Painting Brake Caliper
https://mbworld.org/forums/showthrea...0&pagenumber=2
thanks
Tim
BigBadDad, could you post a pic of the rears of the ML
thanks
Tim
The rears on the ML are not that impressive. It is a much smaller caliper.
The reason the front discs are much larger than the rear discs is because under braking, the weight is shifted very far forward, so if the rear brakes operated at same rate as the fronts, the rear tires would lock up without ABS to compensate. If you got matching sized rotors front and back, the braking power would be distributed 50/50 front/rear, which may cause the rear tires to lock. You'd need an expensive brake balance controller if you want to properly adjust the ratios of the braking force. This also explains why the front discs dust so much more than the rear discs, because most of the work is done by the front brakes.
BlackC230Coupe said that there's no issue with all the dealers he talked to when it came to painting his calipers.
By the way the Red calipers could look great on any color car. They also look great with the C7 rims. It shows them off alot.
i think yellow blends with the white better than red because white and red is in contrast colors.
and there are too many cars with red brake calipers out there. so yellow is kinda special.
here is the front painted, i have pics for the rear if interested.
