Help with electrical/wiring/v1/install please?
Old Jun 1, 2005 | 01:41 AM
nlpamg's Avatar
Super Moderator Alumni
2019 GT3 RS, 2017 M3 30 Jahre
Hey guys, I decided to follow the threads and hardwire my v1 to the fusebox in the trunk and buy an "add-a-fuse" to plug into slot 14. The add-a-fuse came with 4 fuses--3, 5, 7.5, and 10 amps. I put the 3amp fuse in the top slot of the add-a-fuse and used the supplied wire tap (from the v1) and tapped into the red wire on the add-a-fuse. Then, I grounded the v1 thing to a bolt I saw on the top shelf of my trunk. When I turned on my car the v1 didn't work. Anyone have any suggestions as to what I'm doing wrong? What should I get? Where should I ground it? Pics are attached.
Thanks!
Attached Thumbnails Help with electrical/wiring/v1/install please?-v1.jpg   Help with electrical/wiring/v1/install please?-v4.jpg   Help with electrical/wiring/v1/install please?-v2.jpg   Help with electrical/wiring/v1/install please?-v3.jpg
Old Jun 1, 2005 | 02:08 AM
TheBossman's Avatar
04 C230K-ss
Id like to know as well cuz my curly wire is driving me crazy...so hit me up with the DIY instructions! And Id like to know more about this wiring to the trunk as well?! Thx in advance
-Geoff
Old Jun 1, 2005 | 02:24 AM
nlpamg's Avatar
ok, I am an idiot it's slot 7, it works now. I have a 3amp fuse plugged into it, should I change it to a 2 amp? thanks!
Old Jun 1, 2005 | 02:45 AM
nlpamg's Avatar
-Geoff
the curley wire would drive me crazy too... I had it installed somewhat discretely, but I had to keep the cigarette lighter door open so I finally did it this way.
I ran 25 ft. rj11 cable from the v1 all the way into the trunk, the hardest part was fishing the wire from the backseat to the trunk. then, I just bought the add a fuse and used the v1 wire tap to tap into that red cord and then just grounded it to the top (I don't know if that's right).
I learned how to do it from this post: https://mbworld.org/forums/showthrea...=radar+install
and this one: https://mbworld.org/forums/showthrea...=radar+install
Old Jun 1, 2005 | 06:55 AM
Axxis22's Avatar
beep
I am doing mine tommorrow.. I was just going to plug it into #7 and run the wires to the front. Its really a pain in the *** there is no empty spots up front.
Old Jun 1, 2005 | 10:52 AM
MB-BOB's Avatar
Admin Alumni
See Garage
You only have to run the POS wire from the trunk. You can ground the NEG wire in the dashboard fusebox.
Old Jun 1, 2005 | 10:55 AM
neilsam's Avatar
Registered User
2005 C230SS 6spd Blk/Blk, 2006 C350 SS 6spd Blk/Blk
Think i will do the same. Anyone know where to get this "Add-a-fuse"?
Old Jun 1, 2005 | 11:01 AM
nlpamg's Avatar
Bob, I ran a RJ11 cord from the front to the trunk, so I had to ground the NEG wire somewhere in the trunk... Is my ground sufficient? Thanks!
I got mine at Pep-Boys
Old Jun 1, 2005 | 11:53 AM
MB-BOB's Avatar
Admin Alumni
See Garage
I'm sure it is just fine. I made the suggestion, because there are not many options on how to route the wire from front to back, and it's a little easier when there is the diameter of only one wire. But if the wire you have is a two-element joined together, then no problem.
About the "add a fuse", my radar detector came with an in-line fuse holder (didn't have to buy one) and I just spliced that into the line at the dashboard fuse box as well.
Old Jun 2, 2005 | 12:10 PM
Axxis22's Avatar
beep
Theres like a thousand thread I have read on this topic and I still am confused.
We need a GOOD step-by-step install.
