Sunroof maintenance
Old Feb 24, 2007 | 12:05 PM
RES's Avatar
RES
2005 C55, 1988 260E, 2000 Chevrolet Silverado
Thumbs up Sunroof maintenance
I was having a little issues with my sunroof so I did a little checking and found out its a good idea to lube it regularly. My problem was when I would hit the express close function it would get about 1/3 closed and go back to open. I thought I had a big problem. Then when i had it in my shop under the lights and watching it I could see what ti was doing. It would start binding while trying to move. I cleaned the tracks of dirt and muck, and lubed them with a silcone spray I like to use. Works like a champ. I didn't have as much of an issue with my W124, but I believe this car is a little more sensitive. I usually lube my latches and door seals with this same lube because it works well with plastics and rubber. I do this on every detail cleaning, about four or five times a year when I do the extensive vacume and clean all the door jambs, that kind of stuff. I thought i would share incase anyone else is expierencing any problems.
Old Feb 24, 2007 | 12:12 PM
Untouchable08's Avatar
2005 C230
I had the same problem i had to hold the button for it to close.
Old Feb 24, 2007 | 02:24 PM
c230K415's Avatar
AMG GTS
Thank you very much Russell Stevens, you have solved my hair-ripping problem for the past 2 months. haha. I thought it'd be some "defected senor" or something the stealership would charge me 2g's to change or something.
Just wondering, what kind of silicone spray do you use? I only have WD-40...but I heard that doesn't work out too well for these situations (door jams, tracks, etc).
Old Feb 24, 2007 | 07:53 PM
RES's Avatar
RES
Gunk makes a silcone spray for like $3.50-$4.00 for big can. Should be able to get it at the parts store. I use this on all the seals and latches. Same thing, I thought oh crap here comes the issues. But it went away with one shot to each side. Just hit the silver rail on each side, I made sure to hit inside the grove to.
Old Feb 24, 2007 | 10:19 PM
jan ken po's Avatar
'05 SS Brillant Silver
Man thanks a bunch....Mine started doing this about 2-3 months ago. Just haven't taken it in because A) Its winter and B) didn't want get the run around at the dealer. Definitely will try this in the morning.
Old Feb 24, 2007 | 11:16 PM
dnlow's Avatar
2005 c230k
I also had the same problem but the dealer changed the entire sunroof control panel. They said they could not just change the switch. I also looked to see if it was binding but I noticed none. I am just saying this because not eveyone that stated thery had the same problem may be having binding issues. I have also heard the switches on those sunroof control modules are pretty problematic.
Old Feb 25, 2007 | 07:02 PM
MiKeSSw203's Avatar
From: South Coast Metro/Cerritos/Yorba Linda California
'05 C230K '10 GLK350 '13 SMART
Good write up had the same problem just too lazy to take it in. Fixed it this afternoon. Thanks!
Old Feb 25, 2007 | 07:16 PM
BlackLiquorish8's Avatar
C3Twon AWD Jumpofffff
ya my sunroof did the same thing i was scared and so i brought it in the stealership but thankfully it was covered under warranty
Old Feb 25, 2007 | 08:37 PM
c230K415's Avatar
AMG GTS
Cleaned/Re-lubricated my sunroof just five minutes ago. Bought some Pyroil (forgot how to spell it) Silicone Lubricant from KRagen's for about 5 bucks...Got a slightly damp terry cloth and wiped down the tracks and stuck the edges of the towel into the tiny cracks of tracks...then started re-lubing the tracks and all...just make sure when you do this...an area with a lot of ventilation and some time for the stuff to dry...there's a huge chemical scent in my car right now...windows are down sitting in my garage with the garage door ajar.
Old Feb 26, 2007 | 11:59 AM
aecasasus's Avatar
'04 C230K SS
Clear Dry Lube is pretty good for stuff like this. Nothing will stick to it and/or create any gunk or mess. I had a problem with mine one time and it needed to be adjusted. I took it to the Dealer and they adjusted it for free (or under warranty...who knows...didn't cost me a cent). Has been working perfectly ever since!!!
Hope this helps!
Old Feb 26, 2007 | 12:05 PM
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Russell, great solution for sunroof maintenance. I may add this to the AFTERMARKET MODS / SIY stickies. I do the same as you, although I don't lube up the track rails that often. Just clean/wipe down the rails (and re-sync sunroof).
Old Feb 26, 2007 | 07:29 PM
Sanny's Avatar
06 Granite Grey c230
ok i figured out the exact spots to put the oil/lubricant. I did as Russel Stevens said and cleaned the rail and oiled it. but there are exact crucial spots. on the c230 06. when you are looking at the rail down. there is a rectangular notch where teh sunroof goes back. be sure to put lubricant inside the rectangle (both sides). Also, the sunroof was kicking back near the front where it closes. on both sides there is a contact that pushes down the wind deflector thing near the front. make sure to put lubricant here as well and life will be good. i may take a picture and do some diagramming if anyone needs it.
Old Feb 26, 2007 | 07:32 PM
drexappeal's Avatar
Originally Posted by Sanny
... i may take a picture and do some diagramming if anyone needs it...
Sanny, if you do that, make sure to post the pics up here. That way, it'll be more valuable as a sticky.
Old Feb 26, 2007 | 08:19 PM
Sanny's Avatar
ok drex sounds good. but ill wait until someone asks for it. i ithnk my directions were pretty good. so well see
Old Feb 26, 2007 | 09:09 PM
flush's Avatar
2003 C32
i'll ask - take pics!
SUNILP's Avatar
2015 E250D
If you guys and gals are interested in the factory lube, it's part number 001-989-84-51
Old Feb 26, 2007 | 10:31 PM
c230 o5's Avatar
BMW 135i
i have the same prob. with my panaroma sunroof im also take it to the dealer ship cuz its coverd
Old Mar 2, 2007 | 01:49 AM
Sanny's Avatar
im watching back to the future 2. 8 more years and our w203's will be flying! i guess it will be w207 by then.
i wish there was a way to turn down the sensitivity of the sensor that detects resistance because that is what causing us the problems with the sunroof.
Attached Thumbnails Sunroof maintenance-image_035.jpg   Sunroof maintenance-image_036.jpg   Sunroof maintenance-image_037.jpg   Sunroof maintenance-image_038.jpg   Sunroof maintenance-image_039.jpg
Old Mar 2, 2007 | 11:12 AM
RES's Avatar
RES
My old W124 could crush beer cans, this thing gets a paper cup in the way and its going back.
Old Mar 2, 2007 | 04:47 PM
Sanny's Avatar
i agree. and this is the true source of our problems. if you were drivinng the wind resistance would push it back. there has to be some way of adjusting the sensor, or dampening it.
Old Mar 2, 2007 | 07:31 PM
SUNILP's Avatar
2015 E250D
there are a few variables that can be adjusted with Star Diagnose regarding the sunroof. Same goes with windows. I remember setting up pinch guard on a w220 and even though nothing was there, it would still roll window back. I had to later disable this feature.
Old Mar 2, 2007 | 07:35 PM
drexappeal's Avatar
Mine is super sensative like that. Hmmmm...maybe I'll have that done.
Has Steve done this before, Sunman?
Old Mar 2, 2007 | 09:25 PM
SUNILP's Avatar
2015 E250D
I am not sure if Steve has done it but I am sure he can.
