HID kit
Old Jan 6, 2009 | 10:09 PM
ep11turbo's Avatar
'03 C240
HID kit
Hello everyone, I'm new here. I have an '03 C240 and today I installed projector headlights w/HID kit already installed. When I turn the lights on w/the engine off they work fine, but as soon as I turn the engine on the flicker and turn off. I also get low beam H/L malfunctions. Has anyone had this problem and what can I do to fix this? Thanks.
Old Jan 6, 2009 | 10:14 PM
anthuny85's Avatar
06 c230 v6 SS
you probably need antiflicker capacitor harnesses to be installed inbetween your ballast and oem harness. i have a spare set if you need them, ill sell for $35 shipped.
basically HID kits run 35w, your stock wiring harness runs 55w, when the hid kit comes on, its basically underpowered, so the antiflicker capacitors basically store the extra power they need to run flawlessly.
Old Jan 6, 2009 | 10:41 PM
e1000's Avatar
a quarter mile at a time
you're principles are off but the end result is correct
Old Jan 7, 2009 | 09:00 AM
Brad S55(IN)'s Avatar
I drive a 2013 ML350
Where did you pick the HIDs up at? I saw some on eBay, but hard to say what is good vs bad
Old Jan 7, 2009 | 12:07 PM
ep11turbo's Avatar
'03 C240
Yep, I got the ones from ebay. I mean, they work fine if the car is not on, lol. I'm gonna try fixing this, but if not I'll try to put on the original bulbs, but the projector H/L's look to good.
Old Jan 7, 2009 | 01:30 PM
anthuny85's Avatar
06 c230 v6 SS
i can almost guarantee that you need anti flicker capacitors. check the wiring of the hid kit from the ballast to the oem harness, you'll see a middle harness with a capacitor of some sort, if you do have one, then im not sure whats causing the problem, i just know from experience because i installed HIDs in my projectors and fogs as well.
Old Jan 7, 2009 | 07:24 PM
ep11turbo's Avatar
'03 C240
Hey guys thanks for all your input. Today I installed 2 caps and its working perfectly, no flickering or turning off.
Old Jan 7, 2009 | 10:57 PM
anthuny85's Avatar
06 c230 v6 SS
told you
Old Jan 8, 2009 | 03:46 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
version code XENON to PRESENT
