Passenger Side Seat Adjustment FUSE keeps blowing out.
Old Nov 11, 2008 | 05:05 PM
The Punisher's Avatar
C220 CDI year: 2001
Out of the blue, for some reason the passenger side seat adjustment fuse keeps blowing out, I replace it, it will be ok for a few days and then boom it's burnt.
Have no idea why, any run into this??
Old Nov 11, 2008 | 08:11 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
The passenger seat control module is notorious for failing and causing all sorts of battery drain issues. This might be a good sign its failing.
Old Nov 12, 2008 | 12:38 PM
DarthBudice's Avatar
08 E350 4MATIC
Is the fuse blowing only when the power adjustments are activated?
If so, visually inspect the wiring at the control module (under the seat) (front and back wiring) for binding in the fore/aft seat rail.
A short to ground there will cause enough current to flow through that ckt to pop a fuse.
Please let us know what you discover, it may help others with similar problems...
Old Nov 12, 2008 | 01:26 PM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
+1...common problem....
Old Mar 28, 2010 | 12:04 PM
Sorry I am only getting back to this thread now, since I only use the car when I am on vacation to Europe, it is hard to keep track..
So i remember back when i wrote this post, I had checked the wires and they didn't seem to be caught anywhere or shorting anywhere.
The fuse would only blow as soon as I activated one of the seat controls.. I am off to Europe again this summer and would like to possibly get this fixed so the wife doesn't complain.
I am wondering if replacing the whole Seat Control Module is a good idea? Without my being there how do I go abouts of knowing which part number it is ?
It is W203 C class September 2001 C220
Old Oct 27, 2010 | 03:25 AM
PROBE's Avatar
C240 2002
Originally Posted by The Punisher
C220 CDI year: 2001
In my C240 2002 sedan both passanger and drivers seat power controls do not work. Where the relevant fuses are situated ?
Probe
Old Apr 24, 2012 | 02:03 PM
kouka86's Avatar
anybody figure out if its the seat control module that's responsible for this? I'm running into the same problem
Old May 4, 2021 | 10:23 PM
rayradar's Avatar
2004 c240
In my 2004 W203 I found that the blowing fuse issue was that if you remove the 30A fuses (the one for the seat motors with memory which my car does not have) in the instrument fuse box, the 30A fuses in the trunk will power the seats without blowing.
