View Poll Results: Which Grill Would Look better on the C ???
CL Grill 1
![](https://mbworld.org/forums/images/polls/bar2-l.gif)
![](https://mbworld.org/forums/images/polls/bar2.gif)
![](https://mbworld.org/forums/images/polls/bar2-r.gif)
![](https://mbworld.org/forums/clear.gif)
53
42.40%
CL Grill 2
![](https://mbworld.org/forums/images/polls/bar3-l.gif)
![](https://mbworld.org/forums/images/polls/bar3.gif)
![](https://mbworld.org/forums/images/polls/bar3-r.gif)
27
21.60%
Stock
![](https://mbworld.org/forums/images/polls/bar4-l.gif)
![](https://mbworld.org/forums/images/polls/bar4.gif)
![](https://mbworld.org/forums/images/polls/bar4-r.gif)
38
30.40%
Other
![](https://mbworld.org/forums/images/polls/bar5-l.gif)
![](https://mbworld.org/forums/images/polls/bar5.gif)
![](https://mbworld.org/forums/images/polls/bar5-r.gif)
7
5.60%
Voters: 125. You may not vote on this poll
CL-style GRILLE Discussion Thread
#651
06 c230 v6 SS
i think the pictured car is a older model 240, which is probably glacier white, i think they changed to alabaster white in 04-05. im almost positive itll match.
#653
MBworld Guru
white and whiter
Glacier white, Alabaster white, and Arctic white are all different.
Glacier white (pure white) was discontinued after 2001 because consumer feedback saying it was too white, so they replaced the color with Alabaster white which is a stone white with yellow/cream hue. Now the Arctic white is in between Glacier and Alabaster in terms of shade.
you can see the upper corner. my sister's CLK is Glacier white compare to the Arctic White.
![](https://farm4.static.flickr.com/3286/2799233722_9557440181_b.jpg)
#654
2001 C240, 2000 S430, 2002 ML320
Damn it, now im confused as hell as to what to do....any suggestions?
On a side note, i am going to get my windows tinted, and I am going legal, with 35%...however the tint guy said that he applies a 50% tint film, and it darkens after being put on, and then it clocks in at 32-25% on the tint meter....is this how it always works? I don't want him to rip me off and give me a really light tint. Thanks.
#655
i would contact the seller and see how close they can tell you the match is to your white. Maybe they carry the different shades. You never know..
good luck!!
good luck!!
#656
ML320 E53 C230 E92 E82 E90 F10 Macan S
CL Grille
Hi Guys,
Need some advice of where should i buy my CL Grill for my C230. Im leaning to get the 3 fin. Ive read in some posts that i should get the longer latch to avoid problem when dealer opens the hood but i have no idea of where to get this from...thanks for any info...
#657
My first CL style that I bought on ebay came with the longer latch. The next grille I bought after the deer collision, did not come with the latch- but it turns out, that's because the stock shorter piece was the correct one to use.
#658
2006 MB C230 Iridium Silver, 2007 Hummer H3 Slate Blue
My CL grill came with the longer latch. More than likely the one you get will come with it also.
#661
#663
does anyone know how i can remove my rear tail lights AND side mirror blinkers for tinting? I tried to STFF, but everything was either a dead link or a no go....thanks.
#664
rear tails u need to pull the back carpet back
remove all the square pins, there should be over 10.
and find four bolts with nuts holding each light in
Should take ten minutes. Save those clips!
DOnt know about the turd signals
#665
are there any pics of this? I cant seem to do this....im confused, will just the red plastic cover part of my tail light come off, or the whole tail light unit?
Thanks.
Thanks.
#666
I wanted to smoke my tails out using VHT Nite Shades....which clear coat should I use, everything i looked at isnt ment for plastic...which is what all my stuff is.
I bought some clear Dupli Color Acrylic Enamel...but the guy said it will ONLY protect the paint...not give it gloss, any suggestions?
Do I got the right stuff, or shuld i get something else?
#668
#674
Interested in what you guys think about this grille/price!!!
