fiber optic wiring only from headunit to cd changer right?
Old Sep 14, 2002 | 06:12 AM
b4chow's Avatar
the fiber optic wiring is only from the headunit to cd changer right? i'm going to change my speakers and add a sub, i don't have to worry about the fiber optics right?
thanks
Old Sep 14, 2002 | 11:02 PM
peet's Avatar
09 C63
That's a big negative good buddy!
The fiber ring runs from head unit, to glove box for changer to trunk for phone stuff. I just ran across the phone plug in the trunk (in coupe: right rear - next to where sub goes inside the panel. There is a fiber connector and a DB25 plug). Other than those.. if you have bose, than the fiber also carries all signal to the amp which is in rear passenger wall in the coupe.
Don't know of other places - but there are probably a few more.
P
Old Sep 15, 2002 | 11:41 AM
session's Avatar
2007 VW GTI
even though the D2B fibre chain runs throughout the car, you won't have to worry about it when you add new speakers and a sub so long as you change your head unit as well. you'll have to lay new cable, though and your fibre steering wheel controls won't work.
Old Sep 15, 2002 | 04:30 PM
b4chow's Avatar
i'm not gonna change the headunit. just add front components and rear coaxials, and then a 12 inch sub. am i gonna have any problems wiring this car than any other car?
Old Sep 15, 2002 | 05:59 PM
schwarz c230's Avatar
C- 230 Kompressor,C2,C7,Black,JL sub,A/D/S/ amps,Alpine hu and changer
The hu does not have enough power to drive good speakers, you can use line level converters, and power everthing from a seperate amps, one for the speakers, one for the sub.
Old Sep 15, 2002 | 06:13 PM
b4chow's Avatar
yea i'm getting two seperate amps, one for speakers the other for the sub.
Old Sep 15, 2002 | 08:30 PM
hokusbenz's Avatar
c230 Coupe
i hear the impedance is funny on the stock speakers so you cant use aftermarket ones
Old Sep 15, 2002 | 11:05 PM
session's Avatar
2007 VW GTI
only for the bose system.
Old Sep 15, 2002 | 11:11 PM
only on the Bose I think it is 2.2 ohm, the stock system is 4ohm, thats what they say on the back, they are in my garage, if I had it to do over again, I think I would keep the stock rear door speakers to see how it sounds, because whatever you replace it with will be muffeled by the seats.
Old Sep 15, 2002 | 11:17 PM
b4chow's Avatar
what does this mean? should i still change my speakers and add a sub?
Old Sep 15, 2002 | 11:33 PM
bajaiman's Avatar
01 C200 Kompressor, 02 C32 AMG
Yeah you should be able to change all the speakers + subs + amps without any fuss, I've replaced all stocks speakers and add a pair of 10" subs with 2 amps and never had any problems so far
Old Sep 15, 2002 | 11:44 PM
I would change all of your speakers if you have the Bose system,front components if you have the stock system
Old Sep 16, 2002 | 01:01 AM
session's Avatar
2007 VW GTI
where'd you mount your subs? the trunk is kind of small for two boxes or a large box, innit?
Old Sep 16, 2002 | 01:35 AM
bajaiman's Avatar
Well…I bought a pre-made sub box that’ll fit 2 10” subs and they fit just fine at the back. The sub box is not fixed in one place this way I can remove the sub whenever I need some space at the back.
