where for art thou antenna?
Old Sep 10, 2002 | 02:49 PM
christian655321's Avatar
when i turn my car off, i hear the antenna comming down, but from where does it come down from? front, back, left, right ? i cant seem to locate that sneaky thing.
Old Sep 10, 2002 | 02:54 PM
trench's Avatar
2002 C230 K
It's imbedded in the glass of the back window and doesn't move, I'm not sure what the noise your hearing is.
Regards, BT
Old Sep 10, 2002 | 02:59 PM
well, thanks, now im scared.... it sounds like a power antenna, it happens everytime i turn off the car, for about 4 seconds.
Old Sep 10, 2002 | 04:06 PM
dswildfire's Avatar
2002 C230K
it's not the antenna. do you hav power seats? if so that maybe where it's coming from. the mtors/servos for the seats. my car has that same kind of noise, but i ignore it since it doesnt sound serious.
Old Sep 10, 2002 | 04:29 PM
Boo2's Avatar
C32 AMG
I don't think that's normal either.
Old Sep 10, 2002 | 04:32 PM
no i dont have power seats, c5, c7, maunual, '03
it is definatley a small electric motor sound, but i cant tell where it is comming from. i guess i will have to take it in. no error or anything come up on the display. it made that sound since i picked the car up. every time i turn it off.
Old Sep 10, 2002 | 04:41 PM
CHATMANR's Avatar
Veteran: Navy
From: From Oxnard; living in Ocean View Hills, San Diego, CA
'01 C320 SS
It's most likely your climate system closing all outside air vents.
Old Sep 10, 2002 | 04:47 PM
MarkL's Avatar
2002 C240 6-spd (ret)
I think you're talking about the pump which returns the coolant to the reservoir when you shut off the engine. My Passat had the same type of system. Tell you the truth, I don't think I've actually watched this on my C240, but I'm pretty sure it's the same thing. Lasts for about 4-5 seconds when you shut off the car. Also, if you engage "REST" mode after you shut the car off, you'll hear the same pump until you turn off "REST".
Old Sep 10, 2002 | 07:30 PM
xc240x's Avatar
2001 C240
i'll vouch for that
Old Sep 10, 2002 | 07:40 PM
trench's Avatar
2002 C230 K
This sounds like a possibility, maybe the engine redesign is such that the noise is much louder on the '03 Coupe motors than the '02 or V6 motors.
BT
Old Sep 11, 2002 | 09:40 AM
thanks for the info guys. i feel better now.
Old Sep 11, 2002 | 11:07 AM
avlis's Avatar
2008 VW GTI
My '02 coupe makes the noise as described above. Quite noticable. I assumed it was the HVAC opening the recirc flap to 50% as noted my Mbtech208 a while back.
Old Sep 11, 2002 | 11:56 AM
woohoo, just noticed the memeber status below my name. thats going to be easy to remember sept 11....
well, everyone should have this noise if you hear it in the 02 model also, so its either the air vents closing or the pump that returns the coolant... or some unexplained Phenomena
Old Sep 11, 2002 | 02:36 PM
trench's Avatar
2002 C230 K
Ahhh...
I pretty much never use the recirc function, that explains why I don't hear the noise on my '02.
As always, a great forum for almost any question.
Cheers, BT
Old Sep 12, 2002 | 02:30 AM
a1phanumrc's Avatar
2002 C240, Comand, Blk/Blk Leather, C1, C2, K2b
It's the air system on both sides of the car opening... i once had my car apart installing my system and when you turn the power on/off they open/close.... i forget the tech name but they are the circular spinning fans, smaller version of a home air system
