Spark Plug Replacement - M271
The C230 purred too.
The C230 purred too.The Best of Mercedes & AMG
I ask because I don't know. I want to get Platinum Ir Fusion, how will it "trash my engine"?
FYI - I have a 2005 C230k (4 door)
Thanks!
Walking through this all I'll need are:
1) x4 Bosch FR-6-MPP-332 spark plugs
2) Antiseize for the threads (isn't there something else that's also
recommended to be dabbed onto the spark plug?)
3) 7" Extension for ratchet to get deep into the head to get to the plugs
4) Whichever socket (from MB or Torx E8) to use
5) Elbow Grease
Am I missing anything? Sorry, I've never done a spark plug change before and I wanted to learn now and do this for myself. I'll take photos and try to make an attempt at a write-up for the M271 (since there are 2 write-up's sticky'd for the M112 only).
Thanks in advance guys!
Toyota states 19 ft-lbs if you don't use anti-seize, and 11 ft-lbs if you do use anti-seize -- the concern being that anti-seize can allow you to overtighten the plugs. Do we have a similar issue with our engines, or is 18 ft-lbs good with or without anti-seize?
Thanks. John
Do you recall which plugs you ended up with? I purchased an '05 c230 and will be changing all fluids and spark plugs since it doesn't have too many service records. Seems that the NGK might be a better option since it's iridium versus platinum. I'm seeing online that the NGK ILFR6A is the correct plug for the m271 engine?
