avatar
'09 A4 S Line
Originally Posted by E320Star
what is an ASA?
A brand of wheels. I believe the style he is talking about are replicas of the AMG IV dual spokes.
Old Apr 27, 2005 | 04:05 PM
accbenz's Avatar
2005 C230WZ
yes, ASA is a brand of wheels, and yes, they are an AMG twin spoke replica. I've seen the same as you Blake, that w/ the bbk (big brake kit for you newbies out there), that I will need either a 5mm or a 10mm spacer, but I'm trying to find out for sure before I try and install them.
Old Apr 27, 2005 | 04:46 PM
hittin160s's Avatar
2005 C230 Sport Sedan, Kompressor Engine, Brilliant Silver
Ive got 19s for my car, with a 10mm spacer for the front. Without the spacer, it clears while there is no weight on the car, then when you put the car down, thats a different story. Mine required a 10mm spacer, hub centric. I believe that they were +37 offset.
Offset has a lot to do with it.
Old Apr 27, 2005 | 08:49 PM
accbenz's Avatar
2005 C230WZ
I just had one of my tech's try and they won't fit on the bbk. The offset is 36 and the stock one's are 35, so I'm going to give it a shot w/ a 5mm spacer. I'm going to try again Friday so I'll give you guys an update and hopefully pics then.
Old Apr 27, 2005 | 09:49 PM
Blake P's Avatar
'09 A4 S Line
Make sure you've got the right size lug bolts to go with them since your stocks will be too short to accomodate the new width. Another member (not the first...not the last) just caused some major damage to his car by using bolts that were too long.
Old Apr 28, 2005 | 09:27 AM
ernster's Avatar
2016 E63s AMG
This is my problem. I bought the 10mm spaceer from H&R. But when I went to put it on it did not fit the hub. The only way that it did is when the service guy drilled out the center. I want a spacer that fits perfect. And one that will take that little shimmy out of the wheel. Any answers? please help
Old Apr 28, 2005 | 10:42 AM
ctC230K's Avatar
excites your girlfriend
for all this hassle wouldn't it just be better to buy OEM AMG rims?
Old Apr 28, 2005 | 10:46 AM
accbenz's Avatar
2005 C230WZ
if you want to give me the extra approx (at least) $1000 for this style OEM AMG's then I'd be more than happy to get them.
Old Apr 28, 2005 | 11:26 AM
Blake P's Avatar
'09 A4 S Line
FYI - TSW Bremma dual spoke AMG replicas should fit perfectly fine without spacers.
Old May 12, 2005 | 08:49 AM
accbenz's Avatar
2005 C230WZ
Just to let you guys know, I FINALLY put on my ASA's (ST4 17 x 8's). It took a while cause I needed 5mm spacers in the front and shorter lug nuts for the back. No vibration at all. The wheels look great, but they do look a bit small on the car...don't worry, I'll have pics hopefully later today. For some reason the stock wheels look a lot bigger though.
