Worse MPG with Denso Iridium 5304
Old Feb 3, 2009 | 05:42 PM
dan46n2's Avatar
2011 E550 4matic
A few weeks ago I made a 1,000 mile trip with the stock plugs in my '04 C230. Then a few days ago I changed them out to Denso Iridiums the 5304 package and did not re-gap (as recommended) and made the same trip again. Before the change I was getting about 30-32 mpg per fill up. With the Densos I got 26-28. The car seemed smoother but acceleration seemed worse. Anyway I'm going back to factory plugs. I was expecting a lot better.
Old Feb 3, 2009 | 05:51 PM
Mu9enx's Avatar
01' C32o
there's your problem, most likely. you should regap it, although sparkplugs shouldn't have that much of an effect on your gas mileage. i think it would be less than a 1mpg difference
Old Feb 3, 2009 | 05:56 PM
dan46n2's Avatar
2011 E550 4matic
I would but Denso recommends not to gap them because the 0.4 mm electrode might break.
Old Feb 3, 2009 | 06:22 PM
dan46n2's Avatar
2011 E550 4matic
One thing I noticed besides the gap being bigger, is the length of thread on the Denso that screws into the engine is significantly shorter than the OEM plug, maybe that has something to do with it.
Old Feb 3, 2009 | 06:41 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
the question is did you buy the IK20 for the 1.8 or the 2.3. plug # and stock # are the same, but they have different gap. 1.8 has .040 and 2.3 has .044. if you are seeing significant bigger gap than stock plugs then you probably bought the wrong plugs.
Old Feb 3, 2009 | 07:01 PM
jturkel's Avatar
02 C32 AMG
wrong plugs or wrong gap....and yes, spark plugs affect gas mileage......the proper plugs will allow for more efficient combustion...
Old Feb 3, 2009 | 07:44 PM
dan46n2's Avatar
2011 E550 4matic
The box says IK20#4, 5304#4, and I04. I don't know if thats a 0.40 or 0.44 gap but even if it is the bigger gap would 0.04 make that much of a difference?
Here is a cut and paste from Denso's site:
MERCEDES-BENZ
C230
YEAR 2004
ENGINE TYPE L4
LITER 1.8
CC 1796
ENGINE DESIGNATION
STANDARD PLUG NO -
STANDARD PLUG STOCKNUMBER -
PLATINUM PLUG NO -
PLATINUM PLUG STOCKNUMBER -
IRIDIUM LONG-LIFE PLUG NO -
IRIDIUM LONG-LIFE PLUG STOCKNUMBER -
IRIDIUM POWER PLUG NO IK20
IRIDIUM POWER PLUG STOCKNUMBER 5304
GAP 0.040
I don't see any other designation other than IK20 and 5304 to be able to tell what gap the plugs would come with.
Old Feb 3, 2009 | 07:56 PM
Utahkompressor's Avatar
W124, W203, W204, W251
What is the standard plug on M271?
Bosch? Champion? or Beru?
Old Feb 4, 2009 | 12:07 AM
mleskovar's Avatar
'17 Jaguar XF
What does 'significantly' mean?
Old Feb 4, 2009 | 12:08 AM
dan46n2's Avatar
2011 E550 4matic
Noticeably would have been a better descriptor.
Old Feb 4, 2009 | 12:12 AM
mleskovar's Avatar
'17 Jaguar XF
Or 'considerably'.
Old Feb 4, 2009 | 12:15 AM
dan46n2's Avatar
2011 E550 4matic
Or 'considerably'.
Take your pick, or just imagine I wrote "considerably" if that helps
Old Feb 4, 2009 | 12:22 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
might be wrong, but i remember seeing the gap on the package when i got the IK22 for the 32.
also on the site you can see Denso listed Ik20 also for the 2.3, but under the gap it's listed larger.
Old Feb 4, 2009 | 12:26 AM
dan46n2's Avatar
2011 E550 4matic
Well I'm going to replace them for now with some NGK iridiums that I have on hand and see if I get better MPG until I go back to stock. Also I'll measure the gap on the Denso's and report back what they are since I can't tell from the packaging.
Old Feb 4, 2009 | 12:42 AM
mleskovar's Avatar
'17 Jaguar XF
Well I'm going to replace them for now with some NGK iridiums that I have on hand ....
No offense, but WTF are you doing? Swapping plugs until you can match the stock performance? Go back to the originals before you do some real damage, they're probably still good.
Old Feb 4, 2009 | 12:44 AM
dan46n2's Avatar
2011 E550 4matic
No offense, but WTF are you doing? Swapping plugs until you can match the stock performance? Go back to the originals, they're probably still good.
No, they're not, they have 60k+ miles on them and after taking them out they don't look that great. Also I already have the Denso and NGK plugs and a lot of free time.
Old Feb 4, 2009 | 12:50 AM
mleskovar's Avatar
'17 Jaguar XF
.... they don't look that great.....
What does "they don't look that great" mean? What did the plugs gap out at?
Old Feb 4, 2009 | 12:52 AM
dan46n2's Avatar
2011 E550 4matic
They looked fouled, I don't know what the gap is yet on the Denso plugs, I should get to them tomorrow. Also what did you mean by "real damage" in your previous post?
Old Feb 4, 2009 | 06:54 AM
Glyn M Ruck's Avatar
Super Moderator
Guys, running .04 different plug gap with a modern high energy ignition system won't make any difference to MPG, but running a plug with the wrong reach & heat range most certainly will.
So - check heat range
Check tip protrusion
Check thread length
If they are not the same as the Bosch OE plug in most parts of the world then don't use them.
And the comment "don't look great". Well - to read a plug with any accuracy at all it needs to have been running fully warmed up in the self cleaning range for about 15 miles, preferably longer, before what you are looking at means anything. If you took the plug out after a short run to the store, any plug will look crap.
Old Feb 4, 2009 | 08:30 AM
dan46n2's Avatar
2011 E550 4matic
Check thread length
Thread length is definitely shorter on the Denso plugs, and I did run the car about 10-15 miles before taking the old ones out. I think I'll take your advice and go back to Bosch.
Old Feb 4, 2009 | 09:24 AM
SickSpeedMonte's Avatar
2007 C230 and 1985 Monte SS
If the threads are shorter, the electrode isnt in the right position in the chamber. It is possible that it is actually still in the spark plug bore when you tighten it down, which would cause a TON of shielding of the flame upon ignition, and that would definately cause your mpg decrease, as well as the loss of acceleration. Its not the irridium plug, persay, that is the problem, its the dimensions.
Old Feb 4, 2009 | 10:07 AM
Super Moderator
+1 - spot on & thank you. You also don't want shorter threads because the threads in the head will foul. Then someone will put the correct plug in again & bugger up the threads in the head. A good old VW problem.
Old Feb 4, 2009 | 12:21 PM
mleskovar's Avatar
'17 Jaguar XF
..... Also what did you mean by "real damage" in your previous post?
It could burn holes in the tops of your pistons. Stick with the standard plug the motor is designed for. It's engineered for optimum performance and gas mileage.
Old Feb 4, 2009 | 03:51 PM
Super Moderator
Good move At least for you it's only 4 plugs & not 12 like mine. I'm just staying with Bosch as well.
Old Feb 4, 2009 | 05:26 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
you've definitely bought the wrong IK20. lol
