2.5" or a 3.0" exhaust?
C230K Coupe
Which exhaust piping would benefit more and which one would sound better if im going straight from the header 2.5"/3.0" straight back to the muffler.
1 Post
'06 C350 4MATIC
Exhaust Size
It may seem logical to put the largest diameter pipes on your exhaust system to improve flow. An exhaust system requires a certain amount of backpressure and flow to scavenge exhaust gases out of the cylinders.
If you ran your car with open headers (no exhaust system at all) it is as likely that you would lose horsepower because the exhaust gasses are not completely leaving the cylinders (no flow to "suck" exhaust out of the system (* or draft *).
04 C230K-ss
3" is just going to be way too loud. I had a full 3" tubro back exhaust on my vee dubs and man it was loud. Id probably laugh if I saw a benz that was screaming around when it shouldnt. Yes a sports tuned exhaust sounds good, but I can tell you a 3" exhaust is just too loud for a car like that
C230K Coupe
When i was bored one day. I ran if it off my catback, and man does it sound like a monster. After hearing that i thought i had a Z06 engine. But then when i went ot take it for a ride it was nice and meaty but once i floored it it sounded like a ****ing honda that buzzed like there was no tomorrow. One of my friends that modifys cars said i should forget the cat and run 3" pipe from headers(basically a testpipe) straight to the back with a sports muffler or anytype of muffler and it would sound mean.
Anyones feeDback?
Anyones feeDback?
1 Post
2002 C230 Coupe(M111)
Consider that the exhaust on the C230 isn't restriction, its the factory header and the cat. So, a larger pipe is just gonna deepen the sound, not make it louder, or give you more power. If you just want noise, go with the 3" and a good proven muffler. Or just do the muffler. No polished rice cans hanging at some idiot angle out the corner of the bumper.
I read German very poorly, but I read a flyer from a Koln dealer that suggested an AMG twin tailpipe could be fitted to an existing car with a 2.6 or 3.2l motor. The "kit" was a cat back system that changed the tail pipe from 60mm to 65 mm with an adapter, and it included an AMG muffler, a template to cut the notch in the rear valance, and touch-up paint for the edges of the cut out part. It also came with beefier hangers. So 65mm seems to be what AMG likes.
Judging by the fact no one has ever had measureable gains by upgrading a cat-back exhaust... size doesn't matter so much. I would recommend a 2.5" at the biggest for a C230k unless you turbo it... then who knows. I would think the intake flow is a bigger restriction than the exhaust on our cars... If MB could increase the HP rating for a "sport coupe" by simply increasing the diameter of the exhaust - they would have done it.
I'd look more to a custom/tuner header - or upgrade the intake system. (port TB, S/C, intercooler upgrade?).
C230K Coupe
1 Post
Originally Posted by DjKompressor
Well my friend. Tomorrow i will be heading to autologic. Im getting a cold air intake, new intercooler piping ready to fit my custom intercooler from spearco, and the exhaust system. I have decided to go with the 3" exhaust just to get a meatier sound, not too big on the performance of my exhaust, more concentrating on my SC and my SC. lol . I will do a dyno tomorrow from stock, to intake, exhaust, and intercooler upgrade. THen those mods and run off my testpipe cutoff. So i will have 3 runs total for you guys. I will be video taping the whole process. Hopefully i make more than 3 HP to the wheels.
I'm also interested in you results with the test pipe in place. Post your charts when youre done.
C230K Coupe
Originally Posted by Outland
If you have an M111, a simple crank pulley swap is 30-40Hp. Don't know where youre going to get a CAI, the stock setup is about as good as it gets, given the other options. I'd get a K&N drop in, and wrap some of the existing intake to reduce heat soak. The intercooler should be interesting. Previous attemps with aftermarket intercoolers have noted a significant pressure drop and poorer flow, although the temps did drop. I hope yours works out better. If you have the M271, the intercooler upgrade could make some ponies.
I went to autologic today and they are low on material to fab my CAI and intercooler piping. The exhaust they had but i want it all at once to see the dyno from stock to aftermarket stuff.
To the message up top.
-Custom CAI
-M111
-How much is a crank pulley? I know forcedinduction made himself one.
-Custom CAI
-M111
-Custom CAI
-M111
I'd need specifics, grade (guessing 304L or 316L), diameters, wall thickness...
I'm no C class expert, but 3" would be overkill unless you're turning 5000 rpms or higher on a daily basis. If you're running that high of rpms, then go for it, but I don't think you're running that high. Maybe you are.
It will kill your torque unless you're running a diesel in there. I've a 5" exhaust from the downpipe back to the tailpipe in my diesel and it roars! A diesel is a different animal and requires no scavenging backpressure.
Do let us know what difference it makes in the dyno runs.
1 Post
1 Post
-Custom CAI
-M111
-Custom CAI
-M111
M B K L A S S E
C55 ///AMG, 535xi
yeah the 3" exhaust are too loud... I was in toronto and saw a Red c coupe with gold letters and a huge ricer spoiler (duno if hes on the forums) he put a huge exhaust and it sounds so ricey, sport exhaust is goood
1 Post
2005 C230 Sedan 6spd
How about replacing your restrictive Header and cat with a Supersprint header first?
I examin the entire exhaust system when my car was jacked up the other day for oil change, and saw no "restrictions" interms of exhaust flow anywhere on the stock exhaust system. Except for the Header with Cat.
If I were you, I'll get a header and a deep tone muffler. (Remus or something)
C230K Coupe
'05 C230SS 6MT, 1966 Triumph TR4a IRS, Shelby Cobra 427 Supercharged
Originally Posted by MiKeSSw203
I think it is about 2.4 inches 60mm, but that was a quick measurement with a ruler
1 Post
C'mon folks. Think before replying.
C230K Coupe
Right...cause you saw all the way under the car, and could tell that was 3 inch piping.
1 Post
Alot of my mechanic guys tell me when i get my custom headers, testpipe, and exhaust piping is done it will sound like american muscle. Im goign to get a 3 inch tip, sorta looks like the C5 exhaust, but not dual exhaust, just one side of it. and it is basically straight piping from my custom race headers.
If you wanted an american V8 you should have bought one. An inline four is never going to sound like a V8...American Muscle...more like German Thinking.. Play to your car's strengths....the supercharger. There's no stacato firing sequence sound on a four. The music comes from the gear whine on this car, not the exhaust.
And I'd go with twin outlets on the same muffler, or dual exhausts...I'm not a fan of the fart can look. Three inch piping all the way back is gonna make it deep and throaty. Pick a muffler that emphasizes that.
Put up sound sound files when youre done.
