Replaced Hose, Still CEL, probably O2 sensor
P0138
P0170
P0178
I took it to the shop and they replaced the crankshaft hose which was visibly torn. However, after a day, the CEL came on again, this time throwing the following codes:
P0136
P0138
Those two codes above have to do with the second O2 sensor. Today, I read those codes and reset/deleted them. I then drove 3 miles and the CEL has yet to come on. The engine does feel "different" so I'm pretty sure it will come on again. What do you think, second O2 sensor?
Is there a tutorial than the one in the DIY sticky (https://mbworld.org/forums/c-class-w...acement.html)? The guy seems like an idiot. Do I really need a jack stand to get to the second O2 sensor? I might have to take it to the shop again.
Thanks for your help.
BTW what mileage has the vehicle done? I hope for your sake it's just a failed O2 sensor.
I just drove to the store and back (1 mile each way) and the CEL did not come back on.
More on my situation:
Both times the CEL came on, I was on the highway. Could it be a heat or stress problem.
A more technical question:
When the CEL comes on the engine "appears" to on an open loop mode, but when I reset the code with an OBDII computer, the car seems to go back into closed loop operation. Will the car ever go back to closed loop if there are stored codes (the CEL light being on).
Thanks.
Thanks.
Thanks.
I'm delighted that you don't have leaking cam sensors. Please fit the pigtales so when they leak you don't compromise anything.
Default map does not mean poor running - just not optimum running & emissions
So it depends what triggers the CEL as to whether it goes open loop or not with the CEL burning.
My CEL came on again at roughly the same place at my daily commute where it usually fails. I had to drive around a bit for work and it didn't come on so I was illogically hoping I was in the clear. This time i only got the P0136 code. I'm thinking that the downstream O2 sensor actually went bad.
Any opinions?
I'm afraid it looks like you need a new lambda sensor
It's too bad that it'll have to go to the shop again as I don't feel comfortable jacking up the car. Is the mercedes O2 sensor the same as the Bosch sensor that your average auto parts store would sell.
for example: http://www.autozone.com/selectedZip,.../selectZip.htm (i like how the price jumped up 20 dollars when i typed in 90210 for the zip code)
Bosch make universal sensors & the Merc genuine article which I understand to be preheated.
That Autozone sensor looks correct - the generics are cheaper - I guess the Beverley Hills code brings in CA tax or maybe just rich beeotch tax
Stay out of the oilco downstream - It's a dynosaur industry run by dynosaurs. I had a wonderful global career but today it sucks. I'm pleased to be out & not so pleased to be consulting due to the brain drain the industry has suffered due to their own stupidity. Today they hire people that are PC not competent.
People that had m271 CAM sensor problems:
Is that usually the end of it? Did they make any changes to the leaking gasket such as changing its material to silicone? I understand that the ECU could go bad (but it's still covered under the 80k emissions warranty so no problems) and the other sensors (o2 upstream and MAF) could fail due to previous oil exposure, but I'm prepared to shell out for those. My main concern is if the CAM sensors will leak again.
Less than $600 for all the parts and a sat. morning working on the car.
Clearing a check engine light does not remove the problem or improve performance when something is wrong.It just clears the light,the code remains stored in the ecu and the condition remains active.
The indie is going to break your wallet if you keep going to him.Do you have your own obd2 scanner?They are only $45 for one that will read,clear and display I/M readiness codes.
As for the upstream and MAF, apparently they're easy to do with just hood access, so I'll probably do them myself, but they're not failing according to the codes.
Where I'm at now is if the new CAM sensors (and new isolating wires) are a good fix?
Thanks.
I'm having a similar problem to Dead_Eye and I hope that it's not as severe: https://mbworld.org/forums/c-class-w...-cold-cel.html
Another solution
