do i have the only loud c?....
Old Mar 25, 2007 | 08:16 PM
dnasty8305's Avatar
2003 c240
anyone have any issues with their enginge sounding louder than normal?....... im getting some strange noise from where the engine right under the vents that are on the hood so that would be in the back if you pop the hood..... and when i sit in the car with it in park it sounds like i have a exhaust but i dont anyone know what this could be?...........
Old Mar 25, 2007 | 08:44 PM
dnasty8305's Avatar
2003 c240
anyone else have any similar issues?
Old Mar 25, 2007 | 11:46 PM
Blazinpin0i's Avatar
Jeepney
could be you have a hole somewhere in ur exhaust manifold? do you smell gas when u drive?
Old Mar 26, 2007 | 01:11 AM
PhilipM1's Avatar
1993 190E 2.6
have a friend rev the engine while your listening out of the car. You might have an exhaust leak? its not common for the mileage but we've all heard of enigines going bad at 8,000 miles too. so who knows.
Old Mar 26, 2007 | 01:59 AM
RUBYMARDIONO's Avatar
2014 C200 w204
Search the thread I posted sometime ago. Mine had a cracked manifold at the seam joint of the exhaust. Easy to fix, just weld it.
Old Mar 26, 2007 | 12:20 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Yes, I had this problem.
Start the engine when cold, put your hand down near where the exhaust bolts to the manifold, or manifolds.
Feeling a breeze? As in exhaust leak? Check around find out where it's leaking.
Check the bolts where the exhaust attaches to the manifold, and check the nuts on the manifold.
Mine were all loose, tightened them and solved the problem, and no more exhaust in the cab...and yes, much quieter.
Alway look for the simple things before panicking.
Cars rattle themselves loose a bit at times.
Old Mar 26, 2007 | 10:01 PM
jordanomics's Avatar
2004 c 230 komp coupe
Lightbulb
Sounds like an intake manifold crack. Had the same problem with my ML430.
Old Mar 27, 2007 | 12:18 AM
c230K415's Avatar
AMG GTS
Well for the past 2 days I have noticed that my car seems to have that extra little "shake/vibration" to it like I bolted on a aftermarket exhaust...and I saw this thread...feeling paranoid...I want to know what to do to see if have an house leak...you say check where the bolts attach the exhaust to manifold? Where exactly is the manifold and the bolts on them? Sorry . But thank you very much for the tip.
Old Mar 27, 2007 | 12:35 AM
C230Krarana's Avatar
2002 C230K, 2006 VZ800
The manifold is located on the left hand side of the engine bay (passenger)right next to the big silver supercharger. The manifold bolts are going to be bolted to the head of the engine. As in the cylinder head bolted ontop of the engine. Just be on the passangerside of the engine bay, look down and towards the engine. You will see that the super charger is blocking like a little less than half of the view of the manifold. The manifold looks long and ugly and you will see a pipe go down and disapear under the car in the engine bay. Carfull when checking the minifold after it has been started as it will get hot very quick. You might have little over 3 minutes untill the temps get hotter. only try this when just starting the car after sitting over night. As you progress through the checking of the bolts and what not then start going down the exaust pipe line untill you find the leak. Also I am not really sure if there is a valve that closes the the exaust stream for quicker engine temps in the mouring because my car sounds horribly loud in the mouring like the exaust is plugged, then gets quite after a while. Also no smell of exaust in cabin. But that my problem. Oh yeah Hello fellow MB owners, how are you all doing this nice rainy night. I know my post is long but I will introduce my self in another thread.
Old Mar 27, 2007 | 01:14 AM
c230K415's Avatar
AMG GTS
Thanks a lot...I do only get this loudness and vibration at startup's...and I guess I have been getting these symptoms lately because of the semi-cold weather...I'm guessing something to do with the exhaust is altered at cold startup...as I notice too that eventually (within 5 minutes) the vibration and extra sound goes away...difference is...even with windows closed I still do get the gasoline smell in the cabin...but it might be because I always run my fan (at the lwoest possible speed; since my windows always fog up ).
