M271 2003-2005 C230 guys go to the dealer now free work/recall
Old Mar 3, 2015 | 07:07 PM
  #276
RobKellz's Avatar
2005 C230 Kompressor
I am going in tomorrow to get the recall done. I hope that no other new problems arise. Right now I'm getting some surge at idle intermittently and I'm leaning towards it being the harness because I've already changed out the MAF, idler pulley, and airbox hose.
Old Mar 4, 2015 | 02:15 PM
  #277
jrdanny's Avatar
C230 Compressor
Hey, thanks for the advice...I will follow up with them ref camshaft accuator..
Old Mar 8, 2015 | 02:53 PM
  #278
roxythettopfoxy's Avatar
c230
Smile How long does this recall last?
Hey guys,
Brand new to the forum..learning about my 2003 c230k. This is an awesome site. I had a couple questions after reading the thread. I do realize that its pretty old. Both the thread and the car! I noticed the thread hasn't been updated since 08.. Main question: seeing as though the recall may have already been performed, (I did see someone say the hose was replaced 4 times) is this something that can can/will still be honored. Also I have been searching for info about my sunroof (wont open) and more info about the cam sensor harness. The check engine light just came on, and is idling slightly rough... 153k on the odometer.
Old Mar 10, 2015 | 04:43 PM
  #279
Norsk_Johnson's Avatar
2005 C230K SS 6MT
Had this done to my car two weeks ago. If it's the leaking Solenoids, they'll just add two wiring harness adapters to prevent the leaking oil from negatively effecting the CPU. If it has caused any damage, I'm sure they'll replace at no cost. Guess I was lucky.
I tried to see if they would do my breather hose as well, but they indicated it was already done by the previous owner in 2009. Just in case, I bought a new hose. Apparently this little bugger has a short lifespan - guess we'll see.
Ps - This site is the best!
Old Mar 24, 2015 | 12:39 AM
  #280
kipthejeweler's Avatar
2003 c230, 1997 e420
quick question my car...2003 c230k coupe is in an independent shop for a belt replacement, it has 157k miles on it, can i take it for the recall?
Old May 15, 2015 | 08:02 AM
  #281
AMGDW's Avatar
w203 c200k
Does anyone know if the recall service is available in Australia
Old May 15, 2015 | 12:41 PM
  #282
Icebreaker's Avatar
2024 E 350
If it hasn't been done you should at least call the service department of your local dealer and ask if there are any "Open Campaign" for your VIN number...
This reply is for both kithejeweler and AMGDW
Old May 15, 2015 | 12:56 PM
  #283
Icebreaker's Avatar
2024 E 350
If it's already been done then I don't believe they will do it again.
As for your other questions you need to be more detailed and not just state "my sunroof won't open". Does it make a noise when you depress the switch, is it stuck in any position, does it tilt up?
Old May 18, 2015 | 06:22 PM
  #284
AMGDW's Avatar
w203 c200k
Ok so I have called up and checked m271 engines in Australia do not need a recall as they said the engine specs are slightly different and if it there was a engine problem they will contact you ( apparently they have access to gov files that tells them who owns a Merc even of you are the 5th owner )
Old May 29, 2015 | 07:14 AM
  #285
LourensL's Avatar
2005 C180K
Originally Posted by roxythettopfoxy
Hey guys,
Some of the recalls `never expire` so they should honor it. Unless of course you find yourself in South Africa, like me. When you ask MB about recall here they simply have no idea what you mean. Tried to get the little pigtails done - nada. The just put a little barcode sticker in my fuel cap. That was the only open campaign.
Old Oct 19, 2015 | 04:00 AM
  #286
mjc1's Avatar
Car
Does anyone know if this recall was for the c203 model only?, I have a m271 engine in my c180 auto 2004 which looks like it needs this same hose replacing, if somebody could confirm if its for all the m271 engines I would be grateful.
Old Jul 23, 2016 | 01:22 AM
  #287
jtwillia2's Avatar
2005 C230K
I had some issues recently which I assumed were from the famous $12 hose or similar ones that were replaced in the recall, but after removing the airbox I realized I had a couple small cracks in 2 small hoses going to the evap regeneration valve (green bottle thing). I have not seen anyone else on here talk about these hoses, so I'm including some pictures in case anyone else sees this. Part numbers are:
2034767226
1200780381
Attached Thumbnails M271 2003-2005 C230 guys go to the dealer now free work/recall-img_4946.jpg   M271 2003-2005 C230 guys go to the dealer now free work/recall-img_4947.jpg   M271 2003-2005 C230 guys go to the dealer now free work/recall-img_4948.jpg
Old Sep 3, 2016 | 12:39 AM
  #288
dboyrusky's Avatar
2019 GLC300 4matic, 2019 C300 4matic, 2018 C300 4matic, 2009 C300 Flex, 2004 C230 Kompressor
Own a 2004 c230ss, was told by the dealer currently there is no recalls or open campaigns for this car unfortunately.
Old Dec 5, 2017 | 11:33 PM
  #289
drb930's Avatar
2005 C230 Sport Coupe
Any updates on campaign number 2008020002?
Old Oct 15, 2018 | 06:52 PM
  #290
Yehseg's Avatar
C230
Which countries?
Old Aug 8, 2019 | 02:25 AM
  #291
Shawn Smith's Avatar
2003 c230 kompressor
Originally Posted by mctwin2kman
Just got the call from my dealer. Car started idling rough just yesterday. Out of warranty so I am very happy that I got that call. Funny that it just started this yesterday. Car ran fine before lunch and after lunch on the way back to work, then when I got to work and went to park the idle was crap.....
So did anyone figure out if this has a time limit on it? I got my 03 c230k a year and a half ago and just seen this. I know there is an issue with the hose. Any info?
Old Nov 28, 2019 | 04:46 PM
  #292
cgshawaii's Avatar
1998 C280
It ain't rocket science... if you want to know if your local will do it, USE YOUR TELEPHONE. Have the VIN ready.
Old Jan 17, 2020 | 07:58 AM
  #293
Kheichert's Avatar
2004 C230k 2dr
I bought my 2004 c230 recently and was wondering how I would know if this work has been done on it? anyone still have their car and want to take a picture of the hoses?
Old Jul 15, 2020 | 08:05 AM
  #294
slammer111's Avatar
2003 C230K Coupe Orion Blue
2034767226
1200780381
Can you be more specific on the issues at the time? Wondering if I'm having the same problem. Also, were you able to find the root cause?
I also found my 7226 hose cracked and will be replacing it. The 0381 one is fine though. Thanks for the heads up.
The other side of the regeneration valve also uses the same 7226 hose (but with no hose clamps), interesting enough. Just checked the one on my car and it's also fine.
Short of contacting the dealer with your VIN, I guess one way to tell is to check and see if your $12 hose is made of the newer material. See post #7.
Old Jan 22, 2021 | 07:41 PM
  #295
Mircea Chirila's Avatar
C180 Kompressor "Sports" Coupe
How come only in the US you can these recalls and have your card fixed for free? In the UK there is not such thing. I don't have any issues yet with the hose, but I had with the cam solenoids leaking oil and the dealership had no idea about any recalls.
Old Mar 12, 2021 | 08:47 AM
  #296
slammer111's Avatar
M271 crankcase breather hose and check valve DIY
If anyone is out of warranty and needs this job done, see this thread for DIY instructions. Start at post #22.
Old Mar 17, 2021 | 09:15 AM
  #297
Filmmaker2020's Avatar
C320 4-Matic
Hello,
Are they doing this for the c320 too. Im new to al this, so I don't know what motor I have, I think its the M112, as its a 2005 C320 4-matic.
Old Mar 19, 2021 | 07:21 AM
  #298
slammer111's Avatar
Originally Posted by Filmmaker2020
Hello,
Doesn't apply to the C320. With that said, you can always give your VIN to the local dealer to see if any other recalls (such as sunroof adhesive) apply to you.
Old Jul 25, 2021 | 04:30 PM
  #299
jlunsford's Avatar
2004 C230K
Do TSBs expire?
Originally Posted by linkmustang
m271 guys go to the dealer now free work there is a new service campaign out on the 203 with the 271 moter are are replaceing the pcv hose and the lower hose for free even if u do not have a warranty or a check engine light is on do it
Do you think this will still work? It's been 13 years....
Old Jul 25, 2021 | 04:31 PM
  #300
drb930's Avatar
Recalls do not expire
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
