renntech pulley installed and i feel pretty good...
#76
Originally posted by young
yes, the renntech warranty is a plus for me. (one of a few)
renntech - upto 4 years for pulley and labor. labor at an approved Mercedes dealership. Renntech, very reputable company that i believe will make a good faith effort to remedy a problem should it arise.
kleemann is fine but shorter. 1 year parts and labor at an approved kleemann shop. Kleemann, very reputable company that i believe will make a good faith effort to remedy a problem should it arise.
asp... well, 1 year pulley free from defects. um, no reputation to speak of to me - good or bad. are they going to care if your car breaks down?
you see no difference in the warranties from ASP w/ the Kleemann or Renntech? if you say yes, then, again, there is nothing more to be said.
i would be happy w/ either the kleemann or the renntech - both make great products - tested and proven. but i am not comfortable w/ the ASP pulley in my car. i'm sure it is fine in yours.
#77
Originally posted by Boo2
What gets me is that Young should not feel bad about his purchase. He spent his hard earned money on a reputable product from a well known Mercedes tuner which, under conversation, would impress more people than ASP would.
btw, i'm sorry to drag this out...
#78
Lets see if we can get this thread back to something we can all get value from. Has anyone changed any of the fuel settings while using an after market pulley, any pulley?
Young I believe you went back to the default settings correct? Did the shop make any changes when they installed your ring?
If no, then we need to wait for Buells experience at his MB shop Dyno to see if there is a way to reduce the A/F ratio without chipping the car.
#79
yes, renntech recommended that the fuel setting be changed to stage 2 or 3. i'm going to the dealer this friday to get it changed to stage 2 (as well as getting the vent changed and my door seal thing replaced).
#80
#81
w203 c230K 2002
Originally posted by Buellwinkle
I don't think Young has access to a dyno so it may have to wait afterall since I seem to be doing the testing for all the pulley companies since either they don't have the info or don't want to post the results for whatever reason (like it won't be public knowledge soon).
For others interested in Fuel settings I have been running at stage 3 for several months. I also have the octain setting to 93. I don't get 33.6 mpg and I don't expect too. I get 27- 28 most of the time.
Randy
#82
Originally posted by renncpe
Lets see you have Dynoed one car with one change. That is hardly testing. I'm sure that Kleeman and I know for a fact that Renntech have run dynos in the hundreds. With changes to the ecu, air filter, pulley size, exhaust, plugs ect.
Randy
Randy
#83
w203 c230K 2002
Originally posted by Lynn
Part of the lower fuel economy can be attributed to Randy's lower rear gears.
Randy
#84
1 Post
99' SLK 230 & 01' CLK 430
#85
1 Post
I hope they see this post. Because they are "Liars" What they say about their "BIGGER KITS" is pretty true to heart, and should be if you spend 100,000.00 however for their smaller stuff, their gains are short of anything spectacular. They are simply working in on a niche market, and over charging. "For a cam/intake" like 2500? Come on now. Like I said, I have dealt with www.Oberklasse.com for quite some time. They arent known to well I guess, but they come highly recomended from Mercedes them self in Germany. YES Renntech does as well, but I want first class service like mercedes with give me, not some stuck up arrogant a$#$% that provide "Incramental" service to those with a bigger pocket book. "With Oberklasse" you could buy a key fob, and these guys would treat you like gold... Its up to you!
#86
Originally posted by linh
Then what exactly the $700 chip do? Since the fuel problem is fixed by setting it to stage 3. I'm sure you has dyno alot of car with Renntech pulley, do you mind or dare to post the hp/tq gain with A/F ratio?
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
i've been reading all the posts on the A/F ratio issue and here is sort of a summary of what i've been able to glean:
buellwinkle says (linh's slk) may be an older SLK issue b/c it uses a different ecu.
otoupalik says that there should be no a/f ratio issues w/ kleemann, renntech or carlsson that would require a "band-aid" solution of getting a chip.
otoupalik says, "If you simply put around to the grocery store and only stomp it once in a while, then 14 is not so outrageous." well, shamefully, that is me...
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
several people say that 14:1 A/F ratio isn't too bad.
bullwinkle says, "Yes, to me the A/F ratio is an issue but not a serious one..."
anyway, my conclusion is that the A/F ratio issue is not a serious one. the major manufacturers have it covered for the C-sportcoupe. by increasing the fuel quantity, changing the fuel octane rating, the A/F ratio should be even better (and so even less of an issue).
any comments?
ps what's your problem w/ renntech? that one guy's opinion is one guy's opinion. i've been treated very well by renntech. does that balance things out?
#87
You cant be everything to everybody- ever. Any tuner is bound to have an experience with a customer who somehow feels as if they got the short end of the stick. All you can do is make all the good faith efforts you can to make it right.
As for oberklasse being recommended by MBZ themselves- well you would have to be a pretty big sucker to believe that. A small Texas retailer- recommended by MBZ Germany? Dont you think there would be just a FEW guys at AMG a little ticked off? If you go to oberklasse website it looks as if they are a MKB dealer- yet if you ring up MKB in Germany they'll tell you they ARENT an authorized dealer.
Some time ago one of my friends was trying to buy MKB headers from oberklasse-- FOR MONTHS-- before he finally found out the truth from MKB Germany- sound like gold to you?
Is this indicative of oberklasse as a business? No. There is always your story, and the other sides story- the truth lies somewhere in the middle.
BTW to the best of my knowledge Randy does not work for RennTech but BRUMOS- he takes quite a bit of S*** for a guy with no direct interest in RennTech other than selling the products to those who want them at his dealership. Hes an enthusiast with a preference (therefore bias) JUST LIKE EVERYINE ELSE here!!!!
#88
1 Post
linh, i don't understand what you're saying. did you or did you not have a lean A/F ratio? what is this apology to kleemann about?
Young, i did make an apology to Kleemann because at the time i realize that the dyno shop way of recorded the A/F ratio was wrong. But last Friday i has my car dyno it again at Evosport shop and Vadim recorded the A/F ratio the same way as my last dyno shop did and the A/F ratio still show exactly the same. I question Vadim method of recording A/F ratio after the CAT. Vadim said that it does not make that much of a different. The only different is the delay of reading. Vadim also pointed out that the A/F ratio NEED to be between 12.0-13.0 !!!
Young, i did not say anything of what you what to buy, i just asked you to protect yourself by dyno your car. I'm actually helping because of my experienced.
#89
i'm still a little confused. the mercedes mechanic, and another member, said that measuring the a/f ratio as evosport does (after the cat converter) is inaccurate. vadim@evosport says it is accurate...
i can only suggest getting a second opinion dyno at another shop that will do a measurement pre-cat and see if it corresponds w/ your previous a/f ratios.
and i know you are not telling me what to buy and your experience has brought up some issues and i learned quite a lot. i thank you for that.
#90
1 Post
#91
w203 c230K 2002
This came from one of the Renntech customer...........I'll say it again. Buy what ever you want to buy but just do yourself a favor by dyno your car to protect yourself.
Randy
#92
2008 VW GTI
This time i'll ask Vadim to measure the A/F ratio before the CAT for sure. He didn't do that the last time because the welder machine was broked.
When I say "back-probing" (please, no _ _ _ _ish comments)- I mean inserting thin wires connected to the volt-meter into the back of the connector between the wire insulation and housing plastic.
#93
I asked that and Vadims's tech said they had to put in a sensor that was compatible with their dyno. They did use a tail pipe sniffer instead on Linh's car. I don't think you get that much of a difference in readings either way.
#94
Originally posted by avlis
My experience with other cars is to simply "back-probe" the O2 sensor connector to get a voltage reading. No need to weld on a O2 sensor fitting. Does the design of the MB connector prevent back-probing?
Measuring POST cat will most certainly effect the indicated AF. A cats job is to convert CO, among other things, to less harmful gases. The O2 sensor is comparing the ex stream to outside air- so if you "clean" the ex stream to nearer ambient air it appears leaner than it is. How much this method sckews results is a topic of much debate.
Any workshop manual procedure to verify mixture will always sample CO % ahead of any CAT.
#95
1 Post
That guy did not even buy anything from Renntech. He was pissed b/c he could not afford anything renntech sold for his C280. Like a rebuild or cams. ?????
#96
w203 c230K 2002
I'll take your words for it on that matter. But Renncpe, so what exactly $700 chip do when you can take care of the fuel problem by having the dealer do the setting to stage 3?
Randy
#97
1 Post
The only problem with this method is the factory sensors range. The O2 in an MBZ cannot measure a 12.5:1 AF ratio- "narrow" band O2's measure between 17:1 and 13:1.
#98
What, my car "stock" dyno show A/F ratio at 11.5 - 13.0 and the reading were measure after the CAT.
Read the post Im answering again- What Im saying is the O2 sensor IN THE CAR cannot measure a AF ratio like 12:1. If you took your car to a dyno and they used the dyno AF ratio meter it undoubtedly had a wideband O2 that CAN measure that ratio.
#99
1 Post
I understand it now. which mean i can't hook up the A/F ratio gauge to the factory O2 sensor to monitor my A/F ratio, Because it only read A/F ratio from 13.0 and up right?
