DIY: W203 Sedan Headlights Removal
I just bought a pair of DEPO from eBay and want to install. Before installing it, I plugged them in to test it out. The low beam light up. But the high beam don't work at all. Is it because the "Xenon = not present" setting that need to be changed by dealer?
Can I use the OBD2 cable to change it myself?
So here it is. Makes it a lot easier when you're on your back.
