C Class 20amp Power/Ground.
I am taking a long trip coming up and want to throw a ham radio in my car. However, I am having a hard time finding a power source & ground. I would love to just run directly to the battery and tap in there, but I can't seem to find a gromit that I can pass a 8 or 10guage wire through the firewall. They all seem to be out of reach.
So I ask of you all, where would I tap into for power and where would you ground?
2003 C32. The radio draws 20amp at full power, so I need a pretty large power source as to not overload the wiring in the car, tapping off someone for a light or something
Thanks,
Mike
Also, where can I get a good chassis ground on this car?
-Mike
If I don't post the info I mentioned in a few days, PM me and remind me.
-Mike
Ham rigs can kick out quite a bit of power, you wouldn't want to freak out the ECS, ABS or Air Bag controller (*BANG* surprise!).
Also try to locate your ham antenna as far away from the antennas that are located all over the vehicle. A 25-100 watt 2 meter transmitter would very nicely blow out the front end of any receiver in the immediate vicinity.
-Mike
I am still looking for a ground I can use when mounting in the car, anyone have any suggestions?
-Mike
Fuse Link:
Black A 003 545 13 01
Purple A 003 545 18 01
Terminal for above fuse link:
A 004 545 52 26
Ground loop:
A 003 545 85 40
All you need is a little wire and a 20 Amp fuse and you are ready to go! The position with the green fuse link is terminal 30.
I hope this help you out.
20 amps = 288 watts
could someone do a 30 amp fuse? Or would additional 8 guage wire need to be brought back from up from the battery? OR could one run 2 small amps (150 and 150) putting them on 2 different fuses in the fuse block? Or does it stress out the stock wiring?
