Rubbing like hell!!! Need help please!!
Old 11-01-2006, 03:30 AM
tgani's Avatar
C320 2001
Exclamation Rubbing like hell!!! Need help please!!
Hey guys, I have a problem here.. Although the fenders are already rolled to the max, my tyre(just the rear left) is rubbing like hell!!! All the sharp things inside the fenders are already cut as well. Anyone knows how to solve it? The sound is really annoying, and the thing is that I still want to lower my car a little bit..
By the way, I'm planning to buy LED Tail lights(Cl-Style) but somebody told me that the LED often went off. Do anyone who use the LED tail lights has that kind of problem?
Old 11-01-2006, 04:47 AM
Pashap5's Avatar
'05 White W203
when you say rub only on the left was that with just you in the car? cause chances are that if you have two people in the car it will rub on both sides..I was running 255's in the back with my deep dish rims and it was a constant rub...I had to take them back and settle for 245's and 9.5 is way too wide for the back fenders...i would say see if you can get 245 8.5's all around..and that way you can easily rotate them next season...
just my opinion
Old 11-01-2006, 05:19 AM
tgani's Avatar
C320 2001
I've tried to put one passenger in the front seat but the rear left tyre is the only one that rubs. When I tried to put another passenger in the back seat, the tyre was absolutely touching the fender all the time. Somebody told me that it was because the Michellin tyres were too damn rectangular(not like Toyo or Falken tyres that have round edges). i just bought the tyres and i prefer not to change the whole tyres... So, i'm looking for a way to solve it without getting new tyres..
Thanks anyway,,
Old 11-01-2006, 05:55 AM
gate1way2's Avatar
W220, W208, W203
if you allready rubbed down all the metal inside the fender, then i think your only option is to change your tire brand. I had mich's and i rubbed really bad in the driver side rear. Go with Falken, Toyo's or Nittos, and you'll be fine....
also, you might also want to check your allignment, my driver side rear was toed in really bad causing it to rub more on that side than the other.
Old 11-01-2006, 12:14 PM
tgani's Avatar
C320 2001
I see... it seems that it's the only way huh.. That's might be the case.
Old 11-01-2006, 12:52 PM
Cappa26's Avatar
A box on 4 wheels
I went 265 in the rear, no rubbing in the rear with Kuhmo.
Old 11-01-2006, 02:01 PM
C230SportsCoupe's Avatar
19"x9.5" 265/30/19 Falken FK451 - no rubbing.
Just roll the fender. It costs $100 to do, isn't noticable (ie dealer, next buyer would never know) and will solve your problem.
Old 11-01-2006, 02:14 PM
Sauceboy01's Avatar
Blimp
where do you get your fenders rolled for $100?
Old 11-01-2006, 03:01 PM
Pashap5's Avatar
'05 White W203
I was using Pirelli P-Zero's in 255..and they rubbed..i also wonder where you could get your fenders rolled..when i was feeling mine..there really seemed to be no more room
Old 11-01-2006, 03:04 PM
rlee02135's Avatar
2004 C32 ///AMG
you can rent a fender roller for $50
Pashap5's Avatar
'05 White W203
C230SportsCoupe...were you also a member of csportcoupe.com a while back..just wondering..your avatar seemed familiar..i used to be on that site when i had my Coupe..
Old 11-01-2006, 03:35 PM
I'm sure you'd recognize my car if I posted a pic of it, yet I prefer to still post on csportcoupe.com yet its been renamed, PM a mod (drex) for the new site address since they frown on posting it publically.
Old 11-01-2006, 03:36 PM
$80 here. Car on lift, remove 4 wheels, attach roller, roll fender, put wheels back on. 1-2 hrs labour tops.
Old 11-01-2006, 03:40 PM
Pre-emptive's Avatar
Kleemann CLK 43K
I would say switch the rear tires to Toyo T1-R. Are you using your stock shocks? Bilstein sport has higher compression damping than stock or Koni and should help the situation also.
Old 11-01-2006, 04:06 PM
You guys are all silly. Replace $600+ of tires or just roll the fenders for $100. Doesn't take a rocket scientist to figure out which way to go.
Old 11-01-2006, 04:48 PM
Belle the Benz's Avatar
2005 C320 -Sports package - black / black
I run the Michelin pilot PS2's with 19x9.5 in the rear and also had a problem with the tire rubbing on the left side. I personally cut all the sharp areas off the inside of the fender as well and it still rubbed. I ended up taking my wheels back to I-Forged and had them shave 1/4 inch off the back pad to suck the wheels in more. Now there is no rubbing even with the car loaded with 5 people.
Old 11-01-2006, 05:13 PM
anthuny85's Avatar
06 c230 v6 SS
i think H&R springs are notorious for uneven rear drops, my civic was lowered more on the rear left and ive noticed this too on my benz now, the rear right sits higher and the rear left looks more tucked. so im guessing thats why you rub, try a bigger pad to even it out like a #3.
Old 11-01-2006, 05:53 PM
Benzino's Avatar
03 c230
255's for the rear i had the same problem
Old 11-01-2006, 06:14 PM
MBworld Guru
FrankW's Avatar
white and whiter
shave the bumper where it meets the quarter panel. Most likely that's what is rubbing on your tires.
Old 11-01-2006, 06:43 PM
Sauceboy01's Avatar
Blimp
I'm slightly having this issue as well with my 15mm spacers on stock wheels, stock ride height. On the left side mostly!
So you think it's the part of the rear bumper where it meets the quarter panel?? hmm, i'll have to look.
Old 11-01-2006, 06:44 PM
rlee02135's Avatar
2004 C32 ///AMG
why would you put spacers on stock wheels?
Old 11-01-2006, 06:54 PM
BIGjohnny's Avatar
/////AMG
Your wheels' offset are incorrect, that is why you're rubbing. Rolling the fender might help, but i think our cars are already slightly rolled if you feel the fender. Unless you start rolling the fender towards the bumper, that might help.
Sauceboy01's Avatar
Blimp
Because they look amazing with 255's. Also it is part of my upcoming wheel project. I am going to be powdercoating my stock wheels a light gunmetal color to give it that OEM aftermarket look With the agressive 15mm spacers it gives it the wide feel i'm going for! I will post pictures once it's complete. Just something i thought would look great and different.
Old 11-01-2006, 07:17 PM
Pashap5's Avatar
'05 White W203
can't wait to see that powdercoating..thats gonna look sharp what color is your car?
Old 11-01-2006, 07:20 PM
Sauceboy01's Avatar
Blimp
Silver!
I Cant wait myself!
-First i need to find a shop to powdercoat my wheels.
-Then i need to figure out the slight rubbing issue on the rear left.
Quick Reply: Rubbing like hell!!! Need help please!!
