hit a pothole today
Old Aug 11, 2007 | 12:05 AM
BlackLiquorish8's Avatar
C3Twon AWD Jumpofffff
hit a pothole today
i hit a pothole today on the way to work, the thing was huuge i dk why those construction works dug a huuge rectangular dip. the POS in front of me had his hub cap flying down the road. i couldnt swerve because there was cars to my left and the curb was to my right. my drivers side tire now has a small bubble. the rim is ok i think. should i leave the tire the way it is??? is there anything i can do besides replacing it?
Old Aug 11, 2007 | 12:08 AM
ramenbuoy
Guest
Posts: n/a
If the tire has a bubble, I would suggest you replace it.... Anything that compromises the way the tire should be is bad. I would rather change it now then get a flat later you know?
Alex
Old Aug 11, 2007 | 12:15 AM
Saprissa's Avatar
From: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
NO
NO
Old Aug 11, 2007 | 12:47 AM
onecoolloser's Avatar
2003 C240 Classic
Originally Posted by Saprissa
NO
NO
...well said.
Old Aug 11, 2007 | 01:02 AM
Shake's Avatar
IS300
that sucks
Old Aug 11, 2007 | 01:09 AM
advans's Avatar
C55 ///AMG, 535xi
that sucks bro! on the way to dinner, i curbed a little of my front pass side rim!
just replace the tires!
Old Aug 11, 2007 | 01:18 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
good thing the rim isn't damaged...
new tire is fine...
Old Aug 11, 2007 | 11:07 AM
RES's Avatar
RES
2005 C55, 1988 260E, 2000 Chevrolet Silverado
You most likely split the cords on the tire. That usaully ends up causing a major tire failure. High speed blow out that might make you loose control. Your choice though, I would change it.
Old Aug 11, 2007 | 12:00 PM
denver303's Avatar
04 C230K
I hit a pothole at work the other day and ended up getting a pinchflat on one tire and a bubble in the other. Luckily i have free replacement for road hazards on all my tires!
Old Aug 11, 2007 | 12:11 PM
Blake P's Avatar
'09 A4 S Line
As others have said, bubbles mean the tire has been compromised and is no longer safe to drive on, so you should definitely get it replaced. I think you should change your wheels too...not because of the tire damage, though.
Old Aug 11, 2007 | 12:12 PM
Blake P's Avatar
'09 A4 S Line
Damn man...gotta be more careful now that you're riding on rubberbands!
Old Aug 11, 2007 | 12:25 PM
ctC230K's Avatar
excites your girlfriend
same thing happened to me when I hit a pothole in NYC, got two bubbles! I was just glad the wheel or axle wasn't broken because that's how hard it hit!
Scratch that I forgot the wheel WAS broken, it cracked the rim.
Old Aug 11, 2007 | 01:12 PM
benzboi3's Avatar
05 C230K SS 6MT, 00 Audi TT 180Q 5MT
ahh i hate construction roads! as for the tire, you should replace it.
Old Aug 11, 2007 | 03:07 PM
BabyBenz6spd's Avatar
2005 C230 Sedan 6spd
Is it true that you can apply for compensation with local government from tire damage for potholes in road construction areas?
Old Aug 11, 2007 | 05:17 PM
i'm gonna go ahead and get a new tire
Old Aug 11, 2007 | 06:22 PM
RES's Avatar
RES
Ask them to spin the wheel on the balancer to check for any bends or dents.
Old Aug 11, 2007 | 06:45 PM
slowrey's Avatar
2006 Mercedes C55 AMG
Two weeks ago I hit a pothole hidden under a puddle. Got out looked at the bubble on it and then drove it home. When I got home it was still a bubble. Pissed I went inside to tell my girlfriend and when we came out and I showed her, the entire tire was flat.
Took it to get the rim checked out and 2 new front tires and $600 bucks later all was well.
Be careful and check on it.
