Door pin fell into the door =/
I was replacing my stock ones (one was bent) with a set I purchased on ebay, and after I took off the stock one, the screw that goes under the pin fell into the door. Now, the door won't unlock at all. Is there any way to pull it back up? Any help would be greatly appreciated.P.S. I tried searching for this but with what I searched, nothing relevant came up.
If that doesnt work, take the door panel off. DIY link
I thought I had done the same thing when I was doing my car, but when I shined a flashlight down the hole, I could see the pin and pulled it back up with needle nose pliers.
have successfully bailed out buddies by using hemostat, soda straw, or a
sharp/pointed tool....all make this task pretty easy. note that you'll probably
need to manipulate the door switch (use your remote key) so once you center
the pin in the hole, you simply press the UNLOCK to raise the threaded rod.
https://mbworld.org/forums/c-class-w203/110908-door-pin-got-jacked.html
https://mbworld.org/forums/showthread.php?t=110908
but it actually sounds fairly simple to do. Now if only I had a flashlight and it weren't 95 degrees out... I'll post back if I have any results. Thanks again to everyone.
