New Headrest Monitors Installed
Old Oct 5, 2006 | 04:59 PM
SUNILP's Avatar
2015 E250D
Here is a sneak peak at the new headrest monitors I installed. These are from the current model ML class vehicle. These are actually mounted to the top of the seat frame and not touching the headrest. The screen articulates as well. Separate power, volume and contrast controls on each screen. Headphone jack and remote ir also. A factory MB DVD player has to be used with these monitors. The headrests have to be replaced as well as they are tapered in the rear to accomidate the monitors. The bulge you see in the seat is padding. I am still not done perfecting it.
Old Oct 5, 2006 | 05:31 PM
rlee02135's Avatar
2004 C32 ///AMG
those look pretty nice. im currently working on some too.
where did you run the power/ground wires and where did you hook up the sound to?
heres mines:
Old Oct 5, 2006 | 05:33 PM
JesLet's Avatar
2002 c 240
nice!
Old Oct 5, 2006 | 05:35 PM
SUNILP's Avatar
2015 E250D
Since I am using a OEM solution, the wireharness taps into the fuse box. Ignition on is not required on these monitors. They are CAN controlled somewhat. Atleast illumination and power is. if you have a 2005 and later C class and also have a IPOD interface, then you can get Mercedes AAS Switch (automatic audio selector)
(Power harness that directly replaces the ipod power harness)
Part no. B6-782-4228 This will allow you to use both IPOD and a aux input jack. These monitors tie into the aux in jack if you want whole car audio. Otherwise, the separate headphones.
Old Oct 6, 2006 | 03:49 AM
TruTaing's Avatar
Moderator Alumni
w203 m112
Sunman, your threads never dissappoint. Where do you get all of your info for all these MB powered mods?
Looks great.
-j0hn
Old Oct 6, 2006 | 04:07 AM
LorinserCClass's Avatar
The True OG Modded out W203
heres mines:
I used to have those on my old A4 vert back in the day They are awesome and a fraction of the cost of Alpine etc
Sunman great work as usual! I haven't been on the boards much lately so I have a 'silly' question...what are those 'snouts' on the back of the drivers/passengers seats for??
Old Oct 6, 2006 | 04:08 AM
white_w203's Avatar
is SOLD
looks good. is that ash interior by the way? also, what are those vents in the rear of the seat???
Old Oct 6, 2006 | 09:01 AM
SUNILP's Avatar
2015 E250D
Yes that is a ASH interior. Those vents are for the air conditioned seats. They are Ventilated/Heated/Orthopedic
Old Oct 6, 2006 | 10:36 AM
Sickwitit's Avatar
2015 E550 Coupe, 2012 E350 4matic Sedan, 2016 fully blown out custom camaro 2SS
Thumbs up
heres mines:
Both are very nice, Rlee what brand is your monitors I too am working on my on solution to my video/audio enhanchment's?
Old Oct 6, 2006 | 10:48 AM
WaveyKat's Avatar
Something Slow
only you suman comes up with these crazy hot mods and have people like wishing i can do the same ... but i do wanna get IMS, parktronic, Voice comand, and TV tuner and tv in motion or A/V adaptor thingie.. suman do u do Engines too or just interior mods??
Old Oct 6, 2006 | 11:47 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
who would've thought... great job sunman!
for a split second, i thought u were done modding...
Old Oct 6, 2006 | 01:04 PM
SUNILP's Avatar
2015 E250D
Done with Modding??? NEVER!
Old Oct 6, 2006 | 03:45 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
that's the spirit!
Old Oct 6, 2006 | 04:54 PM
RES's Avatar
RES
2005 C55, 1988 260E, 2000 Chevrolet Silverado
I was thinking of using the ML headrests too. but I was not sure the upwrights would fit into the c class seats. So they do fit without modifying them? And if you use the Mercedes TV tuner shouldn't there be a wiring harness that works from the tuner to the headrest monitors? I was told from MBdoctor that they have one??? Plug and play kind of thing.
Old Oct 6, 2006 | 05:13 PM
rlee02135's Avatar
2004 C32 ///AMG
im using SAVV monitors
Old Oct 6, 2006 | 05:18 PM
rlee02135's Avatar
2004 C32 ///AMG
the ML headrests will fit. i have a pair if you want them...charcoal
Old Oct 6, 2006 | 05:54 PM
phattbam's Avatar
'08 BMW e92 335i
PM me your asking on those thanks
Old Oct 6, 2006 | 08:30 PM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
personally I don't like the look of the bulky headrests (both the ML and the SAVV - W210) in the C-class
sunil, why did you go for regular ortopedic seats instead of drive dynamic?
greetingz,
Old Oct 7, 2006 | 03:35 PM
RES's Avatar
RES
I like the look of yours Steve, but never got a price for just the headrests.
Old Oct 7, 2006 | 09:37 PM
SUNILP's Avatar
2015 E250D
greetingz,
Steve,
The one reason I did go for the dynamic seats is because I did not find a suitable way of mounting the switches. after playing fiberglass for quite some time, that issue has been solved. Having a cluster that supports Dynamic seats is good too. I need to change all my air lines to a higher diameter and add a air tank. We're in business then!
Old Oct 7, 2006 | 09:38 PM
SUNILP's Avatar
2015 E250D
I personally like Steve's as well. They're a much cleaner looking monitor set. But at this price, I couldn't let it pass by.
Old Oct 8, 2006 | 09:44 AM
MBenzNL's Avatar
some slow@$$diesels
the ones I have only come as complete assemblies - headrest covers with monitors...
sunil - the DD seat switches are just hardwired switches - shouldn't be too difficult to place those elsewhere (instead on in front of the seat where they become invissible as with the E-class)
greetingz,
Old Oct 8, 2006 | 09:58 AM
benzmodz's Avatar
W203 slightly modified
greetingz,
I still think that Active Body Control is a better mod.
Old Oct 8, 2006 | 11:30 AM
SUNILP's Avatar
2015 E250D
greetingz,
Steve, THE DD switches also come along with the top larger switches that inflate bolsters/massage since the valveblock is electronic.
Old Oct 8, 2006 | 11:45 AM
RES's Avatar
RES
I want the headrest and monitors, I just dont need the TV tuner and entertainment system. Im using the I Pod video and I have the TV tumer already. I just need two of the charcoal headrest and monitors. The price I was given was on the whole system you install.
