View Poll Results: Aftermarket Wheel Thread
W203
![](https://mbworld.org/forums/images/polls/bar2-l.gif)
![](https://mbworld.org/forums/images/polls/bar2.gif)
![](https://mbworld.org/forums/images/polls/bar2-r.gif)
![](https://mbworld.org/forums/clear.gif)
0
0%
CL203
![](https://mbworld.org/forums/images/polls/bar3-l.gif)
![](https://mbworld.org/forums/images/polls/bar3.gif)
![](https://mbworld.org/forums/images/polls/bar3-r.gif)
0
0%
Voters: 0. You may not vote on this poll
W203/CL203 Aftermarket Wheel Thread - All you want to know
#6852
06 C230 SS 6spd
I had cls wheels that were 18x8.5 +28 & 18x9.5 +33 and was on stock ss springs and had no rubbing issues what so ever. Since his car sits higher he definitely wont have any issues with rubbing and having to roll his fenders. He just needs to go to a different tire shop.
#6853
Thanks phister i am going to goto anaheim wheel and tire bright and early monday morning. Hopefully i will have some victory shots to upload by the end of the week. The rims didnt come with lug bolts/nuts so i hope to get the proper length ones from them.
#6854
wheel spacers?
hello everybody, im new to MBW but so far love all the info you all have posted over the years. thank you!
i have an '03 230k coupe. its magma red with a blacked out grill and 20% tint all around. i just purchased a set of 18" 112mm X 5 35mm offset MSR style045. they are black with a silver lip.
i took them in today to belletire to get rubber and have them mounted and they told me the rims dont fit. they said the wheel is too wide and will rub against my struts. they also said that the center bore-hole is slightly too small. i dont get it, what am i missing? do i need wheel spacers? and if so, should i go; 10mm, 15mm, or 20mm?
im putting toyo 225/40-18 tires on them.
thanx again for your help. i hope someone replys as i REALLY want to mount these rims!
#6856
06 C230 SS 6spd
thanx again for your help. i hope someone replys as i REALLY want to mount these rims!![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
#6857
06 C230 SS 6spd
#6861
Would these fit my w203 coupe (2005)
http://www.alloywheelsdirect.net/mer...g_iv_wheel_413
Thanks in advance
Thanks in advance
#6862
06 C230 SS 6spd
Thanks in advance
Thanks in advance
#6865
06 C230 SS 6spd
You'll need at least 15mm spacer up front and 55mm shank lug bolts to accommodate the spacer and you'll need 20-25mm spacers in rear and 60-65mm shank lug bolts. If you're looking for a nice set of 17s you should go for the SS 5 spoke wheels or 07 w203 wheels, both are good choices.
#6866
phister, would using 15mm spacers all around be ok? ive never used spacers before. i dont have any coilovers and i havent rolled my fenders. although im open to doing all of that and actually eventually want to, just dont know enough about camber and such yet.
wheels were the 1st step. then headlights. then everything else.
thanx again sir. have a good one.![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
~daniel.
~daniel.
#6867
06 C230 SS 6spd
15mm would be fine just get hubcentric 66.6 spacers and correct lug bolts. Roland has 15mm spacers I believe. You'll have to get a camber kit once you lower your car.
#6871
1999 E320 4matic Wagon, 2005 C55 AMG - sold, 1998 VW Jetta TDI - sold, 2006 C230 Sport - Totaled :(
if i'm not mistaken, all of the w203 sedan wheels should fit on each other EXCEPT, sedans with the sport package(i.e. larger brakes in the front) will only fit the wheels that come on the sport package models. But if you're getting wheels from a sport package model for non-sport, then it's no problem.
#6872
will these fit
Looking to pick up some wheels with these specs
Diameter: 19 inches
Width: 8.5J front
10J rear
Offsets: ET 30 front
ET 35 rear
Anyone know if these will work without needing spacers or rolling fenders? What tire sizes would you guys recommend?
Diameter: 19 inches
Width: 8.5J front
10J rear
ET 35 rear
#6873
06 C230 SS 6spd
You should be ok if you dont lower your car, 10" in the rear is pushing it. Hector has 10" in his rear if I recall corretly and is on OEM SS springs. But if you plan on lowering it you'll have to either stretch the rear tires so it doesnt rub or you'll have to roll and pull the fenders to get them to fit and not rub.
#6874
FRONT: 19x8.5 rims with 235/35R19 tires
REAR: 19x10 rims with 265/30R19 tires (maybe???)
You certainly won't need spacers,... but I'm not as sure with regards to rolling fenders (especially the rear ones). Anyways,.. with 19" rims and super low tires,.... you better be driving on baby-butt smooth roads.
