View Poll Results: Aftermarket Wheel Thread
W203
0
0%
CL203
0
0%
Voters: 0. You may not vote on this poll
W203/CL203 Aftermarket Wheel Thread - All you want to know
Old Nov 9, 2011 | 01:13 PM
  #7076
aznmode's Avatar
2010 c300
Originally Posted by phister
you'll probably only need spacers for the front wheels to clear the calipers, maybe 5mm will work if not 10mm will clear. just test fit them when you go see the wheels. Rubbing will depend on the tire size you use.
Thank phister. I'm probably gonna go with yok s drive tires so I shouldnt have any rubbing.
Old Dec 6, 2011 | 06:57 AM
  #7077
Ceeke's Avatar
C180
Hi,
If found a nice set of winterwheels, but I don't know if they will fit... : 7,5 x 16 et42, tires 225/55/16. My car is a little bit lowered (3cm) with the Eibach pro-kit (springs).
Can anyone help me?
Thanks,
Ceeke.
Old Dec 6, 2011 | 11:19 AM
  #7078
phister's Avatar
06 C230 SS 6spd
Originally Posted by Ceeke
Hi,
Can anyone help me?
Thanks,
Ceeke.
Itll be close on the inside. Highest offset i would go is +38. Id get a 5mm spacer just for reassurance
Old Dec 7, 2011 | 01:53 AM
  #7079
Ceeke's Avatar
C180
Thanks Phister for an answer.
I found a calculator for wheels and ET. Now i'm driving on 8.5 and 9.5 ET35.
If I go for those winterwheels, this calculator says it will be 18.4mm less close on the inside than the 9.5 and 5.8mm less for the 8.5.
So it will be no problem??? Or do I forget something??
Thanks for reply,
Ceeke.
Old Dec 7, 2011 | 04:30 AM
  #7080
phister's Avatar
06 C230 SS 6spd
Sounds about right since they're 7.5" it should be ok since they wont be as wide.
Old Dec 7, 2011 | 11:23 AM
  #7081
Gbrewer's Avatar
2006 C230 Sport/2002 C230k coupe sport
Anyone know of any ADV.1 style wheels? I've found Concept one's CS-5.0 but it only comes in a 20x8.5"f and 20x10.5"r size. I'd like to fine some that style but don't want to pay $6000. Any help would be greatly appreciated!
Old Dec 7, 2011 | 12:31 PM
  #7082
BlkBenz8's Avatar
07 C230 (sold) 2009 E63 AMG (SOLD), 2015 E 63 AMG S
Theres the VMRs they have some wheels with concave.
Old Dec 7, 2011 | 01:22 PM
  #7083
Gbrewer's Avatar
this is what I'm on the hunt for but the concept one's only come in the 20" size, kind of lame if you ask me since 19" seems the most popular size for the Euro scene...
Old Dec 7, 2011 | 08:32 PM
  #7084
BlkBenz8's Avatar
Buy the 20s, roll and pull your rear fenders! Theres acouple of members that ride on dubs.
Old Dec 9, 2011 | 08:54 AM
  #7085
Gbrewer's Avatar
They are 20x10.5" with a +25 offset. I don't think the little sedan would have a chance lol
Old Dec 13, 2011 | 06:27 PM
  #7086
C_DirtyTwo's Avatar
a land yacht.
HELP!
Ok, I need some expert wheel advice.
I currently have a 19x8.5 up front with a +32 offset and a 10mm spacer. This means the offset is a +22.
It rubs a tiny bit on the coil on the inside, but I can't move it any further out because it will rub too much on the fender (it currently rubs a little on the fender too).
Here's the deal, I want to run 18's and the wheels I want are 18x8.5 with a +35 offset up front. With my spacer that would make it a +25 offset and I think it'd rub too much on the coil...and if I move it out further with a bigger spacer it would rub on the fend as well because it too is an 8.5in rim...
Does anyone have any ideas of how I could run these wheels without rubbing or having a stretched tire??
Any help would be great. FYI current tire size is 225/35 19
Old Dec 13, 2011 | 07:11 PM
  #7087
drtyjrzy's Avatar
05 C230K Sport
I can't imagine why you are rubbing on the coil. I am running 225/40 18 with a 32 offset up front. no rubbing anywhere, no spacer. if your gonna get a set with a 35 offset look for 3mm spacers and you should be fine. unless you have some crazy oversize coils I don't see a problem.
Old Dec 13, 2011 | 11:12 PM
  #7088
loudandheard's Avatar
C32/C55 AMG
What would need to be done to run 19" clk63 nd wheels?
Old Dec 14, 2011 | 06:07 AM
  #7089
Glyn M Ruck's Avatar
Super Moderator
Nothing - Offset is ET34 front ET30 rear.
Old Dec 14, 2011 | 12:51 PM
  #7090
Gbrewer's Avatar
Thinking of just going with some brushed Forgestars. Someone please chime in... whats the most agressive stance someone is running on a w203???
I plan on running tein basics, stretching 235's on the rear, 225's on the front, fender rolling, but NO extra camber. 19's.
Old Dec 14, 2011 | 01:00 PM
  #7091
ahmadk's Avatar
2011 E550 Sedan
check this out newbie.... but it's a Wagon though
https://mbworld.org/forums/c-class-w...s-madness.html
Old Dec 14, 2011 | 01:05 PM
  #7092
Gbrewer's Avatar
newbie? lol I had HRE 540R 19x10's on the rear of my 3 series sedan which many have not been able to fit. But I think I've been struggling with the fitment on this car because everyone seems to be having fitment issues with the suspension on the inside. Thanks for the link though!
I'm wanting to run somewhere around these specs:
19x8.5 front +35
19x9.5 rear +32
235/35/19 rear tire
Anyone see any issues with this setup?
Old Dec 14, 2011 | 01:06 PM
  #7093
C_DirtyTwo's Avatar
a land yacht.
Because I have KW V2's and they are as low as they'll go, the bottom spring sleeve and spring rub
Old Dec 14, 2011 | 01:14 PM
  #7094
ahmadk's Avatar
2011 E550 Sedan
I didn't mean any disrespect..sorry about that
What I meant was new to the forum ..
Old Dec 14, 2011 | 01:50 PM
  #7095
Gbrewer's Avatar
None taken, I knew you were just playin giving me a hard time lol
Old Dec 14, 2011 | 01:57 PM
  #7096
Gbrewer's Avatar
Definitely what I am trying to avoid.
Old Dec 14, 2011 | 03:00 PM
  #7097
phister's Avatar
06 C230 SS 6spd
you have to take in to count your wheels are going from 19 down to 18s. I had 18x8.5 +28 offset and the wheels never touch the struts or springs when I was dropped all the way on my Teins. If you're scared of it touching just get 12mm spacers so it pushes it out just a tad bit more. If you havent done so, roll your fenders and pull it a touch so it doesnt rub in the front. I have 17x8.5 +20 and I have no issues at all in the front with rubbing and my tires are 215/45/17.
I dont think +25 offset on the 18s will rub. but if you're unsure there are 12mm spacers out there, think it'll be enough not to rub the struts or the fender.
Old Dec 15, 2011 | 10:36 AM
  #7098
Gbrewer's Avatar
Whatcha think?
W203/CL203 Aftermarket Wheel Thread - All you want to know-mepewteradv1.jpg
Old Dec 15, 2011 | 11:22 AM
  #7099
C_DirtyTwo's Avatar
a land yacht.
Ok I think I found a better set up.....
Front: 18x8 ET32 + 10mm spacer = 22
Rear: 18x9.5 ET40 + 5mm spacer = 35
That will give me the same offset I have in the front right now, but with a 1/2in more narrow rim. Hopefully it won't rub on the coil or the fender now.....what do you guys think?
What tires would be equivalent to my 225/35 19 and 265/30 19 I have now but for the 18's? 225/40 18 and 265/35 18??
Old Dec 15, 2011 | 04:58 PM
  #7100
Peydidy's Avatar
C63 AMG
Anyone here trying to sell there rims? I have a 05 c230 and I am trying to get some sick looking black rims, but I dont want to spend to much either. If not does anyone know a good place to get rims either online or in the bay area or in orange county?
You have already rated this thread Rating: Thread Rating: 16 votes, 5.00 average.
