C55 AMG Brakes!
Old Jul 20, 2005 | 01:54 AM
derrick_lui's Avatar
My ex-cars: 03 E55,04 C32, 05 C55 ,03 E320
C55 AMG Brakes!
Hey guys,
Im thinking about changing my stock brakes to Brembos 4 pot 355mm brakes after summer!.
And I guess I will need to sell my C55 stock brakes.
Do any of you have any idea how much it can be sold for?
Old Jul 20, 2005 | 10:31 AM
x-tian-230k's Avatar
CLK500/Range Rover HSE/E55 AMG/Bmw 328Xi coupe/BMW 4.8x/Bmw 335i/GS350/Audi S5/E350
Originally Posted by derrick_lui
Hey guys,
Derrick,
Do they come both with front and rear brembo's? Is it the 6 piston or 4 piston. I might be interested......
Old Jul 20, 2005 | 12:10 PM
ctC230K's Avatar
excites your girlfriend
would they fit on a 2005 C230 SS?
Old Jul 20, 2005 | 01:03 PM
They should be able to. But i believe the 230K SS already has brembo's with the cross drilled rotors. Just one thing you might want to check is the offset of the front rims. Might not clear the calipers.
Old Jul 20, 2005 | 02:10 PM
are you sure regular MBs get brembos even when they are 4 pot...coz the slk350 has 4 pot and I have 4 pot ...but im pretty sure my amg brakes brake faster!
anyhow....
They should be up for sale (my brakes) when i order the brembos!
Im gonna get rid of both front rotors and calipers
Old Jul 20, 2005 | 02:35 PM
Derrick you should be able to get 450-500.00 for them.......depending on how long they have been used!
Old Jul 26, 2005 | 06:07 AM
fatkin's Avatar
W203 C200 Kompressor
AMG 4pot are from Brembo
https://mbworld.org/forums/c-class-w203/112832-brembo-caliper-look.html
Old Jul 26, 2005 | 05:27 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
if you are upgrading to Brembo GT kit be aware of the kit have thicker caliper than the C32/55 caliper. if you are only upgrading to the Brembo Sport kit there's no point because they are the same as the C32/55 brakes.
Old Jul 26, 2005 | 07:59 PM
str8clownr's Avatar
so in the 05 c230 ss it comes with brembos?
Old Jul 27, 2005 | 12:21 AM
BlackC230Coupe's Avatar
Former Vendor of MBWorld
Fast Cars!
hmm, there actually just about the same thickness as the stock AMG caliper. They even fit behind all AMG wheels with no spacers.
Old Jul 27, 2005 | 01:05 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
i dunno...my friend got the same HREs as you do made to clear the C32/55 caliper, but it didn't clear his Brembo GT and he had to put spacers on them. i'll ask him again. He might have put on the spacer because the rim was rubbing against the coilover one or the other.
Old Jul 27, 2005 | 01:11 AM
Fast Cars!
Hmm, i was looking to get the brembo GT kit and i checked the specs of the brembos and it will fit just fine behind my front. The rears are another story, it wont fit at all on my damn 4 series.
Old Jul 27, 2005 | 01:18 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
i'll see him this weekend when he bring back one of my 18s (he had blown a rear so he borrowed my rim). i'll ask him again.
Old Jul 27, 2005 | 01:26 AM
Fast Cars!
cool....
btw, u ever get the green filters?
Old Jul 27, 2005 | 01:36 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
cool....
yes i did ...i've made a tread for you too... it should be somewhere in the first or second page.
Old Jul 27, 2005 | 01:56 AM
Fast Cars!
I found it! thanks!
Old Jul 27, 2005 | 02:01 AM
CynCarvin32's Avatar
Mercedes Benz
Hey guys,
The brakes are not much different than those on 2004.5 and EARLY 2005 C230k's. Those cars have the 4 piston brakes up front but the caliper is slightly heavier. The C55 brakes are the same as C32 brakes so the rears are about in inch larger, vented, and its a twin piston not a single like on all other W203's.
I put the C32 brakes on my later production C230k daily driver after I totaly fried the stock brakes in the canyons. The car does actually stop far better than the stock kit. I would guess they are worth 400 bucks or so. But for track use they still are not enough. but then again a C230k is not that fast so i bet it would be fine. I just remember the C32 had SERIOUS brake fade when I had one.
For a car with 189 hp they are MORE than enough for serious use.
Old Jul 27, 2005 | 09:51 AM
cracker123's Avatar
05 CLK 320
How much are the AMG brakes and the rotor's , I want to upgrade by W209 brakes.
Old Jul 27, 2005 | 10:10 AM
As stated above you can probably get a used pair for 400.00 or so.... As for an upgrade from your current W209 set up it depends on which CLK you have. If you have the CLK320, it will be an upgrade. As for the CLK500, they are the same except for the drilled rotors. The calipers are the same. One says AMG and one says mercedes.....
Old Jul 28, 2005 | 09:57 PM
Moviela's Avatar
Derrick Lui said:
Thinking about replacing the C55 badge with a C230...so people will start racing with me
Use a C240 badge, the lesser horsepower will increase the embarassment of the pony car conductor (yeah, thats the right word, huh?) that tried to shut you down.
Old Nov 3, 2005 | 07:23 PM
E55Cent's Avatar
AMG 55, 335i, Mini Cooper S
Hey guys,
Have you sold the brakes yet?
PM me
