Doing Lines...
Super Moderator
when I get home I'll check the offsets for ya. in fact, the rears have 3mm spacers, and I really don't need the spacers and can take them off at any time, but that would mean that I would need to get new lug bolts and new wheel locks for the rears and the rears wouldn't stick out as much...
One with 4 wheels
Looks nice!
The brake fluid flush is something that is included in Service B, right? I'm due for Service B in 4000 miles, and I figured instead of paying $400 for a ridiculous "inspection"+oil change+brake fluid flush, I'd just get an oil change+brake fluid flush, and have them do this mod. This would be a great upgrade for my car!
Stupid question, but the new brake lines works with any rims setup right? (I'm running stock right now.)
Thanks!
Thanks!
Super Moderator
Looks nice!
Thanks!
Thanks!
it should work with any rim setup.
Super Moderator
'09 A4 S Line
#32
2004 C32 ///AMG
although, after i machine 5mm off to make the rear 36mm, will my Stoptech BBK fit?
#34
2002 C230K, 2013 BMW 328, 2015 BMW X5
Phil;
That is an awesome mod. I am the type of person that does look inside of the wheels as I pass a modded car. BBK is one thing, but when I see SS brake lines, I know two things, this guy is serious, and no way do I want to try to pass him in a curvey.
E
E
#35
Super Moderator
I figured you'd appreciate this mod... Even though it's somewhat of a "bling" mod, it's not really one...
#37
Location: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
Just ordered the STOPTECH SS lines from K1Motorsport. $49 front / $49 rear
other brake-work to be done shortly:
hopefully all done before the May 12th Rose Bowl meet,
along with other goodies !
Carlos
Saprissa@aol.com
- CLK55 AMG rear brake kit
- PORTERFIELD R4-S pads
Carlos
Saprissa@aol.com
#38
I just got stainless steel braided lines installed on my ride. I got the Goodridge lines and the install was $159 including flush and bleed of the system. I had the ss brake lines installed on other cars that I have owned and have been happy with the feel.
#39
I have been a fan of stainless brake lines for decades. They do take the mush of the pedal of every German car I have owned. It is such a low dollar mod, anyone can do it. The effect is immediate and I feel safer when there is some metal covering the lines vs. rubber brake lines.
I do take issue with using ATE blue or gold (they are identical, and the color difference allows you to see when the old is fully flushed out.) brake fluid in W203 cars. The ABS/ESP unit on these cars is impaired if the specified fluid is not used. The intricate passages of the system require the specified fluid to work as intended.
The viscosity is double in the racing fluid @ 1400, compared to the 700 found in ATE SL.6 fluid. I am not sure if SL.6 is the same fluid as that approved by Mercedes, but the MSDS looks very close. There is also ATE SL, which is NOT the same as SL.6. ATE sells SL.6 in 500 liter containers. That indicates to me that only vehicle manufacturers are buying this size for use in new cars.
For their part Mercedes says:
"Mercedes-Benz DOT 4 brake fluid is available
in one liter (Part Number A 000 989 08 07 01)
and five liter (Part Number A 000 989 08 07 11)
containers. This is the only brake fluid recommended
by Mercedes-Benz for all applications.
This fluid is also used in the differential lock
mechanisms of the G-Class model."
I use Blue & Gold in my Porsche, and it works very well for my level of skill. I would be shy, however, to put it in my Mercedes. The ABS unit is more than I make in an hour.
#40
#43
2002 C230 coupe , NOt THE AVATAR!!
#44
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Looks nice!
Thanks!
Thanks!
#47
However, braking has been better and screeching noise has been eliminated.
