HELP NEW COMAND DVD APS on W203 02/2001
Hi,
I would like to install the new Comand DVD APS on my C200 CDi year 2001.
Is possible installed it?
which adapter can I use?
where I can buy it?
![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
![devil](https://mbworld.org/forums/images/smilies/devil.gif)
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
![wall](https://mbworld.org/forums/images/smilies/banghead.gif)
2004 C32 ///AMG
Originally Posted by frankyweb
Hi,
where I can buy it?![wall](https://mbworld.org/forums/images/smilies/banghead.gif)
2015 E250D
I have done it in my car but it is very expensive. If you want to change the comand with no other additional fiber connected components such as h/k AMP, changer, teleaid, phone, voice, then you will only need the following.
1. dvd comand unit
2. bracket to hold above
3. a/c controls
4. upper switch row
5. upper and lower trim panels
6. comand dvd harness
1. dvd comand unit
3. a/c controls
4. upper switch row
Former Vendor of MBWorld
some slow@$$diesels
Originally Posted by sunman
1. dvd comand unit
3. a/c controls
4. upper switch row
3. a/c controls
4. upper switch row
Besides that you will find that if your car has PARKTRONIC or a REAR SUNSHADE you will have to do something with that as well to make it work properly again after the upper switchrow has been swapped out.
In short: CD rom comand ishould be good enough as far as functionality goes.
greetingz,
some slow@$$diesels
I search the adapter cable from ISO (old comand) to fakra (new comand aps)![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
greetingz,
thanks to everybody.
I look for this (Retrofit kit to the MCS 2)
you look at the link:
http://mbdoctor.com/shop/product_inf...products_id=67
which is the Mercedes part/number ?
I live in Italy.
I live in Italy.
some slow@$$diesels
Steve was being sarcastic. There is no original mercedes adapter.
greetingz,
Originally Posted by MBenzNL
there IS an original mercedes adapter (for those 2005 and up cars that come with radio prewiring from factory but without radio) but yes - sarcastic...that piece of 20 euro wiring doesn't make it any easier to swap to comand APS
greetingz,
greetingz,
which is the original part number?
2015 E250D
you dont have a 2005 and up car with radio prewiring. here are links to my car. http://homepage.mac.com/drsunilpatel/PhotoAlbum14.html
some slow@$$diesels
greetingz,
the 2005 radio prewired cars have the same A & B connectors as the pre 2005 cars had...
greetingz,
greetingz,
see.......
http://tech.bentleypublishers.com/se...2050%20APS.pdf
i'm seraching the same but for w203.
some slow@$$diesels
greetingz,
