View Poll Results: Aftermarket Wheel Thread
W203
0
0%
CL203
0
0%
Voters: 0. You may not vote on this poll
W203/CL203 Aftermarket Wheel Thread - All you want to know
#4830
03 c240
#4831
18x8 wheels..but what offset? C320 4matic?
So im wondering.. i have a 2003 c320 4matic sport sedan, and am looking at some 18x8 wheels all the way around with 225/40/18 tires all the way around.. what offset shoudl i get?? I dont want to have to use any sort of spacers or anything.. i just want to bolt them on and drive... please help thanks..
#4837
MBworld Guru
white and whiter
ET30-35
I listed this in the other thread. mainly just light weight 18" wheels available.
Forged wheels:
BBS RE 20.3-21.5lbs for 18x8 ET35 and 18x9 ET38 (i run 5mm front and 10mm rear BBS spacers make'em ET30 and ET28, but they are not needed to clear calipers)
BBS LM 23.5-23.9lbs for 18x8.5 ET30 and 18x9.5 ET32
BBS RS-GT 20.8-21lbs for 18x8 ET35 and 18x9.5 ET32.
BBS RG-R 20-21lbs 18x8 ET35 18x9 ET38. (12mm spacer from BBS is needed to clear the caliper.) look at BlakeP's car for example.
OZ Superleggera 3. 18x8 ET36 18x8.5 ET32. these should be around 21-22lbs.
RENNtech Monolite. 18". forgot the width or offset, but they should weight around only 18lbs.
SSR Comp-H 18lbs 18x8. most likely discontinued.
SSR GT3 18x8.5 18x9.5...not sure if you can even find these anymore either.
HRE competition series
cast light weight wheels:
OZ ultraleggera 18.5lbs for the 18x8 ET35
OZ superturismo 24.7lbs for 18x8 ET35
OZ Crono 20lbs for 18x8 ET35
BBS CH 24.5lbs for 18x8.5 ET35 (need 5mm spacer to clear coilover)
BBS RX 24.3lbs for 18x8 ET32 (probably needs a 5mm or 10mm to clear the caliper. This is basically the cast version of the RG-R)
BBS RA approx. 22lbs each. 18x8.5 18x9.5 ET32. They are discontinued, but you can find them used usually on Audi forums. All you need is make the center bore bigger if the RA doesn't run BBS's hubring/spacer design.
other options I know less about which can be custom ordered in 18" spec you want if the shop has contact with Volks/Rays and Work:
Volks Racing TE37
Volks Racing CE28
Work Wheel VS-XX
hope this list will help some of you determining what you want for light weight wheels. There are more of them in 18" fitment such as the mentioned Enkei's etc. feel free to add them if you are sure about them.
Forged wheels:
Volks Racing TE37
Volks Racing CE28
Work Wheel VS-XX
#4838
MBworld Guru
white and whiter
List Of 18" Lightweight Wheel Setup For W203
here's a list of lightweight wheel setup that I can think of in 18" fitment for someone you that maybe interested.
Forged wheels:
HRE competition series.
Volks Racing TE37
Volks Racing CE28
Work Wheel VS-XX
Forged wheels:
Volks Racing TE37
Volks Racing CE28
Work Wheel VS-XX
#4843
2005 1.8 B/B
Brake Clearance
HI, i did search on the forum before i start this post.
On the other posts, none has mention about how much space do i need between the rim/spoke and the brake.
Or as long as the rim does not hit the brake and run through, then i am okay?
Because i only have 1.5mm between the brake and the rim.
#4845
#4846
C32 AMG
so i've read through this thread at least once. just need to confirm that these will fit my c32 with amg calipers and pretty decent drop with tein SS coilovers. I've read that the coils on the teins and narrower than the KW V2s.
The offsets match up with +32 in the front and +35 in the rear. No lip to really account for so I am pretty sure they physically fit I'm more concerned with the tires rubbing after lowering the car. I used the tire calculator and it's within the 2% diameter difference.
I guess what I'm really asking is can I drop it enough with this setup to have a nice stance with minimal gap without rubbing. How does a 35 and 30 profile tire hold up against potholes.
Thanks in advance for the advice.
http://cgi.ebay.com/ebaymotors/19-Me...em370039076369
#4848
'09 A4 S Line
#4850
C32 AMG
awesome. thanks for the quick reply. i also found some 5mm hubcentric spacers on ebay
