braking.....
Old Sep 27, 2002 | 12:58 PM
c230_2k2's Avatar
Alabaster White C230K Grey Int. and 2003 C32 pewter/charcoal gray
braking.....
Just wondering afetr i got my car from service it feels weird...when i brake when in going 40-50 mph my steering wheel shakes from left to right...the dealer replace the esm...does it have something to do with it?
Old Sep 27, 2002 | 01:39 PM
kompress's Avatar
What's the ESM? Sorry, drawing a blank. Computer-related, right? How many miles do you have?
I would first check your tire pressures and for unusual wear (scalloping, uneven wear, etc.). One of those or a bent rim are the usual suspects.
If that don't do it, give the stealer a call! Hope that helps!
Old Sep 27, 2002 | 01:41 PM
c230_2k2's Avatar
3000 miles tires are ok...cause i just had it swapped with a new c240 of my friend ..tries got 30 miles on it
Old Sep 27, 2002 | 02:13 PM
kompress's Avatar
Who put the tires/wheels on and when? I ask because some alloy wheels will warp pretty quickly if you don't tighten properly (ie, tighten the bolts across from each other).
Old Sep 27, 2002 | 02:17 PM
c230_2k2's Avatar
i did it.
Old Sep 27, 2002 | 02:22 PM
avlis's Avatar
2008 VW GTI
Originally posted by c230_2k2
i did it.
Try it again. Loosen the lugs and retighten in a criss-cross pattern.
Old Sep 27, 2002 | 02:40 PM
peet's Avatar
09 C63
Also, if you didn't tighten bolts with torque wrench (or if you happen to be one of the 1% that can torque correctly by feel) then you may have warped the rotor or worse the hub.
I did that once - ONCE - but that $600 mistake was a solid lesson!
P
Old Sep 27, 2002 | 02:46 PM
avlis's Avatar
2008 VW GTI
You mean it was permenantly warped? Usually you can just re-tighten, right?
Old Sep 27, 2002 | 09:29 PM
xc240x's Avatar
2001 C240
in my opinion some people are two meticulous... i use an air gun for my wheels... i've never had a problem... other nuts, bolts, etc. like ones on engine parts or suspension I torque them (learned that lesson by breaking the head off a screw in my spindle), but wheels, i use air... then again, i've always had aftermarket wheels... i've never really dealt with stock wheels too often.
Old Oct 26, 2002 | 01:42 AM
antonio's Avatar
2002 C240 Classic
i have the same problem and have an appointment this week. after i dragged the service guy to drive my car, he admitted its very bad pulsation and unsafe. if the cars under warranty, like mine, they will replace all the rotors and perhaps the brake pads. don't know exactly, but i'll keep you posted when mines fixed.
Old Oct 26, 2002 | 01:54 AM
vadim's Avatar
'19 GLC 300, '19 TM3SR+
Overtorquing the lug bolts is known to be one of the major causes of warped rotors. It's permanent. Machining is not recommended nowadays. Once they get warped, replace them.
