DIY - Fuel Filter Replacement
You're not reading my post properly, and I couldn't care less if Bosch invented anything. First thing is they have MASSIVE quality control problems with the stuff they actually make, then in the US, such maintenance items aren't even made by, nor even overseen by them- they license their name to third parties to produce with no involvement by them at all. The last visit I made to the US, I checked out the Bosch filters at Autozone- the regular Champion garbage and very different from what I see here. The Autozone showed me the boxes it came in- source was somehow related to both Purolator and Champion, and the filter was identical to the ubiquitous Champion type, but more expensive.
http://www.bobistheoilguy.com/forums...Number=1476607
What you get from Bosch depends on your local market and you have to go on a case by case basis, as with anything.
PS- it was not invented by Bosch.
and Bosch/Mann purchased Purolator?
they seem to like the oil filter...
humm... not sure if I want to use it or not if it's not good like Glyn said...
Case by case, like I said. In the case of Audi/VW, even the high end aftermarkets had bypass valves which were set too low, for instance. In some cases, piece of mind might outweigh the costs. In my case, I have the luxury of being able to buy the exact part aftermarket, right from any shop, but for a savings. They might like it on that forum, but that is not real data. I love the filters that have cases that balloon under pressure. That's always good for a laugh. The bypass resulting in unfiltered oil flowing for longer is an issue, I would think, but I'm looking for filtering. In my case, like last Sunday, I was running at 4000+ rpm for well over an hour on a trip home. Don't want blowouts of the media and definitely want to ensure the fuel filter is working right.
oem MAHLE-KNECHT fuel filter isn't that much.
$41.66 from rmeuropean.
funny thing is the oem filter is cheaper then the Bosch from rmeuropean.
ended up with the Bosch one because I wanted to get some power steering fluid and in order to qualify for the free shipping from AutohaustAZ, order needed to be of certain amount.
at the time didn't need anything else but I knew fuel filter change was coming up so ended up picking up the Bosch since they don't carry the Mahle-Knecht.
maybe it wasn't a smart move...
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Aye, keep yer panties on...my eyes aint that bad,
I can still read,
with glasses.
No need to get testes.
Going forward I'll definitely use the Kneckt.
Wasn't aware of all these quality issues at Bosch.
Well, of course there is the old joke, why do the germans drink warm beer;
Bosch refrigerators.
Now I'm wondering if I shouldn't pull the bosch.
I used a Bosch oil filter last time around, an add-on to get the free shipping.
Wow, rockauto has Mann oil filters for the M111 for $4.24
I can still read,
with glasses. No need to get testes.
woke up this morning to find my 2001 C180 would no longer turn over. Cranks continuously but never starts.
Pressed the fuel rail pressure valve and nothing came out. Will be testing with a pressure tester tonight, and most likely have to get a replacement filter (hasnt been done in a LONG time).
Hopefully thats all it is.... FYI - i got quoted $99 for a replacement here in Australia
So I guess I'll check the fuel pressure and spark, but if that's good then what?
- bad gas? I can pull the fuel line off the filter and prime it out
- Clean the maf? Ive searched and read mixed opinions on this?
- clean throttle body? I mean come on, this couldn't keep it from starting could it?
- Compressor is seized (is there a clutch on this thing) ? It sure didn't feel like it was making power during the short period where the car ran but like crap. What about a boost pressure relief valve being stuck open?
- Vacuum leak?
- some kind of crank position sensor or camshaft position sensor? (besides fuel and spark, this is about the only think to keep this thing from running)
BTW car has recent (within past 6 months) motor and tranny oil and filter change, and yes I used the 15$ a quart tranny fluid.
Thanks all
Rob
So I just put the fuel pressure guage on the car, no pressure with car off. Turn key to ignition, fuel pump primes but no pressure. Turn key to start (full on) car turns over but won't fire, but fuel pressure slowly builds. Car only cycles a few times and the fuel pressure immediately drops once it stops turning over. So I immediatey cycle ignition and then fuel pressure builds enough so car will start (continuing from where it fell builds enough pressure. It holds 40psi at idle, but drops rapidly as I rev the engine.
What is the culprit?
Seems like pump is weak and the check valve is not working properly?? Maybe the filter is causing both these problems??
Thanks guys
Thanks guys
Super Moderator
Fuel pressure should come up to spec immediately. You might have a clogged filter or the pressure regulator might be damaged inside the filter. It sounds like fuel pump to me.
Install university has a complete pump replacement method. It's easy.
Here
Here
Glyn nailed it on one of his old posts about the regulator being in the filter. The regulator was stuck open and it was just dumping fuel back in the tank (basically just making a loop so no pressure would build. A very poor mechanical design methodology on Mercedes part to put the regulator in the filter IMO. For one it means an unnecessary regulator swap everytime you do a fuel filter, two it drives up the cost of the filter, and three the design sucks and is unreliable (probably somewhat due to the higher ethanol content in fuel these days). Its the first time in my life that a fuel pressure regulator went bad on me. Anyway , car runs like a champ now ... So much for preventative maintenance , if i would of left the factory filter on there at 70k this probably wouldn't of happened...
Rob
Rob
Super Moderator
Damn, another filter giving trouble. Last one was d1no. OK in future default recommendation will be do filter even if new before pump.
Great!
Great!
'02 C320 Wagon, '78 308 GTS, '06 Highlander Hybrid
Hey Guys,
I replaced my filter on my C320 a few months ago and all was fine. A few weeks ago my wife said there was a loud humming noise. It sounds like it is coming from the fuel pump. I replaced the filter with an OEM from the dealer. Do you think I got a defective filter? Any thioughts?
Hey Karo,
Today I actually stopped by the dealer and bumped into a tech in the parking lot. I asked him about the humming noise...he asked if it was coming from the pump or the filter. Has anyone heard of this noise coming from the filter? I have not gone under the car, but assumed that it was from the pump. The tech said that he has seen some defective filters. Of course, it was not making the noise when I was there.
Hey Karo,
If you change the filter again will you be able to tell if that was the remedy right away? Or is the sound intermittent?
Sorry to go into too much detail but to answer your question yes filters would make the humming noise if it's defective or if something is clogged.
Since the filter is a cheap fix change that first and go from there. The pump is a real PITA (from what I hear).
Can you return your defective filter?
Hey Karo,
Well lets backtrack a little bit, how is the car running? If it runs great with no loss in power at high rpm, its likely not the filter but a pump going bad. Or something else.
I doubt your filter is already clogged...but then again, I didn't think anybody was stupid enough to put a regulator inside a fuel filter
Super Moderator
The filter can't make a noise. Only the pump. Filter might not be clogged but the pressure regulator could be faulty. I think likely pump trouble. Change filter first.
