Final verdict on springs? Eibach? H&R? Kleeman? Confusion reigns!
Rating: Thread Rating: 2 votes, 5.00 average.
Old Sep 11, 2002 | 09:16 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
So far I've gathered that the Kleeman springs seem good to one person who installeed them with stock shocks.
And I think they said they put sway bars too.
Do we need sway bars? I thought good springs negated that need.
The H&R "cup kit" (WTF is a "cup kit"? Are their shocks and springs with it? What kind of shocks?)
makes the car too low, and rides like crap.
Eibach....I have questions. What the opinion of those who've intalled them. Did they buy a kit or seperate springs and shocks,
or use any existing stock components.
Other options?
I'm ready to upgrade my suspension! So much potential, but it sure sucks stock!
Old Sep 11, 2002 | 09:29 PM
shtatc's Avatar
2001 C240 6spd
I agree - I think buying springs is like choosing wheels - so many options and opinions. I would just like to change springs to start. H&R cup kit is a spring/shock set - lowers the car a little more than if you bought springs and shocks separately. Which also should not be confused with coilovers.
Companies claim various lowering values - seem like Kleemann and Eibach (Eibach manufactures the springs for Kleemann) has the least amount of lowering. That is why I am leaning towards them. Both can be used with the original shock.
I think you will get numerous opinions - you will just need to pick one that you feel will fit your needs.
Old Sep 11, 2002 | 09:47 PM
vyse's Avatar
Does anyone have camber problems with lowering? Well, especially noticeably worsened tire-wear
Old Sep 11, 2002 | 09:57 PM
Buellwinkle's Avatar
When someone figures it all out tell me. I don't want to buy tires twice as often and I don't want the rear lowered as much as the front.
Old Sep 11, 2002 | 10:12 PM
CHATMANR's Avatar
Veteran: Navy
From: From Oxnard; living in Ocean View Hills, San Diego, CA
'01 C320 SS
I have the H&R's w/19's, and I don't care much for them. The car is too low & uneven [I like a negative rake]. I killed my shocks in 4 months because of the excessive drop. I'm an Eibach Pro-Kit fan, but chose H&R's based on positive comments on another board [now defunct]. As soon as Blistein comes out with dampers, I'll be making the switch to Eibach springs. On a positive note, when I had good dampers, the car handled great!
C320 [s]
Old Sep 11, 2002 | 10:19 PM
TNat's Avatar
'02 c230 coupe
i have the pro kit, but not yet installed. To be quite honest, i really want to return it and wait for OMP to come out with a nice spring, sway bar and strut bar combo. Add a set of koni adjustables and that will be one hell of a setup.
The eibachs really look like a top notch product and you probably get the most bang for the buck, afterall, the kleemann are the same spring as the eibach, with a price tag over $100 more.
Old Sep 11, 2002 | 10:49 PM
bajaiman's Avatar
01 C200 Kompressor, 02 C32 AMG
I've got Eibach springs installed when my car was only a few days old, never gave me any problems at all even with stock shocks.....its a bit bumpier than stock but still comfortable. Lowered the car about 30mm front and back I think.
Overall I'm pretty happy with it
Old Sep 11, 2002 | 11:26 PM
Brandon @ Kleemann's Avatar
Former Vendor of MBWorld
Eibach does not manufacture our springs.
Old Sep 12, 2002 | 12:39 AM
TNat's Avatar
'02 c230 coupe
Kleemann,
Old Sep 12, 2002 | 12:42 AM
TNat's Avatar
'02 c230 coupe
(cont.) sorry, hit the submit button too soon.
If this is true, you should really talk to some of your sales reps. The one I spoke to told me this and actually used it as a sales pitch to promote your springs. When i saw the eibachs at $150 less, i jumped on them.
Old Sep 12, 2002 | 10:31 AM
W0n6_3d4n's Avatar
C200K (w204)
i had eibach with 19, it lowered ok but not low enough (at least for my taste) at the front, the back is pretty good. If u never have lowered car before, this spring will make you feel good, but after some time, i feel the car become too bouncy (well, it may have been bouncy the first day i changed to eibach), changing the spring is not enough, i recomend you to change the shocks as well.
Old Sep 12, 2002 | 11:20 AM
shtatc's Avatar
2001 C240 6spd
KLEEMANN,
Kleemann,
I guess confusion continues to reign - if I am not mistaken - I have read on this forum that Eibach did manufacture your springs...sorry to be wrong. Regardless of who manufactures your springs, I think I am leaning towards the Kleemann springs - and then wait to get the speed sensitive dampers at a later date.
Thanks for clarifying,
Scott
Old Sep 12, 2002 | 12:14 PM
QC1's Avatar
QC1
C230 Coupe
Im going to buy a set of of spring in the next couple of weeks, I was going to get a set of H&R's because they seem to lower the car the most, but since reading this Im assuming the more you lower, the need to replace shocks & struts becomes evident. So just to clarify, If I were to purchase Eibach springs, there would not need any replacement of any other parts? Also someone posted that Eibach only drops about 30mm, if this drop even noticeable? How much does the Kleemna drop and does that need any replacement of anything?
Old Sep 12, 2002 | 12:16 PM
young's Avatar
GLB 250 4matic
KLEEMANN,
Kleemann,
Scott
i don't think kleemann ever said that the SRPINGS were eibachs, just the SWAYBARS. perhaps that is the confusion.
Old Sep 12, 2002 | 12:21 PM
c230_2k2's Avatar
Alabaster White C230K Grey Int. and 2003 C32 pewter/charcoal gray
When i called H & R tech guy to ask if i need a new shock for their spring he said no...he said the spring will match the stock shocks...now its getting more confusing...cause some people say h&r are good...now its eibach....hmm..i think i better hold on this ...
Old Sep 12, 2002 | 02:55 PM
Question Yanks!
OK, since I don't have a handy dandy conversion table handy,
how much is 30mm in inches?
I agree with Beull, I mostly want the front lowered...
looks dorky now...the stock suspension tend to slosh too and fro front to back to when hitting a bump at speed...I want better control, without being too ricey. The back with C7's looks fine to me as far as heigth.
And whats a damper? Is that what limeys call shocks? :-)
So, seem the subject is still confusing.
How much is the Eibach Pro-Kit?
Not having to do major alignment work would be good....
for those of you who have yet to have an alignment,
if you don't get one under warranty during the 1st year,
yer gonna ger f'd, since one thing MBZ did to save $$ on this car was to not have any adjustments for the alignment.
The adjustment bolts need to be INSTALLED at the time of alignment. The dealer spent hours putting them in when I was having issues with pulling right....just glad those hours were on MBZ's dime!
Old Sep 12, 2002 | 03:16 PM
patronus's Avatar
2001 C240 / 6-speed
I think there is some indirect relationship between the amount the spring lowers the car and the shock's effictivenes in controlling that spring, but I think there is a better thing to measure.
More directly, the spring's spring rate (lbs/inch of travel) should have a proportional dampening device (shock absorber) to the spring rate.
According to H&R's web site, their spring rates are 25-30% stiffer than stock. According the Eibach's (Pro Kit) they are 15-20% stiffer. This probably explains why you can blow out stock shocks with H&R's and there is less chance of that with Eibach's.
Yes, the H&R's lower more, but, by definition the lower they go, the stiffer they have to be (higher spring rate) because the forces that compress the spring are the same (bumps, dips, etc.) yet the travel of the spring is less. Its simple math.
I have Eibach Pro-Kits and Koni Sports on order for my C240/6. Both are advertised to be about 20% stiffer than stock. A nice matched set.
Old Sep 12, 2002 | 04:17 PM
Patronus,
so the Eibach "Pro kit" contains, what?
Just springs?
And are their Koni's available for the coupe?
What did this $et you back?
(In US dollars...)
Old Sep 12, 2002 | 04:28 PM
tommy's Avatar
2004 Civic Si. FWD for the Win!
"Pro Kit" is their weird designation for a set of four springs. Don't ask me why they call it a kit. It's like Carrot Top; don't try to understand it, just move on with other things.
I've had Eibachs in my crx for about 4 years now. They did settle a little with time, but I beat the crap out of that car; your results may vary.
Old Sep 12, 2002 | 04:36 PM
mdp c230k's Avatar
2002 c230k
The reason your shocks go is because they hit the end of their travel too often on a very low car. If you don't lower the car too much or don't bottom out then the shocks will last. The new shock should be designed to operate in a longer travel range, not the same as stock or you will end up with another set of dead shocks. The Kleemann variable rate springs are a great idea to keep a nice ride but handle when needed, all with stock shocks!
Old Sep 12, 2002 | 04:42 PM
Prices!
So....
Can you guys give me prices (approx) on the various options?
The Eibach springs aren't variable rate?
The only way I even know about any of this stuff is from reading here.
Who sells/installs this stuff in either the Monterey Bay, or SF Bay Area (south bay)?
Old Sep 12, 2002 | 05:19 PM
Cory @ Kleemann's Avatar
You don't need a handy dandy conversion table to convert MM to inches. Here's the down low: 1 inch = 25.4 mm, therefore,
30mm=1.18 inches. now ya know!
Old Sep 12, 2002 | 07:18 PM
patronus's Avatar
2001 C240 / 6-speed
Tirerack sells Eibach, H&R and Koni (among others). That is who I have the Eibach's and Koni's on order from.
The Eibach's are $275, available now. Koni's are about $550 and available in about 3 weeks. Total of about $850.
Visit:
http://www.tirerack.com
Old Sep 12, 2002 | 08:38 PM
KWiK's Avatar
2002 C230 : 2007 C230
come on, give us a hint which manufacturer makes your springs...
Old Sep 12, 2002 | 09:31 PM
We know it's not Eibach or H&R because they don't make progressive springs. Here's some possibilities.
Sprint Springs - http://www.sprintspring.com/
Progress Springs - http://www.progressauto.com/
Suspension Techniques - http://www.belltechcorp.com/
Most likely candidates that already make progressive rate springs for the W203 -
Intrax - http://www.intraxsuspension.com/
Ultimate Springs - http://www.ultimate-suspension.com
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
