View Poll Results: Aftermarket Wheel Thread
W203
0
0%
CL203
0
0%
Voters: 0. You may not vote on this poll
W203/CL203 Aftermarket Wheel Thread - All you want to know
#4851
"One Man. One Engine."
Check out these replicas
http://cgi.ebay.com/ebaymotors/19-AM...spagenameZWDVW
...pretty damn good copy.
These are not as good...
http://www.bekkers.com/Merchant2/mer...ry_Code=amgrep
#4852
'08 CLK320CDI AMG// '13 E500 Coupe AMG// '17 E350d AMG
I have a question about the light weight wheels...
Being them light weight, do they have enough strength to support some considerable potholes!?
What I wanna know is, if I'll go with some of these wheels, won't they have the tendency to transform in a square wheel!?
I'm asking this because I'm running on replicas, but the quality is a little bit better than some years ago, but not as OEM! (I have all 4 wheels needing to be straighten up)
#4853
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Of course, the best thing is to avoid potholes no matter what.
#4854
Jeepney
Thought id post it here too: W203 material: FS 19" millenium Wheels with Toyo T1rs
If anyones interested, 1,900$ shipped 80% tire thread check link for more info
They have to go by this weekend
https://mbworld.org/forums/wheels-tires/238897-feeler-fs-19x8-5-19x9-5-millenium-rims-good-price-needs-go-asap.html
#4857
"Double Stuff" SOLD | Nor*Cals "Pesky Audi"
i miss havin those wheels. too bad the offset is too low. i'da saved em and threw em on the a3
good luck w the sale.
#4858
W203,W163,R170
Ok, Ive read though most of the posts but did not find the exact info that i was looking for.. I have a W203 C240 non sport package and was thinking if i could fit a 19X8.5 in the front with a 40 offset and a 19X10 rears with 45 offset.. Wheels are made by carlsson model 1/6 evo. Also, can I use 245/35 front and 275/30 rears? planning to use Tein springs. If it would not fit.. any suggestions on how I can make it fit? Thanks for you help! meantime, ill read through other posts..
#4859
I thought that somewhere in this thread, someone stated- a couple times, that something between et28-35 for the fronts and et32-35 (maybe a tad more) on the rears. With that being said- you can most likely use those wheels, but you will need some spacers and longer lugs.
I think I would cut that tire size down a little also. 225 or 235 fronts and 255 or 265 on the rears.
#4860
'09 A4 S Line
#4865
2004 C230K
I just got my rims & i need advice
I just got my rims and i need to know if it would clear and not rub on my car.
I have a 2004 C230 Kompressor and i got some rims that are 19x8.5 with a 32mm offset front and 19x9.5 with 35mm offset on the back....
The car is not drop or anything, and what discounttire told me that it wouldn't rub and the tire size that im going to need are 235/35/19 for the front and 255/30/19 on the back does anyone know if i would rub or if i would clear it with no problem.......
thank.......
thank.......
#4867
2005 W203 SS
thank.......
thank.......
yeh, if u dont have the big breaks on the front ur good to go, if u had them it would 36mm offset ont hew front and 32 on the back last i checkd. post pics of your wheels when u get them on ur ride. im still looking for wheels but cant decide... then i end up speding the money saved and then i need to wait again ahaa..
#4868
03 c240
ur okay. you can go 265 in the back and still be okay. also take into consideration the sidewall height of the tires. that plays a major role.
#4869
1996 MB E320 & 2010 Nissan Elgrand
Might rub if the suspension is too soft, no? Your car is SS?
Go with 245s/255s and not sure if ET32 will clear BBKs (if you have them)
#4870
MBworld Guru
white and whiter
#4871
Ok, I'm in love with these HRE M40
Any one know more info about them, weight, price!?
I think I read somewhere that the sizes are 19-20" if so I can forget it since I only want 18"
#4873
06 CTT-S
a friend was offering me to buy his giovanna wheels 20". i have a stock 06 c230 SS (tires are 35 but not sure about any other dimensions) it's black, with chrome lip. we'll meet up sunday. is 20 ok? i was just looking for 19. he won the wheels from a poker game. do i still need to drop the height? and upgrade sway bars? would an H&R lowering spring will do with stock shocks?
#4874
'02 CL203 M111
Im getting tired of not being able tu turn the steering wheel all the way to make u-turns. Front tire tuch the front part of the black plastic under the fender. is there any solutions other than getting smaller wheels or raising hight? coz I luv the way it looks now.
H&R coils, 225 40 18X8.5 and 255 35 18X9.5.
Any suggestions with that plastic
Or I just have to live with it?
#4875
I had the same issues and readjusted those wheel covers, it's been fine since that..Try to readjust them!
