noisy belt fix
Old Jul 1, 2007 | 11:31 PM
BlackLiquorish8's Avatar
C3Twon AWD Jumpofffff
noisy belt fix
i was driving today and noticed that a belt under the hood somehwhere was making some noise. i took a can of WD40 that i found in my garage and sprayed it on all the belts and anywhere the belt will go. the noise was fixed and the engine seem to be a lot more quieter. i was careful b/c i didnt want to spray it in the alternator. the WD40 gave the belts a light shine also which will prevent the belts from cracking. anyone here also spray WD40 on there belts and pulley???
Old Jul 1, 2007 | 11:35 PM
advans's Avatar
C55 ///AMG, 535xi
ay sheldon how many miles does your car have...? I think you should change the belt.
Old Jul 1, 2007 | 11:37 PM
jmza2's Avatar
2003 C320 4-Matic
I did the exact same thing a couple of weeks back and the noise went away for a short period of time. Needless to say the noise came back. I brought it into the dealership and the idler pulley had to be replaced (under warranty).
Hopefully the sound was purely the belt but watch out for an issue with your pulley's.
Old Jul 1, 2007 | 11:49 PM
SlvrC230SS's Avatar
2006 C230SS & 2009 E350
Is it a whinning noise? It could be the idler pulley like jmza2 said. I had the same issue before.
Old Jul 2, 2007 | 12:04 AM
mleskovar's Avatar
'17 Jaguar XF
... i took a can of WD40 that i found in my garage and sprayed it on all the belts and anywhere the belt will go.
Never, never, spray/put/wipe/drip oil on rubber belts. WD40 might be harmless in light application as it disipates quickly and may even act as a cleaner with all its' solvents but I wouldn't take the chance. What was the noise...squeeling?
Old Jul 2, 2007 | 02:45 AM
Saprissa's Avatar
From: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
What ???
NEVER spray WD40 on rubber !!
Don't you know that from your adolescent bicycle days ???? geeezzz people !
Old Jul 2, 2007 | 02:47 AM
krnboy817's Avatar
c230
why not try some sprays that is actually labeled as belt dressings... i kinda agree with spraying some... specially here in tx... heat... driness... weather seems to beat down on many other rubber materials... im guessing it would do the same for the rubber made belts under the hood.
Old Jul 2, 2007 | 07:43 AM
i've got 56K
