Brake Rotors and Pads
Old Oct 26, 2006 | 11:20 AM
BIGjohnny's Avatar
/////AMG
Just curious. How often do you change your rotors and brake pads? I am required to change my brake pads roughly every 20-21,000 miles. So far I have not changed my rotors yet (car is at 52,000 miles), but am considering it once I need new brake pads. Mercedes is charging nearly $700 for new rotors, brake pads, and brake fliud (including tax and labor).
I'm considering the AMG 4 piston. Since TWS is charging $1,000 for C32 AMG brake with rotors, pads, and brake fluid (including tax and labor).
I know Drex replaces his rotors every other brake pads service. So I wanted more comparisions. Thanks for the information.
Old Oct 26, 2006 | 11:41 AM
RAULTPEREZ's Avatar
05 C230, 04 GSXR600
im having the same problem, i have to change front pads and rotors but i know the stealership is going to charge me a bunch so im trying to find some good pads and rotors but cant find much in here. yeah i did search
Old Oct 26, 2006 | 12:50 PM
mleskovar's Avatar
'17 Jaguar XF
My front Porterfield pads lasted 75K miles and could have gone another 10 or 15K. Usually I replace rotors every other time pads are replaced but with that kind of mileage I'll replace them every time. As far as cost goes....use an independent and it will be at least 1/2 as much ($100 for rotors, $120 for good pads, $130 for labor).
Old Oct 26, 2006 | 01:21 PM
nlpamg's Avatar
Super Moderator Alumni
2019 GT3 RS, 2017 M3 30 Jahre
WOW! 75k miles in So. Cal. is amazing. Since you're in HB, do you have any place that you'd recommend?
Johnny,
I'm glad I'm not the first one that'll have to change pads and rotors on the 05 and up brakes.
$1k for the AMG 4-pot isn't so bad, especially if the dealer is charging $700.
but, assuming that I'd keep my stock setup, has anyone found pads and rotors better than oem for the 05 and up 2-pot? Porterfield STILL doesn't have 2005 and up specific pads.
Old Oct 26, 2006 | 01:33 PM
mleskovar's Avatar
'17 Jaguar XF
Originally Posted by nlpamg
...do you have any place that you'd recommend?
....Porterfield STILL doesn't have 2005 and up specific pads.
I do my own work so I can't recommend. However....and don't laugh....if you have a Pep Boys with good mechanics the job is definitely within their skill range. If they have treated rotors and ceramic pads for your model I would use them. I'm very pleased with their treated rotors and ceramic pads I've installed on other cars (when I installed mine they didn't have them for the C). Pads and rotors are not rocket scientist stuff and just about any car mechanic can change them. If you don't want them to squeal or shimmy be careful how you break them in.
Old Oct 26, 2006 | 01:35 PM
kaze81's Avatar
Mercedes
I'd like to know this info too.
Btw, I was suprised that the AMG BBK is only $1K. Time for me to think about it
Old Oct 26, 2006 | 01:47 PM
nlpamg's Avatar
haha cool, thanks!
I just checked with Porterfield and got an almost instantaneous response regarding the pads:
(WENDY FROM PORTERFIELD) Yes but without wear sensor cut outs. It won't be until next year that we can furnish our material with factory steel. The price currently is $249.00
Old Oct 26, 2006 | 01:58 PM
mleskovar's Avatar
'17 Jaguar XF
Yea, my first set of pads from Porterfield didn't have the cutouts/sensor mounts or the sensor holes. I just tied the sensors back and kept an eye on the pad wear. $249!!!!! That's the most I've ever heard for street pads but still cheaper than going stock if you get the same wear I did...but that's mostly driving style and environment.
Old Oct 26, 2006 | 02:04 PM
Sauceboy01's Avatar
Blimp
So what about Rotors??
My last brake service cost me $600!!! That's ridiculous!!
Old Oct 26, 2006 | 02:37 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
I found the DIY for brakes on the more "coupe-oriented" forums and applied the same technique to my car. With a little help from friends it wasnt too bad.
You guys should give it a shot. I replaced my rear rotors when i changed my rear pads, but I didnt really need to and im at 60k+ miles. Just wanted to get hands on exp trying it out. Ive gotta get porterfields for my front pads because after changing my rear pads, my rear tires get nearly no brake dust! its sooo worth it just for the amount of time ya save on cleaning brake dust. Brake dust bad for you!
If you guys are going to replace the rotor yourself, I've gotta warn you about that darn screw they use to hold the rotor down. I swear that material is SUPER soft and your screw driver will eat it up like nothing. So be careful or have easy outs on hand Better yet, talk to the stealership to get new screws before ya do the project.
-j0hn
Old Oct 26, 2006 | 02:40 PM
MCONDE01's Avatar
2005 C230 SS
Wow! 75k miles is awesome!
I would like to know as well if anyone has found pads and rotors better than oem for the 05 and up?
Old Oct 26, 2006 | 02:45 PM
nlpamg's Avatar
-j0hn
wow, I want to replace my rear rotors just b/c I want cross-drilled ones to match the fronts...
does anyone know where I can get cross-drilleds from the 05 and up?
Old Oct 26, 2006 | 03:59 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
I bet tirerack has some for your car
Old Oct 26, 2006 | 04:50 PM
nlpamg's Avatar
nope, unfortunately all they have are Brembo BBK's...
http://www.tirerack.com/brakes/resul...5&autoModClar=
Old Oct 26, 2006 | 07:01 PM
Tony Berry's Avatar
2009 Corvette Z06
My front Porterfield pads lasted 75K miles and could have gone another 10 or 15K. $120 for good pads.
Where do you buy your pads? Does $120 cover all four front pads?
My brakes are starting to squeal a little and I even hear an occassional "grind" sound... not good. I checked my rotors and there isn't any signs of scaring, but my brake wear sensor isn't telling me it's time for brakes.
Old Oct 26, 2006 | 07:21 PM
mleskovar's Avatar
'17 Jaguar XF
$120 does cover all 4 front pads, but I bought mine from formymercedes.com and they include an install/silencer kit ($20, worth it) with the pads. Rears are $90. Be careful about the wear sensors. Depending on your year and model determines how many wheels have the sensor. My car has them on both fronts and the right rear....however....they are not on all pads, just the inside pad, and wouldn't you know it that when I checked the one wheel that didn't have a sensor the pad had only .020" remaining on the inside pad!
Old Oct 26, 2006 | 07:48 PM
razorfish228's Avatar
BLACK 05 C230SS
If you guys read one of my previous posts, I started the beta testing of Porter Pads for my car when they created the first mold for my car. I paid less because it was a project. I had to create my own holes using a Dremel and comparing it to the OEM ones. I actually got the sensor to fit properly. I can't wait till they have them made perfectly next year.
I had them for about close to 500 miles and the rears don't do that much dust. The front dust is more but much much less than OEM. I don't have to wash the wheels as much.
Old Oct 27, 2006 | 02:30 AM
SPORTCOUPE's Avatar
2003-c230K 2001-c230k sportcoupe - 1998 A190 - 2008 Smart Fortwo Brabus
Maybe this LINK does not fit here, but have a look and see what you might be getting for a little over 2k$
Old Oct 27, 2006 | 03:44 AM
c230kracer's Avatar
cl203 Sports Coupe
just making sure. can i put the drilled and slotted rotors on STOCK callipers?? i just dont want them to mess up anything. And what name brands to people prefer on rotors and brake pads?
Old Oct 27, 2006 | 05:44 AM
Moviela's Avatar
For street use, slotted rotors are OK, but you really don't want drilled rotors. The holes are useful for cooling in competition, but you don't care about how long they last. In street cars cracks develope in the disc, radiating from the holes. Mercedes feels 1 inch long cracks are OK, but if I am in the car...well, this is no place to be "on the cheap."
Old Oct 27, 2006 | 03:07 PM
Boosted5cyl's Avatar
98 Volvo V70R currently
Might try www.fcpgroton.com or eurosporttuning.com I think they both do Benz stuff ~ Good luck guys.
Old Oct 27, 2006 | 03:09 PM
http://www.racepages.com/performance...78&brandid=642
Give these a try, I know Zimm does good stuff for the Volvos and German made too ~?
Old Oct 28, 2006 | 07:55 AM
yeuchau's Avatar
Stage 2 C7 A6, QX60
just buy the parts yourself and take it to independent shop for installation, that will save you a lot money.
I would only change rotors if it's needed.
I don't know if C class requires you to change rotors everytime when changing brakes.
But for BMW 3 series, they recommand you to change rotors everytime when chaning brakes, but I didn't do that..haha
Old Oct 31, 2006 | 06:32 PM
nlpamg's Avatar
It's ironic how this post came along. Literally 4 days ago, my Brake Lights went on. I didn't have time to buy anything or look around b/c I was faaar from home and needed to drive 300 miles or so. Plus, my daily commute is in bumper to bumper traffic. I took it to the closest dealer by my office and haggled with them a bit. I got the front rotors and pads changed for $440, and my service A for $190 all with tax. Eh, it's a convenience thing I guess.
I'm probably going to order the zimmerman rotors and then have them changed with the rear pads by an independent shop in a couple months though.
Old Oct 31, 2006 | 08:34 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
25k miles between front pads. 50k miles for the front rotors (I forced about 5k mile extra on them basically you had to stand on it to stop). 50k miles for the rear pads.
