Air conditioning after front defrost
Old Nov 26, 2008 | 12:47 AM
DiBenz's Avatar
19 XC90
Question Air conditioning after front defrost
In my 07 C230, if I push the button to turn off the front defrost, the air conditioning button lights up. Is this normal behavior? I am using the heat at the time, so I wouldn't want the a/c on. What gives here. Thanks in advance.
Old Nov 26, 2008 | 01:25 AM
acr2001's Avatar
2012 C300 4Matic
Unless this is something new to 07 something is wrong. When you push the button to turn off defrost it's supposed to return to your previous setting, so if you had the AC on previously, then yes it would turn back on. Otherwise it would not.
Old Nov 26, 2008 | 10:03 AM
Glyn M Ruck's Avatar
Super Moderator
This is correct if the aircon is turned off. Defrost engages the aircon. If you turn defrost off & the aircon was previously off then the aircon light should burn.
Old Nov 26, 2008 | 07:55 PM
DiBenz's Avatar
19 XC90
Yeah I was reading in the manual that air conditioning was used like a dehumidifier as well or whatever, but why does it stay on? Or is the whole idea supposed to be that it comes on after you defrost? I guess I just don't get it. Should I be turning it off right away? I want heat! NOT A/C
Old Nov 27, 2008 | 11:36 AM
Rainman15's Avatar
09 C350, 1960 Impala
My 06 does the same thing. It is normal to our models.
Old Nov 27, 2008 | 01:13 PM
GotDaBenz's Avatar
'03 C320 Sedan, '04 SAAB 9-3 Cabrio
When the AC light is ON, the AC is OFF. So when you turn defrost off the ac is off also. Assuming you hasd heat going.
Old Nov 27, 2008 | 01:20 PM
Super Moderator
+1 correct. Light on = Aircon OFF
Old Nov 27, 2008 | 03:32 PM
acr2001's Avatar
2012 C300 4Matic
This is only correct of the older pre 2004.5 models. From then on the light is on when the A/C is on.
Old Nov 27, 2008 | 03:36 PM
Super Moderator
Interesting - a lot more logical I would think. Now DiBenz must be thoroughly confused
Old Nov 28, 2008 | 06:49 PM
DiBenz's Avatar
19 XC90
I actually knew that much because I had an 04.5 sedan.
Old Nov 29, 2008 | 05:22 AM
Super Moderator
Excellent - I've always considered the " aircon light logic" screwy on my car
