misterious black box behind passenger side fog light
Old Jul 18, 2007 | 09:15 AM
rtrimarchi's Avatar
C 220 CDI SW
Hi everyone
unfortunately this morning I hit a metal bar on the highway on the way to work.
I got a 50% broken passenger side fog light and some bumps and scratches on the front lower right bumper.
Luckily I can fix the fog light plastic screw supports, but I need your help to find out what is a black box behind the passenger side fog light.....
This unknown black plastic box has a little hose attached to it which goes upward somewhere, but I also see a pink little hose with a whyte connector that I honestly have no clue where it links-attaches to.
My baby is a CDI 220 W203 european model...year 2003.
Can anybody help me out to discover what the black box and this pink hose are for ???
Thanks a lot in advance to everyone
Please... I need your help if you can ...........
Drive Safely
Ric
Old Jul 18, 2007 | 09:40 AM
C24owner's Avatar
'08 E550 4Matic
Post a pic if you can.
Old Jul 18, 2007 | 10:12 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
i don't think i've seen it b4....
Old Jul 18, 2007 | 10:46 AM
WaveyKat's Avatar
Something Slow
its probably the same black box that airplanes has in case u crash or something they can find out what went wrong
j/k never seen that before tho.
Old Jul 19, 2007 | 02:41 AM
rtrimarchi's Avatar
C 220 CDI SW
Thumbs up here are the pictures... Airplain black box
Hi guys...
Here are the pictures of the "airplain" black box
There is another hose (pink) which is not in the picture and I have no clue what it is for and where it goes....
On top of this..... this morning my baby decided not to let me drive over 2000 RPM.
Last night it was working fine and this morning ....
Can it be the "magic box" ???
Any idea is welcome.....(even the airplaine one)
Thanks again
Ric
Attached Thumbnails misterious black box behind passenger side fog light-imgp1642_low.jpg   misterious black box behind passenger side fog light-imgp1644_low.jpg   misterious black box behind passenger side fog light-imgp1645_low.jpg   misterious black box behind passenger side fog light-imgp1646_low.jpg
Old Jul 19, 2007 | 02:58 AM
Saprissa's Avatar
From: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
are you in the UK ??
if so, check with the local MB boards there, because, being a European model, no one here in the USA (except for Dr. Sunil / aka SUNMAN) will know what it is.
You may want to e-mail Sunil (motorwerks@mac.com) or Steve (www.MBenzNL.com) to see if they can identify the box in the picture.
Please let us know, when you find out. At first I thought it could have been the cabin pre-heater, but that is a gasoline (petrol) driven device, and unless that pink hose goes back to your gas tank, then I doubt that's what it is.
Carlos
Saprissa@aol.com
Old Jul 19, 2007 | 03:44 AM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
that is just a simple vacuum reservoir - nothing weird about that...
I presume that yuou found it just underneath your headlight attached to the aluminum beam and not dangling around behind the foglight?
greetingz,
Old Jul 19, 2007 | 03:56 AM
rtrimarchi's Avatar
C 220 CDI SW
Thumbs up
YES
you're right, MBenzNL.....
It was surely attached to the aluminum beam , but since the impact broke the plastic supports...it fell off.
As you see it has a white hose attached to it.....
But I also have a pink hose not shown in the picture......
Any idea where it has to be plugged ??
Also... do you think that, since I removed it teporarely, this could be the reason why my car does not run higher then 2000 RPM ???
If I am not driving, if I accelerate, RPM go up all the way I want.
If I am driving, if I accelerate, RPM wil not go higher then 2000
Can It be the cause ???
PS:
Can you tell me more about the Box..... I'd appreciate it
Huge thanks
Ric
Old Jul 19, 2007 | 07:23 AM
rtrimarchi's Avatar
C 220 CDI SW
update...
I have just been told that the pink -magenta hose is connected to the low beam light component....
Does it sound correct ??
Old Jul 19, 2007 | 08:58 AM
rtrimarchi's Avatar
C 220 CDI SW
Thumbs up
YES.....
It is correct.... I just plugged it back.
And about that black box..... MBenzNL was 100% right, and this is why the car is in allarm at the moment and does not run over 2000 RPM.
I called a MB dealer, and luckily they gave me these info.....
I am sharing it because maybe somebody (hope not) can run into the same problem I got
Always thanks to everybody
Bye from ITALY
Ric
